Question about Funai PY90VG DVD Player/VCR
PY90VG Tape/DVD Turns Off Ny Itself
The unit turns off after about ten seconds. Is this worth repairing?
    President:
  • 2,777 Answers
Unfortunately it is going to cost you more to repair this unit then to just replace it. You can get a new one for $70 shipped here:
http://www.amazon.com/gp/product/B000N42HTK?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B000N42HTK
Posted on Sep 09, 2009
System will not eject video tape and is locked
This unit is confused. The timing may be messed up. Try unplugging the unit for 1/2 hour. This will force a system reset and make the unit go through a complete startup check/reset. This may clear it up. If not, hopefully the symptoms will change slightly. Please post the results of the "reset".
Thanks,
Dan
Nov 03, 2009 | GoVideo DVR4000 DVD Player/VCR
I think we had a power surge. Now my Pye PY90VG vcr/dvd player won't stay on. Can this be repaired?
I am having the same problem. Turn on the machine and it stays on for only 10 seconds and turns back off.
Oct 21, 2009 | Funai PY90VG DVD Player/VCR
Intermitent start up
my friend had a similar problem with a panasonic combo unit it needed resetting what we did was hold the power button on the unit for about ten seconds we had to do it a few times but eventually it reset itself then went into standby mode its worth a try hope this helps regards JIm
Apr 29, 2009 | Panasonic DMR-E85H DVD Recorder
Pye py90vg VCR will not play
There are 2 problems. On the botton of the machine you should replace the rubber drive belts. And on the top of the machine under the cover there is an idler wheel with a rubber wheel on it. that shoul be replaced too. Caution If you are doing this yourself please have the power cord disconnected. If you do not have the parts. It would probably be cheaper to buy a new unit, depending on the model. Because if the belts are worn then it is time for a complete service.
Dec 13, 2008 | Funai PY90VG DVD Player/VCR
Defect
Tarlach.
I had similar trouble & searched web & found answer. Caused by PSU (power supply unit) overheating. IC STR-G6353 was problem. Panasonic repair agent wanted $60 Aust. for one but found in electronic spare parts shop & cost $11 Aust. I replaced it myself & now works like new. Pls go to web site
http://www.avforums.com/forums/showthread.php?t=316972&page=9
This will show the problem & how to fix. regards
jhcollister@bigpond.com
May 05, 2008 | Panasonic DMR-E85H DVD Recorder
TV wont stay on
The vcr carriage was probably damaged ( broken gear or carriage gear, etc ), As for repairing it, it may not be worth it and chances are, you won't find a new carriage for the unit. I have, in the past, disarmed the VCR unit and at least the customer could watch the TV. Thats not possible in every set, but it seems to work in the majority of them. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 22, 2007 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
VCR WILL NOT PLAY
The problem is the tape mechanism is malfuctioning. It trys eather to load or play a tape and a sensor inside tells the microprocessor to shut down this mechanism before damage is done to the tape. BUT sometimes a malfunction causes a damaged tape too. this unit has NO user serviseable parts inside itself, so its time to take this puppy into a repair shop to see if its worth the repair , Unless this units more then a few years old?? then its time to buy a shiny new unit. Good luck
Jul 09, 2006 | Emerson EWD2203 DVD Player/VCR
Funai PY90VG DVD Player/VCR Logo
181 people viewed this question
Top Funai Televison & Video Experts
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
