Question about Garmin nuvi 265 Car GPS Receiver
Downloaded and installed Bluetooth firmware update - Won't Pair
Hi, I also downloaded and installed a Bluetooth firmware update on my nuvi 265WT using Garmin WebUpdater. The nuvi now has no voice and won't pair with the original phone. Garmin support emailed me new remote switch software which I installed but it didn't solve the problem.
  • 2,335 Answers
I recommend rerunning the webupdate software available below, which was updated March 30, 2010. Run through the update steps again.
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
After successful webupdating, a hard reset is often helpful at this time, too.
I hope that helps.
_____________________________
Nuvi 265WT Manuals here.
Posted on Apr 19, 2010
I wish to erase phone numbers, transferred from my cell phone to my Garmin 265WT when pairing the phone to the Garmin. These phone numbers came from my cell phone and I cannot remember who is associated...
I can help you with the phone numbers on your Garmin Nuvi 265WT.
The phone numbers transferred to your Nuvi are only supposed to be available when your phone is paired to your cell phone. Changing the entry on your phone should allow that entry to show up changed the next time it is paired with the Nuvi. Sometimes, a bluetooth mix up causes entries to be duplicated or entries' phone numbers to get repeated.
To correct this, I recommend backing up your favorites, clearing all user data (this hard reset will remove the phonebook info from your nuvi), and then updating your Nuvi' firmware to make sure the nuvi and cell phone bluetooth process runs as smoothly as possible in the future.
Follow these three steps to take to get your Nuvi 265WT running like new:
I hope that helps.
_______________________________________
Erase Nuvi 265WT Phone Numbers here.
Apr 11, 2010 | Garmin nuvi 265 Car GPS Receiver
Tip
Nuvi 265WT Delete Phone Numbers
Garmin Nuvi 265WT Delete Phone Numbers
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to erase the phonebook entries on your Garmin Nuvi 265WT, left over from when you bluetooth paired with your cell phone?
I can help you delete the phone numbers on your Garmin Nuvi 265WT.
I hope that helps.
____________________________________________
Change Nuvi 265WT Home Phone Number here.
Download Nuvi 265WT Manuals here.
Download Garmin Nuvi 265WT WebUpdater here.
Garmin Nuvi 265WT Hard Reset here.
on Apr 23, 2010 | Garmin n?vi 265WT Car GPS Receiver
Tip
Garmin Nuvi 265WT Webupdate Models: Garmin Nuvi 200, 200W, 250, 250W, 260,...
Does your Garmin Nuvi 265WT GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Backup & Restore Nuvi 265WT Favorites here.
on Apr 19, 2010 | Garmin n?vi 265WT Car GPS Receiver
My garmin nuvi won't turn on? i've tried to plug it into charger but nothing happens
I can help you reset and fix your Garmin Nuvi 265WT.
Erratic behavior is an indication that the firmware / system software inside your GPS has been corrupted.
It is not necessary for your computer to be able to 'see' your Nuvi in order for the firmware update to work. When it is successfully updated, the Nuvi will communicate properly to the computer, and your pc will 'see' it, and you can load your maps.
There are three steps to take to get your Nuvi 265WT running like new:
I hope that helps.
Nuvi 265WT Change Home Phone Number
Apr 10, 2010 | Garmin nuvi 265 Car GPS Receiver
Need too update cant get in site
this is because your browser may not be supporting the file you first need to install a more appropriate browser
Apr 05, 2010 | Garmin n?vi 265WT Car GPS Receiver
Garmin Nuvi710 phone book detail does not match phone contacts
I hope that helps.
Jan 26, 2010 | Garmin Nuvi 265W GPS Receiver
I have a garmin nuvi 265w and when i connect via bluetooth to my BBerry curve the garmin turns off and on occasionally (usually at a critical point in my trip or during a phone call !). i have the current...
Also, a Nuvi that is turning off and on is symptomatic of having corrupt firmware.
I hope that helps.
Nov 11, 2009 | Garmin nuvi 200W GPS Receiver
Need to add and delite numbers to phonebook
I hope that helps.
May 18, 2009 | Garmin nuvi 265 Car GPS Receiver
When I connect my 265wt to the computer, it just keeps loading the maps and the computer won't reconize the nuvi.
It is not necessary for your computer to be able to 'see' your Nuvi in order for the firmware update to work. When it is successfully updated, the Nuvi will communicate properly to the computer, and your pc wil;l 'see' it, and you can load your maps.
I hope that helps.
May 12, 2009 | Garmin n?vi 265WT Car GPS Receiver
Garmin 265wt. How do you delete duplicate # fm phonebook?
I hope that helps.
Feb 10, 2009 | Garmin nuvi 265 Car GPS Receiver
Garmin nuvi 265 Car GPS Receiver Logo
435 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
