Question about RCA DCW615R Wireless/Cable Modem
How do i set up a wpa or wep on my modem
Well its self explanatory
  • 25 Answers
1.) Well first, you must open your web browser up.
2.) Then you would type in the address bar: 192.168.0.1 (being the default ip address for this modem)
3.) If you haven't changed it already, the username is <blank>, and the password is, "admin".
4.) Once logged on, you would go to the far top right, where it says: "Wireless".
5.) Then, on the column on the left hand side (about mid-page) you can see five different tabs, click on the one thats says: "Privacy".
6.) Now, this is where you have to decide what kind of Security you would want(either a 64-bit or a 128-bit encryption key) NOTE: having 128-bit encryption key will be a long password.
7.) Then, in the WEP Passphrase, you would type in something that you would remember, it could be anything, just as long as you can remember it.
8.) Then click the "Generate WEP Keys" button right next to it.
9.) Now, on the Default Key right under it, it gives you choice of 1-4. This means which channel would you like to connect though. So here is an example, if you picked a128-bit encryption kep with a default key of 3, then you would look at the corresponding chart at the bottom of the page. And at the row that says "Key 3" in the "128-Bit" box, then that would be your password for other devices to connect to this modem.
10.) And when you have saved you password somewhere, click "Apply", and you done!
Posted on Dec 26, 2007
Wirless works for the netwoek but cannont connect laptops or i pods. they pick up the router but every password showing on the set up pages denies access
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Mar 16, 2011 | Zoom X6 (5590) DSL Modem (55900003)
What is a security key
WPA (Wi-Fi Protected Access) is an advancement over WEP (Wired Equivalent Privacy). While connecting to a home network, you are often asked to insert a WPA key or a password to which users often ask, "How Do I Find My Computer's WPA Key?" WPA stands for Wi-Fi Protected Access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over(Wired Equivalent Privacy) Wep is standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
While connecting to your home network, you are often asked to insert a WPA key. This WPA key is either located in the modem or in the router you are using. In order to find your computer's WPA key, follow the steps given below:
How to find your computer's WPA key Step 1: First of all, you need to launch an internet browser. Press "Windows + R" keys to open the "Run" prompt and type "iexplore" without quotes to open Internet Explorer. You can also type "firefox" to open Mozilla Firefox. On the address bar at the top, type http://192.168.1.1 (Belkin routers use 192.168.2.1 as the default IP) and press "Enter" key.
This address belongs to your wireless modem or wireless router to which you are connected.
Step 2: A window asking for username and password will appear. In the username field, type "admin" without quotes and in the password field, either type "password" without quotes or leave the password field blank. Press "Enter" key to continue.
If password is correct, you will be redirected to the modem/router's "Settings" page, otherwise, you will have to reset the modem/router. Check beneath the modem/router or check the manual for correct password.
To Reset a modem/router, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
Repeat the step 2, in order to gain access to "Settings" page.
Step 3: On the modem/router's "Settings" page, find "Wireless" option. Click the "Wireless" link to populate the wireless settings. Now, locate and click the "Security" or "Advanced Security" option.
On the security page, you will find "Network Authentication". Different options available under the Network Authentication menu are open, shared, WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, etc. Select either WPA or WPA2, to find your computer's WPA key and insert this key when asked for.
If in step 2, you had reset the modem/router, you will not find any WPA or WPA2 key, and you will have to manually assign one. Select any of the WPA-PSK or any other authentication and assign a key to it. A key can be 8-63 long. For minimal security, you can choose 8 characters key, like "iN\/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBD\m+oMp$nrXj5XPVRTvVA5fpwGSGI\RVz4RdQ7V3y\l$P1NrT9Be".
After you have assigned a key, save/apply the changes and reboot the modem/router.
Note: The procedure shown above is common to most of the modems/routers. If this doesn't apply to you, check your modem/router's manual to find the wireless security option.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Jan 20, 2011 | Buffalo Technology AirStation Nfiniti...
Where is the wep for it
hi
You can find the WEP or WPA Key settings for your router under the "Wireless" or "Wireless Security" sections in your router settings on your PC. Security must be set to WEP key not to any other type of security setting in order for you to have access to WEP Key information
Jan 09, 2011 | Arris SURFboard® SB5101 Cable Modem
I am trying to set up my wireless internet to my PS3. What do I choose WEP or WPA - PSK under WLan secutiry and how do I know the codes?
Wireless internet is provided with a wireless router. The router will be what you set up for the WEP or WPA codes.
Jan 02, 2011 | Arris SURFboard SB5101 Cable Modem
How do i connect to internet with ps3, wireless, what is a wpa key?
WPA stands for Wi-Fi protected access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over WEP (Wired Equivalent Privacy) standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
You can correct this problem by entering the WPA Key into your PSP's Network Settings. But before you do that you need to know what your WPA Key is...
To reset a Linksys modem/router or Belkin one, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
For minimal security, you can choose 8 characters key, like "iN/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBDm+oMp$nrXj5XPVRTvVA5fpwGSGIRVz4RdQ7V3yl$P1NrT9Be".
Jan 02, 2011 | Video Game Consoles & Games
When i connect i get this message' your wpa key you entered may not be correct"
Jan 01, 2011 | Sony PlayStation Portable (PSP) Console
I have a wii so im trying to get this wpa code to get internet acess and i cant find it
try this trouble shooting guide. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Aug 15, 2010 | Arris Touchstone 450a (CM450) Modem
It wont let me connect to wii internet
here try the trouble shooting guide. Please try the
Aug 09, 2010 | Arris SURFboard SB4200 Modem
Limited connectivity
Hi Duneider!
It's normal that your computers will not connect after you enable a wireless security (WEP/WPA). You are getting a limited or no connectivity message because the wireless computers are not connected to the network using the network key or the password that you have used to setup WEP or WPA. There is no need in hard conding the IP address, all you need to do is reconnect to the wireless network using the WEP or WPA Key. If you will type the correct WEP or WPA Key, it will connect and automatically get the IP address again from your router.
May 08, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Can't get connected to the internet!
you have to be sure your modem is wirless if it comes up in scan then your good maybe your modem doesnt need a wep key it all depends on your modem
Jan 01, 2008 | Sony PlayStation Portable (PSP) Console
RCA DCW615R Wireless/Cable Modem Logo
167 people viewed this question
Top RCA Computers & Internet Experts
Rommel Balcita
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
