Question about Dual TOA IP-600D Channel, 400W Power Amplifier, Stereo Amplifier with 400/600 Watts per Channel (IP6... Car Audio Amplifier
Amplifier doesnt cut off with car, battery dies every time
    Problem Solver:
  • 8 Answers
Where have you connected you remote wire?
it should be on the back of the stereo its self.
there are two power wires on the back of the stereo, one that is permanent live for the stereo's memory, and one that is semi live that dies when the ignition is turned off.
the semi live is wire you need for the amps remote wire.
hope thi helps
Posted on Sep 25, 2009
I assume you are speaking of the car battery, and it gets drained when the ignition is turned off.
Your problem is you have connected your system to the wrong power connection. Automobiles have wiring lines that supply power all the time, to other parts of your vehicle. You need to find a power connection, preferably from your fuse box, that stops supplying power when the ignition is turned off. This will also help provide a back-up fuse incase of any other problems you might incur.
Posted on Sep 09, 2009
I have all alpine speakers,deck,amp, and subs. My subs were working for about a year until one time i started my car and they keep cutting in and out .. at times they will work but then they cut off...
Sounds like blown subs, in the process of completely dying out, or a loose wire, possibly inside the box or from the box to the amp. Have your subs tested at a sound shop, or using a multi-meter, check for resistance across the sub terminals. An open line indicates a blown sub.
Jan 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
My 1992 kawasaki zephyr 750 cut out and died when
sounds like your battery has an internal short circuit, time to change it and hope nothing else got damaged
Oct 05, 2009 | 1992 kawasaki Zephyr 750
Amp cutting out when bass hits
With an amp like that you can not pull enough power from you cars battery alone. That is why when it hits hard it drains the amps from your battery and you amplifier cuts out. The light on the amplifier most likely dims when the bass hits. You need to get a capacitor. They are easy to hook up on the main power wire. You can get one from http://phatcaraudio.com/capacitors.html or get a used one off ebay.com. Good luck
Jul 01, 2009 | Alphasonik PMA1000D Car Audio Amplifier
Why does the amp sound like it doesnt have enough
check battery voltage under load with radio off and then on
Jun 29, 2009 | Nitro BMW-482 Car Audio Amplifier
I would like to get my amp out of my car but i cant figure out how to disconnect the ground wiring
The ground wire can be cut and be spliced in at a later time so its safe to cut the ground to the amp and tied off for later use. Otherwise it would be a needle in a haystack of wires to find the ground lead. Thanks Rulds2008
May 14, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
LIGHT DOESNT COME ON AT ALL
all the possibility but check all you power source and rca;;
Mar 29, 2009 | Sony XM-2165GTX Car Audio Amplifier
Amp goes into protection
First change the wire,and disconnect the subwoofers to check if the amplifier turn on without going in to protection mode,if the amplifier go to protection mode you gotta change the Audio amplifiers IC's because they are in short circuit.And if don't go in to protection put one speaker at a time to check if one of them are damaged.Good luck.
Jun 02, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Amp cuts off
You may have a problem with the power source feeding the amp. You need to check the voltage across the amplifier's B+ and ground terminals when the amp is playing/cutting off. If it's dropping below ~11 volts, you need to determine why it's dropping so low.
Sep 18, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Dual TOA IP-600D Channel, 400W Power Amplifier, Stereo Amplifier with 400/600 Watts per Channel (IP6... Car Audio Amplifier Logo
89 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
