Question about Dell Vostro 1500 Notebook
Type the correct pass word to continue and press enter
  • Patrick Kirwan May 11, 2010
    Where it say this? is it on the login screen? What OS have you
    Is this on the login screen? what Os have you?
    Scholar:
  • 74 Answers
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on Nov 05, 2009
  • 3,940 Answers
If you are dealing with a BIOS level password (Before Windows Loads) an you don't have the password, you'll need to contact Dell Technical Support for a Master Password (There are no jumpers or an hardware manner to bypass the BIOS password).
To get a Master Password from Dell, you will need to be able to verify you are an approved system user, then they will assist with the password. (If system is not in warranty, there may be a fee for tech support)
Posted on Sep 14, 2009
Why am I continually receiving error message 0x800CC92 when trying to access emails.
Hi Angela,
The first step is to check your Outlook Express settings, making sure that the POP3 and SMTP servers are as in the screenshots, and that your full user name and password are correct.
Then test your connection by following this procedure.
Click the Start button then RUN type in cmd on (Windows NT/2000/XP) or Command (Windows 95/98/ME). This will open a new command prompt window, with white text on a black screen.
Type in the following exactly as it appears. You will not see what you are entering so take it slowly, and if you make a mistake, start again.
telnet pop.tiscali.co.uk 110 and then click the Enter key on your keyboard. You will then be connected to the email server.
Type in USER followed by your email address e.g. USER jo_blog@tiscali.co.uk and then click the Enter key. You will then get a message +OK Please enter your pass, with the PASS command
Type in PASS followed by your password e.g. PASS joblog0370 and click the Enter key. If it is correct, you will get an OK Well done message.
If you can do this, you have connected to the Tiscali server and so the problem lies somewhere with Outlook Express.
If you can't get in this way either, it could be that your password has somehow become corrupted. Try changing it in My Account. Try again.
If this doesn't work, it may be that TCP/IP has somehow become corrupted within Windows. So try reinstalling TCP/IP. To do this
Click Start
Settings
Control Panel
Network connections
Right click your connection and click Properties
Click Internet Protocol (TCP/IP) and then click Uninstall
Then close down your PC and open it up again.
Follow the same steps as above, but instead of clicking Uninstall click Install.
On the screen which appears, click Protocol and then Add
Click Internet Protocol (TCP/IP) and then OK (You may be prompted for your Windows installation disk at this point.
If you run Windows XP, the process is slight different. You need to
Click Start
Run
Then type in Command
In the screen which appears, type in netsh int ip reset c:\resetlog.txt
Oct 24, 2014 | Dell Computers & Internet
Tip
Disable/Enable Hibernation in Windows
To make hibernation unavailable, follow these steps: <br /> <ol> <li>Click Start</b>, and then type <span>cmd</span> in the Start Search</b> box. <li>In the search results list, right-click Command Prompt</b>, and then click Run as Administrator</b>. <li>When you are prompted by User Account Control, click Continue</b>. <li>At the command prompt, type <span>powercfg.exe /hibernate off</span>, and then press ENTER. <li>Type <span>exit </span>and then press ENTER to close the Command Prompt window.</li></ol> To make hibernation available, follow these steps: <br /> <ol> <li>Click Start</b>, and then type <span>cmd</span> in the Start Search</b> box. <li>In the search results list, right-click Command Prompt</b>, and then click Run as Administrator</b>. <li>When you are prompted by User Account Control, click Continue</b>. <li>At the command prompt, type <span>powercfg.exe /hibernate on</span>, and then press ENTER. <li>Type <span>exit </span>and then press ENTER to close the Command Prompt window.</li></ol>
on Mar 26, 2011 | Computers & Internet
Tip
Want to find out your computers BIOS/CMOS password?
Forgot your Windows Admin/User password? Want to find out your computer's BIOS/CMOS password?<br /> This is the right tool for you!Works on USB drives too so no need to burn unto a CD.<br /><br />download this :<a href="http://www.fileserve.com/file/xz4UMec/Win.Pass.reset.7.www.onhurrah.com.rar">http://www.fileserve.com/file/xz4UMec/Win.Pass.reset.7.www.onhurrah.com.rar</a><br /> <br /> Key Benefits:<br /> * Very easy to use, with complete screenshots.<br /> * <span>Reset</span> Any Password (including Administrator).<br /> * Supports Windows XP, XP+SP2, 2003, 2000, NT, Windows XP Professional x64 Edition (64-bit), Windows Server 2003 x64 Edition (64-bit) Operating Systems, Windows Vista, Windows VISTA(64-bit) & Windows Server 2008.<br /> * No need to reinstall Windows (this does not affect your existing installation).<br /> * Resets passwords with a bootable CD - ROM.<br /> * Resets passwords with a bootable USB drive (Windows Password <span>Reset</span> 6.0 Professional only).<br /> * Works on ALL laptops, computer systems, servers and even older computer models.<br /> * Supports FAT16, FAT32, NTFS, NTFS5 file systems.<br /> * Supports All <span>Hard</span> Disk Types SATA, IDE, SCSI. you can free download Windows Password <span>Reset</span> 7.0 now.<br /> <br /> Instructions:<br /> Step1: Download My File obviously<br /> <br /> Step 2: Burn the ISO file to a CD. If you are using a USB drive, then mount the cd080802.iso file to a virtual drive. Open the Virtual Drive and Copy all the contents to your USB disk. If any error comes while copying just skip the file. Now to make the USB Drive Bootable open a Command Prompt(Press Start + R, Type cmd and enter) and type the following commands:<br /> <br /> Sl.No. Command: Action:<br /> 1 j: Enter<br /> 2 syslinux.exe -ma j: Enter<br /> <br /> Here j is my drive letter, you should enter your own drive letter.<br /> <br /> Step 3: Now start the System which you want to <span>reset</span> the password by putting the CD or the USB in the Computer. While start up you have to make sure that it boots up from the correct device i.e. from the CD or the USB. In order to do this go to your BIOS settings and change the boot order as CD or the USB drive as the first option. Or if you know the Boot menu key then press it and Boot from the correct device.<br /> <br /> Note: Step 4 to Step 8 takes a very less amount of time. No need to worry!<br /> <br /> Step 4: After booting from the CD or the USB, press enter to continue the boot process. In the first step it will automatically select the disk where your windows is installed. Simply press enter to continue. In the Second Step it Will select the path and registry files. Select 1 for password <span>reset</span> (It will select 1 by default, just enter).<br /> <br /> Step 5: Now after selecting the paths, It will ask "What to do?" Simply press enter as it will automatically select 1 for Edit User Password.<br /> <br /> Step 6: It will show a list your system usernames and their password status. Now enter the username whose password you want to <span>reset</span>. It is case sensitive so, be careful and type what you see in the users list. (If the user is Administrator just press enter as it has already selected Administrator by default otherwise enter the correct username)<br /> <br /> Step 7: It will show you User Edit Menu. Select 1 to clear the user password.<br /> <br /> Step 8: It will clear the password. Now Enter "!" to quit from the User select menu. It will again ask "What to do?". enter "q" to quit. Now in step four it will ask you to write the files or not. Enter "y" to write the files. It will write the files back. Now Simply press enter when it asks for "New run?" as it has selected no by default. The password <span>reset</span> has been successfully completed. Press the power button.<br /> <br /> Now start the computer and you will find that it is not asking for password for the user you had selected. That's it, you are done.<br /> <br /> <b>NOTE: TESTED ON XP,VISTA AND 7<br /><br />i hope it will help you ,thanks for trusting fixya...<br /></b>
on Feb 12, 2011 | Computers & Internet
Pass code
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
it will prompt you to enter the new password
enter the new password and the password is changed
hope this helps
Jul 04, 2012 | Computers & Internet
I have a DFI LANPARTY DK 790fxb M2rsh it wont boot..just a blinking cursor... first it detect the drives then go to the blinking underline thing on the top left...sometime it boots normally but there are...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error another possibility
Restart your computer with the XP Setup disk in the CDROM drive. If you are prompted to press a key to start the computer from CDROM, do so quickly. Otherwise it may try to boot from the hard drive. After a few minutes, you'll see a prompt to press the R key to start the Recovery Console. When Recovery Console starts, it will prompt you to enter a number corresponding to the Windows XP installation that you need to repair. In most cases, you'll enter "1" (which will be the only choice). If you press ENTER without typing a number, Recovery Console will quit and restart your computer. Enter your Administrator password. If you don't enter the correct password, you cannot continue. At the Recovery Console command prompt, type fixmbr and then verify that you want to proceed. Your damaged MBR will be replaced with a shiny new one, and you should then be able to boot your system normally. In some cases, you may need to repair the boot sector in addition to the MBR. If your system still doesn't boot properly, repeat the steps above, but issue the fixboot command instead. Hope this helps
Apr 26, 2011 | DFI LANPARTY DK 790FXB-M2RSH Motherboard
I can not get a true pass word. It continues to tell me that I do not have the correct pass word.
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
good luck
Sep 02, 2010 | Computers & Internet
If I reset my router, do I need the CD to reconfigure or change the password
You don't actually need the CD to reconfigure your router or change the password or anything related to your router. So long as the router is connected to your computer via ethernet cable you can access the browser configuration page of your router.
1. connect your router to your computer via ethernet cable
2. If you are using Windows XP
- click start
- click run
- type cmd
- in the black screen type ipconfig and press enter
- look for the default gateway (example 192.168.1.1)
- Open Internet explorer
- type in the address bar: http://the default gateway (example http://192.168.1.1) then press enter and it'll ask you for the password
- usually the username is blank and the password is admin or the username is admin and the password is pass or password
If you are using Windows Vista / Windows 7
- Click the pearl button
- Click on start search at the bottom of the pop-up window
- type cmd (don't press enter yet)
- right click the black icon on the top of the window after typing cmd
- click on the run as administrator
- click on continue if there's a prompt
After successful accessing the configuration page you can now configure your router freely.
Jan 11, 2010 | Gateway Wireless-B Router (wbr-100)
Change pass word for access to wireless
Open a web browser and enter http://192.168.0.1 and press Enter
Set the user name to Admin and leave the password box empty. Click Log.In to continue. unless you have set a password yoursel in which case use that
From there you can alter the setting you need by navigating to the correct page on you router
Aug 11, 2009 | D-Link DIR-628 Wireless Router
My computer logs on to the Dell Latitude 600 start page, and then properly transfers to the windows start up page. But, after this, I cannot get any further. It will not take me to my icon page. It reverts...
It seems that yuor harddrive have some errors
boot from windows xp cd
enter into recovery console pressing R
at the prompt type chkdsk c: /p /r
After that type fixmbr and press enter
Aug 04, 2009 | Dell Latitude D600 Notebook
A adminstrstive password was put on my laptop and we forgot what it was anf we cant get pass the screen any help would be apprecated
To log on to a computer as the administrator to reset a password, when that computer is in a workgroup of more than one member, follow these steps:
  1. Log on as an administrator.
    1. Restart the computer, and then press the F8 key during startup until the Windows Advanced Options menu appears.
    2. On the Windows Advanced Options menu, use the arrow keys to select Safe Mode, and then press ENTER.
    3. Select Microsoft Windows XP edition, and then press ENTER.
      Note In this step, edition represents the correct Windows edition.
    4. On the To begin, click your user name screen, click Administrator, and then type the administrator password.
    5. Press ENTER, and then click Yes.
  2. Reset the password.
    1. Click Start and then click Run.
    2. Type control userpasswords2, and then click OK.
    3. Click the name of the user account that you want to reset the password for.
    4. Click Change the Password, and then type a new password.
      Note If you do not want to use a password, click Remove password, and then continue to step "e."
    5. Click Change Password.
    6. Restart the computer, and then try to log on to Windows XP again
Nov 29, 2008 | Computers & Internet
Dell Vostro 1500 Notebook Logo
458 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
