Question about Canon PIXMA MP600 all-In-One InkJet Printer
Canon PIXMA MP600 printer. What should be a blue image is turning out "pink". I have followed all the checks, and get a message "nozzels not blocked no need to clean" What else can I check? Ron Knights
    President:
  • 1,653 Answers
Try printing a full colour test chart Get the following and print them out, compare to what you see on screen. This will tell you which carts are working or not working.
You might need to run a cleaning cart through the printer. Are you using compatible carts or originals and if they are compatibles have you used them before? You may also have a problem with the print head.
http://www.hutchcolor.com/Targets_&_images_to_go/P2P_Package.zip
http://www.hutchcolor.com/Targets_&_images_to_go/RGB_Curve_Guide.zip
Both of these are royalty free and can be used over and over.
Posted on Sep 09, 2009
SHOWS MESSAGE DEVICE NOT COMPATIBLE
It seems that your printer cartridge is not proper for for MP600 or cartridge is not properly installed or it's installed to wrong position. Check manual the right positions for each cartridge and right codes for each cartridge. You can load manuals here http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#BrochuresAndManuals
Jun 27, 2014 | Canon PIXMA MP600 all-In-One InkJet...
My MP600 will not print documents. It will print a scanned document i.e. scan the doc and print from the image. It will print a webpage. It will print a copy it makes but it is blue instead of black....
If colours are faded I would recommend running several cleaning/deep cleaning cycles to try and pull through the colours. It is difficult to say without seeing the print quality, but it sounds like an issue with a partially blocked printhead within the printer.
The printing in blue would suggest to me that one of the blacks in your printer is blocked. Were all 5 colours present on the nozzle check?
Jul 31, 2013 | Canon PIXMA MP600 all-In-One InkJet...
CANON PIXMA MP520 NOT PRINTING BLUE
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Nov 27, 2012 | Canon PIXMA MP520 InkJet Printer
How can I reset canon Pixma MP600 error code 5B01 please?
pull out your ink carg and on your printer and then put back the cag and use your printer its work aone
Mar 15, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Printing problem with my canon pixma mp630
Run the alignment test page from the software on your computer and check and adjust the alignment.
Dec 30, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Pixma IP5000 printing pink
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Mp600
if you remove the transformer block ( the one in witch you insert the power cord... is secured with two plastic restrains ) you may see a small electric drive... engine name it as you wish with two blue wires ..
those two blue wires are the positive power coupeling on it ... if they are removed you get error 6000. The removal of the two blue wires may occur when moving the printer or if you remove the transformer block from the printer. put them back to the electric engine, and you will resolve the canon mp600 6000 error and possible other serie two ( the error is standard for most MP series and even IP). Be shure to unwind the blue wires around the small ring or else the wires will pop off the couppeling when you put the transformer block back. It is a pain in the back to recoupple the blue wires into the elctric drive but it can be donr without opening the whole printer(witch is a huge pain in youre back side).
I reffer to the transformer block as the ac\dc block witch feeds power to the printer. For any problems adress me at alexmi88@yahoo.com
Dec 19, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Mp600
i would try and do a deep clean. and then proform a nozzel check and see if you can anything from there. if not you might want to try to blow through the inks with the head and see if any ink comes out the bottom of the head but it can get messy if you dont do it right.
It sounds like it just needs a good purge, is it all colours or just 1!?
Oct 18, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Scangear - scanning problems with mp600
windows XP instructions.can be easily applied to other operating systems
-turn printer/scanner on
-go to control panel
-click on system
-click on hardware
-click on device manager
-click on imaging devices
-right click on canon mp600 and choose updat driver option and then after that is done.click on scan for hardware changes
(below images provided)
this should make sure scanner work.. but if it still doesnt work then go back to the device manager and check if there are any hradwares with a yellow question mark beside them.if there is then right click on them and click update driver.
if that does not solve the problem try reinstalling the CD or go to the canon MP00 web page (google it) to dowmload the printer/scanner drivers. and repeat everything until it works or until you give up =). hope it all works out bye!
Apr 02, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Lost of cd install
Here is the link:
http://driverscollection.com/?H=PIXMA%20MP600&By=Canon
In the middle of the page, click on your operating system in the blue font. Then you want to click on the "view and download Canon PIXMA MP600 Easy Photo Print Driver" in blue in the middle of the page. Enter the validation code in the middle/bottom of the page and click on download file. It should start automatically. Hope this helps!
Nov 08, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
74 people viewed this question
old marine
old marine
