Question about OKI MICROLINE 590 Matrix Printer
Our OKI Microline 590 prints fine for 24 pages and then starts printing gibberish on page 25 and up
I have a OKI Microline 590 Matrix Printer at my store. When we used to hit Utility it would print decently. The ink would be on the lighter side but it was legible. Recently someone came in to change the...
Re-install the printer ribbon. It's probably slipping or dragging on the head mechanism, and the printer synchronization control is slowing everything down to compensate.
Mar 08, 2011 | OKI MICROLINE 590 Matrix Printer
Printing gibberish then feeding several lines, printing gibberish
If text did not line up as planned, your TOF ( top of forms adjustment ) isn't correct. Just correct it using the button on the panel. If after printing 1 page or so and then it begins to go out of place, most probably you hv set the page lenght incorrectly. To correct, enter the MENU on the panel and set the correct page length.
Lastly if printing garbage, most probably you have selected the wrong emulation on the MENU. Correct by entering MENU mode ( press ' SHIFT+MENU ' button together ) and select the correct emulation.
Hope this helps.
KM HOO
Mar 04, 2009 | OKI MICROLINE 590 Matrix Printer
Oki Microline 590
Try to perform an offline test print using your printer alone
To do this, power off your printer first
Press and hold the LF/FF button on the printer panel then power on. The printer will perform its own printing ( lines of pattern )
If it does it without problems ( no MENU lights came on ) the printer should be OK. If not try replacing the printer main control board.
Hope this helps
KM Hoo
It
Setting up printer for reports & checks
Press SHIFT+MENU together to enter MENU mode
press GROUP until it prints EMULATION - make sure it doesn't shows UTILITY
Best Rgds
KM Hoo
Dec 28, 2008 | OKI MICROLINE 590 Matrix Printer
Rolling halfway down the page
is the form tear off on?
if it is try changing it to off
Dec 03, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI Microline 320 Problem...
I think you maybe using the wrong driver.Printout the menu if you are set for IBM than choose the "IBM Proprinter" driver in windows.Hope this helps.
Dezzi
Feb 26, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki Microline 320 Turbo page alignment
This sounds like a problem in the computer program that is sending the prints to the printers....especially since it is happening in several of them.
Jan 23, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 591
You need to set and store paper size, width etc in printers internal menu and on print driver on pc.
See Oki manual for printer settings its written on the front of the machine i think menu and set power on, then print to see settings then read manual...
Jan 04, 2008 | OKI MICROLINE 591 Matrix Printer
Need Help!
Sounds like driver problems. Cant solve problems without details like what opperating system, what driver, how it the printer attached, usb, paralel, network? Will it print a test page from the driver ok?
Aug 31, 2007 | Samsung OKIDATA - OKI Microline 590...
OKI MICROLINE  590 Matrix Printer Logo
214 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
