Question about InFocus IN72 Multimedia Projector
Power not working
I started using hdmi cable and next day my projector wotn start.. when i hit the power button it was on but the light dissappeared and it wont start.. could this be a fuse problem.. ?
  • Brad Collier Jan 06, 2008
    I was watching TV and the projector powered off and will not power back up.
  • TuskenRayder May 11, 2010
    When did you purchase your IN72? Earlier models usually need a fuse replacement. Mine blew 10 days before the warranty expired, so I was lucky. Unfortunately, this is a repair that can only be performed by returning it to Infocus.
I have an infocus lp70+ it turns on and displays an image for about 2 seconds even if you push the menu button, then the bulb powers off and it acts like it overheated. It does this when it is clearly not overheating. Please help me, I can be emailed at trendkillaffxi@yahoo.com.
Posted on Apr 08, 2008
Forget about sending to InFocus. It's 400 to fix. The fuse is easy to replace. It is on the middle board under the metal heat sink. They are hard wired in (soldered) and require a soldering iron to fix. Most people just wire in a radio shack replacement fuse holder with a 2 amp fuse. The problem of the blowing fuse seems to be more prominent when the projector is inverted (upside down).
Posted on Mar 12, 2008
My IN72 stopped working today, anyone now how to locate the fuse?
Posted on Feb 26, 2008
  • 167 Answers
Whatever kind of fuse you have try looking for one at radioshack? or send it to infocus
Posted on Jan 27, 2008
Hdmi input issue - screen goes black after 20 minutes of use
Could be a defective HDMI processor word of warning to everyone never under any circumstances must you connect up any device with HDMI ability whilst they are switched on as static can and indeed does smack out the HDMI processor and can and does work out expensive in time to replace.
john
www.jvsvisual.com
Apr 16, 2013 | InFocus IN72 Multimedia Projector
How can I connect PS3 to ACER X110P Projector
does the projector have an HDMI port?
i would buy the cable that is HDMI from the PS3 (unless it has HDMI already)
HDMI converter (HDMI to DVI or VGA) typically don't work well because you are changing the signal from digital to analog through a cable. you want to use a cable that is the same on both ends.
Nov 09, 2012 | Acer Computers & Internet
Epson PowerLite 410W projector (used for a smart board in a classroom) won't project anything or even turn on. Power button (maybe lamp indicator light? I don't really know anything about this...)...
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Sep 23, 2011 | Epson PowerLite 410W LCD Projector
Projector powers up as normal, bulb comes on, displays Optoma logo on screen and menu will show on screen. The issue is that although I have 3 devices plugged into the HDMI port of the device using a HDMI...
There is a source lock and source button I would unlock source lock button and the push source button until you get to your hdmi input you are using. You also may just plug in one input first and once you get the input right play with the multiple hdmis
Aug 11, 2011 | Optoma HD20 DLP Projector
How to you connect PS3 to to model 37PD5000
Good day!!!
Please try this procedure to connect the PS3 to TV..
The PS3 has a Blu-ray drive that can be used not only for playing games but also for watching high-definition movies. The best way to connect a PS3 to a high-definition viewing device such as a video projector is through the PS3's high-definition multimedia interface (HDMI) output. The HDMI connection can transmit up to 1080p high-definition from the PS3 to the video projector using a single cable. Attaching and setting up the HDMI cable will only take a few minutes and will let you watch high-definition video from the PS3 on the video projector.
  1. Connecting HDMI
    • Attach one end of the HDMI cable to the HDMI output connector of the PS3. Turn the HDMI cable around if it does not slip right into the HDMI output, because the HDMI cable can only fit into an HDMI connector one way.
      Attach the other end of the HDMI cable to the HDMI input connector that is on the video projector. Make sure both sides of the HDMI cable is securely pushed into the connectors of the PS3 and of the video projector. Turn on the video projector. Press the "Menu" button on the video projector's remote. Navigate to the "Sources" setting on the video projector's Menu. Select "HDMI" from the "Sources" setting. Press the "Menu" button on the remote control again to exit the Menu.
    Adjusting the PS3
    • Turn on the PS3. Wait for the "Home" menu to appear on the video projector, although the quality of the video seen from the video projector will be muddied and dark. Navigate from the "Home" menu to the "Systems" icon using the game controller and select the "Display Settings" tab. Choose "Video Output Settings" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the next screen.
      Choose "HDMI" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the next screen. Choose "Automatic" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the "Confirmation" screen. Press the "X" button on the game controller to make the settings active. Return to the PS3's "Home" menu.
    Watching the PS3
    • Insert a Blu-ray disc into the slot at the front of the PS3. Wait as the Blu-ray disc begins to play the video content on the video projector from the PS3 through the HDMI cable.
Please don't forget to rate my answer...I really appreciate any ratings you done..
Thanks for using fixya..
Jul 16, 2011 | Hitachi 37PD5000 Television
Panasonic PT-AE900E Projector not working???
I have this exact problem too, so anyone out there that can help it would be great!
Mar 03, 2010 | Panasonic PT-AE900U Multimedia Projector
Infocus X2 projector
resolution changes. if you hit auto image, that should correct it.
Sep 03, 2009 | Compaq MP2800 Microportable Projector sps...
Infocus lp600 not working
HI-
MAke sure that cables are properly connected, it might be that it is not getting any signal from the source.
Hope this helps
Oct 28, 2008 | InFocus LP 600 Multimedia Projector
Wont turn on
I don't think the outlet you are plugging it into has enough power to support the ps3. Try plugging it into a different outlet and see if it works.
Dec 17, 2007 | Sony Playstation 3 (PS3) Console
Projector won't power up
my Hitachi CP-S210 Multimedia Projector
will not power up at all.
Power sorce is good. Turned off last night, but will not do anything today. HELP
Sep 06, 2007 | CTX Optoma EzPro 610H Multimedia Projector
InFocus IN72 Multimedia Projector Logo
370 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
