Question about HP Photosmart 3210 Printer
My photosmart 3210a will not scan or copy but it will print
  • gerand177 May 11, 2010
    Here is some great PRINTER solution by Some FIXYA EXPERT.
    Get any kinds of PRINTER solution from bellow.
    » Brother Printer Solution
    » Canon Printer Solution
    » Epson Printer Solution
    » HP Printer Solution
    » Lexmark Printer Solution
    » Xerox Printer Solution
    » Other Printer Solution
    6
Why won't my HP Photosmart 5510 copy?
first you confirm scanning is working or not if it is working fine there is no issue with printer, if it is not working problem found with scanner assay you need to contact hp service center....
May 04, 2014 | HP Photosmart 5510 Wireless e-All-in-One...
I can not scan from my HP Photosmart C7180 All in one. Mac OSX 10.6.8 I can copy, print but not scan.
Launch the OSX system preferences, click on the Print & Scan Icon located in the Hardware row, select your printer in the left hand column, click the Scan button above the right hand box, click on the Open Scanner button, a new window will open, click on the scan button in the upper right hand corner of that new window, set your document on the flat glass panel of your multi function printer/scanner, and click the scan button located in the lower right hand corner of the window, once scanning is complete, your document image should appear in a new window and save the image from there.
Dec 22, 2013 | HP Photosmart C7180 All-in-one Printer Fax...
Copying and scanning don't work but produce all-black image
please clean the scanning glass and also the feeder.
Open the machine check if any paper has struck anywhere inside.
In most of issues it will work, if this does not works call your technician to troubleshoot the problem
Jan 13, 2010 | HP Photosmart C7280 Printer
Won't print! it scans photos but it won't print
as it is not printing u can try making copies . if it copies fine that means the issue is with software but if it is not copying properly that means the problem is with hardware. u can try with uninstalling the software and reinstalling it .
Oct 06, 2009 | HP Photosmart C6280 Printer
Duplex copying on HP Photosmart C8280 All-in-One Can't see how to do two-sided copy apart from scanning both sides and printing two-sided! Old HP printer could do 1-1 1-2 2-1 2-2 etc.
Open HP Solution Center, click on Settings, click on Scan Preferences, select "Scan both sides of original when using duplex feeder."
or
Open Solution Center, click on Scan Document, and you should have a check box towards the bottom of the window which would say 'scan both sides of the original document'. check that box and start scanning.
Jul 22, 2009 | HP Photosmart C7280 Laser Printer
Hp photosmart c6180 all in one printer will not scan or copy
The scanner bulbs ahve gone bad.U need to get it them replaced.Before that try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
see if it works.
Mar 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
Yellow band when coping & scanning
this is problem with your scanner it is good if you can get servicing of your all in one printer
Sep 22, 2007 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart 3210 Printer Logo
96 people viewed this question
Seeker5211
Seeker5211
