Question about Zebra LP 2844 Thermal Printer
Zebra LP 2824
Printer staying orange and not printing . Have wiped the inside with barely damp cloth, changed to new role of tags, unplugged power, when I try to print, it will go green for a second then right to orange. Periodically it will go green enough to spit out a few tags.
Lp 2824 plus won't print. Have windows 7 till switch off and on again
printer driver conflict or windows 7 driver incompatibility. contact zebra for proper driver installation.
Oct 21, 2014 | Zebra LP 2824 Plus Label Printer
My zebra lp2824 barcode printer does not print, i downloaded zebra lp 2824 from nice label still it not working, when doing print test it will print only some letters....what to do
check the driver, and the setings from the driver. Try ZDesign Driver or seggul driver from WWW.seaguscientific.com, and print the testpage, chech the connection (port) if is seria (com) check the setings speed etc...
Nov 09, 2010 | Zebra Eltron LP 2824 Thermal Printer
Tags cannot be printed properly in QB POS Version 8. Printer Argox OS 214-TS
The tag printer used by Qb POS is the Zebra LP 2824.
The argox is not compatible.
Jul 04, 2010 | Intuit Quickbooks POS Tag Printer PC...
Just one of the double tags is printed on
I assume by double tags you mean 2 labels across the roll.
You need to tell your software that the roll is 2 across.
If using the software that comes with the printer, Zebra designer.
Set your label width to twice the single label and copy the barcode so that you have 2 across the label, then print
Feb 10, 2010 | Zebra Eltron TLP 2844 Thermal Label...
Zebra lp 2824 faded printing
Many factors affect print quality: Heat settings, speed setting and label face stock quality and type are a great place to start. How old is your printer? How many labels have been printed through it (there is an odometer that tells your this on the config label). Is the printhead dirty? Use > 90% isopropyl alcohol on a cotton ball or microfiber cloth to gently clean the printhead.
I would start by checking the heat and speed settings in the driver - crank up the darkness and crank down the speed a notch or two at a time until you get the print quality that you are looking for. If all of this fails, you may need a new printhead (not too easy to replace on this model). Printheads are made up of an array of resistors. These can loose their electrical resistance over time and require more energy (controlled by the darkness setting) to get the same results as a new printer. Printheads, like labels and car tires are considered a consumable commodity.
Jan 14, 2010 | Zebra Eltron LP 2824 Thermal Printer
Labeller not printing in black - appears to be white
possible the ribbon is on the outher way.
The darkness is to low.
Dec 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
Prints half of label
Restart your computer. Turn your printer off and back on again. Restart your software for printing lables. When updating the printer drivers, all software needs to be restarted to make sure that the form controls are working properly.
Oct 06, 2008 | Zebra Eltron LP 2824 Thermal Printer
TLP 2824 don't print
Only one suggestion, do a memory dump, switch off the power switch (should be back corner of printer) , hold down the green feed button, power on and watch the feed button, take Your finger off it after the third flash.
Leave it for a moment and press once more, it might say something on the label like out of dump. Try a label again.
Do this two or three times if it still acts up.
After this all thats really left is to clean it with an alcohol swap or check settings in the program You're using
Some times they cant store the amount of print jobs being sent to them and the zebra just freezes up or spits out labels
Apr 08, 2008 | Zebra Eltron LP 2824 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
100 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
