Question about Poulan Oregon Chainsaw Chain For Chainsaw 16" Bar Length 60 Drive Links 3/8 Standard 0.05 Gauge Chiesel Chain
What are the carberator settings for Poulan Predator chainsaw model 2150 PR LE?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
Follow this link and you will be able to adjust your carberator:
http://www.zamacarb.com/tipspage.html
Posted on Sep 09, 2009
Chainsaw won't idle- runs fast only
Gently Tighten the carb adjustment screw fully tight then adjust it out 360 (full turn) then again a further 180 ( half a turn) and your idle speed should be set correctly. Let me know how you get on
Oct 02, 2014 | Oregon Poulan/Poulan Pro 10" Chain Saw...
How to change/ Replace Poulan 2150 chainsaw primer bulb
I have attached a video on chainsaw primer bulb replacement from YouTube. There are many great videos about chainsaws on YouTube.
I hope this helps.
http://www.youtube.com/watch?v=sNj2oO9L9ic
Jul 01, 2014 | Poulan 2150 Chainsaws
Poulan 2.1 cu #2150 what is the correct model number? it is a chain saw
On your label you should see the number 2150 plus a type number. There might be another part to the name, such as Predator or PR. You need the entire model to be able to find parts.
Here is the customer service number should you label not be readable or you still can't find it: 1.800.554.6723
or email at www.poulan.com customer service option.
If you find the model and need parts, here is a web address for Milaca Lawn and Garden:http://www.milacalawn.com/parts.asp
They provide parts schematics and fast delivery.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 29, 2011 | Poulan PP4218AV 18" Chain Saw
How do you re assembly brake handle poulan 2150
Hello Larsens;
A Poulan "2150 Predator Gas Type 6" IPL follows (may not be your saw)(the LE suffix is a Wood Shark) http://www.ordertree.com/modelinfo/PWE/2150-Predator-Gas-Saw-Type-6/75.2150-Predator-Gas-Saw-Type-6.1.59.1.html
There is no breakdown, they want you to order a new cover $20±. The cover appears on different print names with different models (Handle & External Assembly) above.
Poulan.com (all)
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Do you have a friend with a cover you can look at? The brake will need to be lached open (enlarged) to refit the clutch cover on your saw.
Detail A here is a good representation of a Husky chain brake, they are all similar and this may be helpful.
http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601077.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 24, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I NEED A DIAGRAM OF THE FUEL LINE TO THE CARBURETOR FOR A POULAN PREDATOR SERIAL#03296D300154-6 MODEL#2150PR
What you request doesn't exist. An IPL containing fuel system parts with very little detail can be found here:
Poulan.com
The fuel system parts can be found on the "Engine Assembly" and "Handle & External Assembly" illustrations.
e17de8d.gif Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
HTH
Lou
The serial number you provided allowed me to find the correct IPL for your saw Type 6 (-6 from serial number). Thank You.
If you feel Poulan should provide better illustrations please contact them here: http://www.poulanpro.com/node4033.aspx There is a toll free telephone at the bottom of the page.
If you contact them and aren't satisfied with their reply, please elevate your concern to their parent company (Husqvarna) here:
http://www.husqvarna.com/us/homeowner/support/customer-support/
Oct 29, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I need the fuel line routing or diagram for a Poulan Predator 2150 LE. I have parts list but it does not depict the fuel detail I need.
Jimmy there are no Poulan drawings with fuel system detail worth the ink it takes to print them, but that is all there is.
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb (once compressed bulb draws fuel as it returns to normal) , bulb (as it is compressed) returns displaced to fuel tank. HTH
Lou
Oct 22, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Need a manual for a poulan 2150pr le predator 16" '
Arboristsite dot com, "Chainsaw" forum, "The beg for manuals thread". Do a search for your saw. Lou
Aug 27, 2009 | Garden
Need a diagram of the fuel lines on a poulan 2150. what lines go where?
You can View a Diagram of the Chainsaw here http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP⟨=EN&TF=Mainfram...
Select the Catalog Poulan/Weed Eater. Then Select Poulan. Then Select Gas. Then Select Saw. Then Scroll Down to your Model Saw i.e 2150.
Regards
Marc
Apr 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Oregon Chainsaw Chain For  Chainsaw 16" Bar Length 60 Drive Links 3/8 Standard 0.05 Gauge Chiesel Chain Logo
296 people viewed this question
Top Poulan Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Poulan Measuring Tool and Sensor Expert? Answer questions, earn points and help others
