Muratec 2830 drum cartridge problem.
I have a Muratec MFX 2830. Even with a new cartridge, it says replace drum cartridge. Is there a way to reset the counter or is there a sensor bad. It will let me fax and get a printed confirmation but it will not let me cpopy or print. The alarm light is lit but I don't know if its because of this or something else and I don't know how to check the alarm.
Any help is welcomed and apreciated.
    President:
  • 1,187 Answers
The drum cartridge is different from the toner cartridge. The drum has reached its life cycle and must be replaced. This is normal for any copier of that class.
The drum is not too expensive and not difficult to replace.
Hope this helps!
Posted on Sep 09, 2009
Error code when we replaced our Drum Unit for the 2830
You should reset drum error code.Please contact any service authorized this copier
Jul 13, 2012 | Muratec MFX-2830 Black and White Copier
Replace drum
Yes this indicator comes on approx. every 84,000 pages of print.
The Drum cartridge is "fused" and it will have to be replaced as the machine will eventually stop printing.
When the new drum cartridge is installed, the light will be re-set and you will be good for another ( approx. 84,000 pages.)
You will have to contact a local Muratec dealer to either get the drum cartridge or have them replace it.
Nov 02, 2010 | Muratec MFX-2830 Black and White Copier
Muratec MFX-2830 with call service :0C
0C means you have a cooling fan problem. Located behind the lower rear cover in the lower right hand corner of the machine. Either the filter has gotten caught in the fan "OR" the fan itself has gone faulty..."it is also a signal generator." So...check for the filter caught; or the fan may have to be replaced.
Aug 09, 2010 | Muratec MFX-2830 Black and White Copier
Muratec mfx 1300>> CAN I reset A "replace
YES....try the following...... Press PROGRAM,*,*,I(thats capital letter i) then press ENTER.
SHOULD RESET IT.
Jun 16, 2010 | Muratec - MFX-1300 Copier
MFX-2830 Black and White Copier: How do you replace a staple cartridge on a Muratec...
Open front door of the Finisher Unit. Over to the left beside the 2 green knobs you will see the Staple Cartridge. Pull slightly down and out and the cartridge will come out. A new cartridge has to be installed...they cannot be re-filled.
May 17, 2010 | Muratec MFX-2830 Black and White Copier
I replaced the drum in the fax machine and it still say i have only 14 copys left, how do i reset that? I have muratec fax MFX 1700
You are not supposed to replace the drum until it says"replace drum"
Not when it is saying "replace drum soon."...you have prematurely blown fuse in the cartridge so now it will not reset.
Try the following...
Press...PROGRAM,*,*,I(That is Capital I), then ENTER.(SHOULD RESET IT.)
Nov 16, 2009 | Muratec MFX-1700 Fax
Reset drum counter on a muratec mfx 1430
Drum counter is reset by installation of a "NEW" drum.
There is a small fuse at the rear of the drum on the top( you will see the 2 brass contacts) When a new drum is installed, the fuse blows and resets the drum counter. Installing a used drum will not reset the counter as the fuse is already blown.
Sep 15, 2009 | Muratec MFX-1430 Copier
Scanning a photo
Most Muratecs now a days do scan in color. The 2850 is one such model. So to answer your question you are incorrect.
Jan 16, 2009 | Muratec MFX-2830 Black and White Copier
How do I reset the drum counter on a Muratec F320?
Ok, this is how I resolved it for my fax machine.
I powered down the fax, removed the new drum and reseated it.
When I powered it back on the counter reset itself as it is supposed to.
Nov 12, 2008 | Muratec F320 Plain Paper LED Fax
MFX -2380 (Muratec) issue with net work printing
In network environments the muratec's usually have to have the setup disk run. They do not work on the standard TCP/IP port. The disk creates a muratec port for the pc to print to.
Jul 21, 2008 | Muratec MFX-2830 Black and White Copier
290 people viewed this question
jasbo
jasbo
