Question about CTX Televison & Video
Need AC Adapter for CTX JT156A2-2 Monitor or voltage & polarity specs for same...Thanks
  • 3,153 Answers
The specs you need are usually embossed on the monitor near the power socket or on a label on the rear.
Posted on Sep 09, 2009
I need to know the voltage of the speaker for ac adapter matching
The speakers may have a label that has the voltage printed on it.
You can check the Bose WEB site for the specs of your model speakers. You need to know the polarity of the connector, if you get it wrong you could destroy your speakers.
You may need to contact Bose support if the specs do not help you.
Jun 14, 2012 | Bose Companion 2 Computer Speakers
What is rating of Spin 50 Power Module. Lost mine
Should it be a power supply that outputs AC and converts to DC inside the speaker case, or is it a wall adapter the outputs DC straight to the built in amplifier?
Some speakers have the voltage and polarity for the plug on the back of the speaker where the power lead plugs in. As they are only small speakers of probably a couple of watts it may only need about 2 Amps or less. Higher current is fine as the amp will only use what it needs to work correctly but I would'nt go below 2 Amps.
May 06, 2012 | Labtec Spin 50 Computer Speakers
I'm missing the power adapter for the CTX Monitor S500. Where can I find one?
http://www.google.com/#hl=en&source=hp&q=power+adapter+for+the+CTX+Monitor+S500&btnG=Google+Search&aq=f&aqi=&aql=&oq=&gs_rfai=&fp=ff274912d96214e6
Jun 24, 2010 | CTX S500BA (Black) 15 in. Flat Panel LCD...
Voltage and polarity for Hyundai B70A
Your monitor needs a 12volt 5amp power supply with + 5,5mm tip. Most universal power supplies will not supply enough amps to power an LCD monitor. If you need an adapter we do have them in stock at:
http://www.ccl-la.com/parts_lcd.htm
I hope this helps, if so please rate this solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 16, 2010 | Hyundai ImageQuest B70A 17" LCD Monitor
I need to know if there is still some were to purchase and Ac Adapter for a Balance LCD Monitor CM2019?????????
All you need to know is:
- The output voltage (usually 12V)
- The rated output current (usually above 5A)
- The plug polarity (usually plus on the inside)
Then just purchase any replacement AC adapter that has the same voltage, same plug polarity and rated current preferrably more (at least 120%) of the original.
That's it.
You can buy them online, for example at http://www.12vadapters.com/
Dec 24, 2009 | Balance CM2019 19" LCD Monitor
Power failure issues
The specs for this monitor is a 60 Watt, 12 Volt, 5 Amp power adapter. The voltage must be the same. You can always get an adapter with a higher Amperage rating, but never get one with less, as this can overheat the adapter and damage it. I was not able to locate specs on whether the voltage to the monitor is DC or AC... most are DC. If this is the case, the observe the polarity at the monitor. Power adapters have a positive and a negative... center and outer contact, Make sure that the power adapter matches that of the monitor, else it will not work.
Sep 26, 2009 | Balance CM2017 17" Monitor
Cpqusbfw usb hub
i have one of those hubs the ac adapter is output +5V, and current 0.2 - 2.5A, inside of connector is pos(+), outside is neg(-), input: 100 - 120 Vac and 0.45A Max
Aug 30, 2008 | Micro Innovations Compaq CPQ24USB
Need specs on AC adapter
It'll need a +5v and a +12v.
I'll repost tomorrow with current ratings, I've got one at work.
Or you could take the drive out of the Seagate case and put it in another case, they are cheap.
Oct 10, 2007 | Seagate (ST3300601CB-RK) (ST3300601CBRK)...
Televison & Video Logo
64 people viewed this question
Top CTX Televison & Video Experts
Electro Med Services...
Are you a CTX Televison and Video Expert? Answer questions, earn points and help others
