Marantz 7t an ac buz suddenly occurred on channel b. how do i find it with only a multimeter?
  • pedersen Jan 13, 2008
    As suddenly as the buzz occured, it disappeared, but I'll take any advice so that when it reoccures I will be prepared. the volume control afftects the buzz level so the problem is before it. I have interchanged leads, etc. and it is definitely inside the preamp. I am thinking a loose coax grounding on one of the input cables, but have not opened it up yet. The multimeter pamphlet says it has recolution down to 200 mV. Is this enought to detect the buzz? I do have the schematic.
    While I do have you, the expert online, our model 15 Solid State amplifier has one bad channel. The local repair place says it is the output transistor, but is having a hard time finding a replacement. The Marantz schematic only gives the Marantz part # and they do not support the product anymore and do not have parts or information. Is there a cross reference guide somewhere of Marantz and manufacture parts #? Any other ideas would be helpful.
    Again, thank you.
  • drobertson17 May 13, 2009
    I am also trying to find a suitable replacement output transistor for the Marantz Model 15 amp. I have a service manual but it only lists the Marantz part numbers (DTM13 and DTM14). They are TO-3 type transistors. It also gives a voltage chart for base, emitter and collector.
    DTM13 = Base -42v Emitter -42v Collector -0.8v
    DTM14 = Base +42v Emitter +42v Collector +0.8v
    Does anyone know the cross reference for these devices?
  • 1,512 Answers
You could try to find the problem with a multimeter.... but i suggest perhaps some experience on vintage amps would be required also. ;) This old girl is a sought after collectable classic these days. I would first check that all connections to and from the preamp are ok by interchanging leads. If this does not point to the problem, is it independant of the vol control or not. I will need to ask a few more questions to help you from here
Posted on Jan 11, 2008
  • Graeme Ross
    Graeme Ross Jan 13, 2008
    It is likely that you have an earthing problem in the preamp ascociated with corrosion of eareth connections. Taking the lid off and carefully seeking this with a mechanical approoach(gentle tapping) may help you to find it. Original parts ar rare for this model (and vintage) but not unobtainable. Check out the links below for details of this guys approach to service and repair... taking note of the age related failures that can occur...particularly resistors and capacitors going out of spec. Rebuilding can often be the best approach to repairs for these old girls. I reccomend it if you can afford it! They carry value as collectables, and will always do so. I am in Australia, and am glad to help you with the work to be done if you are down under. The links I have given you are for a Chicago Tech that offers specialist service on your amps. Good luck. A "Fixya" rating would help my profile for my time spent to get you to this point:) Good luck mate!
How do I connect a Marantz av8801 to a Marantz sr7009
The 8801 is an 11.2 channel AV preamp/processor. The SR7009 is a 9.2 channel receiver that includes both preamp and amplifiers.
The 8801 handles an amazing 11 channels of audio, but you can only use the SR7009 for 7.1 input channels. (Does anyone really need 11?) Unless you have some extremely demanding audio requirements, you would probably just want to use the SR7009 by itself. You can't fully utilized the 8801 as a front end (pre/pro) so I'm not aware of any benefits to connecting the two of these together.
Feb 22, 2015 | Marantz AV8801 - Flagship AV Preamplifier"
How do I connect CD player to marantz NR1504 with phono leads
Connect the cd audio out to the line in or cd in on the marantz
Nov 25, 2014 | Marantz NR1504 5.1-channel Home Theater...
Odysseyware answer key
Just carry out the indicated additions and subtractions.
5t+t-7t+3t = 2t
-3-5+8 = 0
The result is 2t+0 or simply 2t
Feb 28, 2014 | Office Equipment & Supplies
Can i hook up 4 8ohm speakers to my marantz 2252b
You can but you will have to put two speakers on the main L/R and two speakers on the remote L/R. DO NOT HOOK UP MORE THAN ONE SPEAKER TO A CHANNEL. Doing so can result in the amp running hot and damage will occur.
Oct 25, 2012 | Marantz Vintage 2252 B Stereo Receiver...
I want to connect my bravia lcd to my marantz sr770 i can only get two chanel sound from my two front spearker i cant get the surround working
Let's break this into little pieces. Disregarding the TV, does the Marantz otherwise provide multichannel sound?
How is the TV-related audio getting into the Marantz? Analog RCA yields only 2-channel audio.
Two front speakers are only capable of two channel sound.
Jan 24, 2011 | Marantz SR-770
I have a Marantz PM-66SE Ki amp which appears to have a problem with one of the channels which is only outputing about 10% of the volume of the other channel. Have tried swapping speakers and cables around...
I have exactly this same problem with my Marantz PM60100SE - one of the channels seems to have lost power and is much much quieter than the other one.
Did you find a solution to this? Anyone have any ideas?
May 20, 2010 | Audio Players & Recorders
PMD660 Handheld Digital Voice Recorder: I have a Marantz PMD 660 digital audio recorder. T...
This implies that there is not enough current going to the device when running on battery (only back-light but no data) whereas running fine on AC means that the device board is most likely in a good operational condition.
I think maybe once a leaked worn battery which left forgotten inside battery compartment damaged the battery terminals or at least the wires connecting these terminals to the main board, i would recommend you to open and check on that.
Sep 23, 2017 | Marantz PMD660 Digital Voice Recorder
PM7200 cannot turnon
Pull cover check for fuses on the bord and replace with exact rating on the fuse.
Nov 18, 2007 | Marantz PM7200 2-Channel Amplifier
No output from left channel after crackling sound
Marantz SR 5200/6200 lost audio or crackling on left or right channel except in mode s-direct is now fixed !
The root cause is a defective inegrated circuit on DSP board (the one with digital inputs). To fix it change the chip CS4391 by a new one or better by the improved version CS4392. On my device a capacitor was cut close to this IC : replace one 1uF after changing the IC. For any question search me with my callsing "F5RCT"; i have a spare IC for the one who is able to change it !
I'm amateur radio and engineer
Jul 08, 2007 | Marantz SR-4200 Receiver
614 people viewed this question
