Question about Proview PL713B 17" Flat Panel LCD Monitor
The monitor keeps going blank after a minute or so
The monitor keeps going blank after 20 seconds or so and you have to keep turning the monitor off and on again to get a picture
  • gq2180 Sep 11, 2009
    thanks for giving me a solution to try. unfortunately it didn't work. i had the turn off monitor setting already set to never so i changed it to 5 hrs. and the same problem still is persisting. any other ideas to try? i've been searching through the whole menu of the actual monitor and there isn't anything that sounds like it would help this. thanks.
  • 30 Answers
Hey right click on your desktop.go to properties.in the propertes menu go to screen saver tab.click on the screen saver tab.in the screen saver tab menu you will see a tab called power.click on the power tab.change your settings there for the monitor.let me know if it works.
Posted on Sep 11, 2009
  • 3 more comments
  • lorenzo carolus Sep 11, 2009
    hey right click on your desktop.go to properties.in the propertes menu go to screen saver tab.click on the screen saver tab.in the screen saver tab menu you will see a tab called power.click on the power tab.change your settings there for the monitor.let me know if it works.
Monitor flickers and goes blank after 5 seconds and keep repeating this very often.
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 26, 2010 | Acer AL2016W 20" LCD Monitor
Screen goes blank when first turned on, have to keep restarting m
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
Hi..my sony model sdm-hs93 lcd monitor flutters for a couple of seconds right before the screen blanks out. But, if I leave the monitor on for a day in sleep mode, the next day i can hook it up to the...
I think the problem with your monitor is that, the picture board on the monitor is malfunctioning that is why it keeps going blank after a minute.
What you need to do is to replace the picture board on your LCD monitor, replacing the picture board will solve the problem, because the picture board on the monitor at the moment is bad and will need to be replace.
Replace the picture board and you will see that the problem will not repeat itself again.
Take care.
Jul 16, 2010 | Sony SDM-HS93 19" LCD Monitor
No Signal
yes start the computer then keep pressed the key F8 untill the display comes then hightlight the option last good known configuration and select the problem will be solved
Mar 06, 2010 | Acer 22" X223w LCD Monitor
Acer Monitor Not Staying On
It sounds like there's a problem with the monitor itself. It may be that the lamp in the computer is dying, which would explain why it keeps going out. Other possibility is that the monitor isn't receiving power properly either through the cable or inside the monitor itself.
If your're not the kind of person who wouldn't mind opening the monitor up and hopping in there, then I recommend you take it somewhere it can be diagnosed like Best Buy.
Hope I helped :)
Nov 28, 2009 | Acer X223WB 22" WIDESCREEN LCD Monitor
Sceptre 20" Monitor will not stay on
First check the monitor sleep mode for your monitor in windows control panel, check that its not going into hibernation/stanby. if thats not it. and the monitor keeps shutting down. You may have to replace it newer models have more features and could be cheaper by saving you the hassel check newegg.com or orverstock.com
Jul 08, 2009 | Sceptre X7GNAGAV 17" LCD Monitor
The W1907 goes blank when i turned the monitor off and then on
I would say don't turn off the monitor at the switch at all unless you are not going to use it for a long time. I just leave mine switched on and the power save blanks the screen if I am away from it for 20 minutes. I leave my PC switched on all the time as well. If I need to use it for any reason it takes ages for it to start up fully so it's more convenient to just leave it all going so it's ready when I need it. If away from the PC for a day or more switch it off but I keep going back to it all day and night so it's easier for me to leave both on all the time.
Jun 17, 2009 | HP w1907 LCD Monitor
Proview monitor PL716s
you ave some blown caps on the vga board replace them and all will be well
Dec 28, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Proview PL713B 17" Flat Panel LCD Monitor Logo
323 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Diego Zenizo
Diego Zenizo
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
