Is there a filter on the wmt 03 hotpoint washing machine
Is there a filter on the wmt 03 washing machine that i can clean , As my washing machine is making the clothes smell,tried all other solutions boil wash clean rubber seal clean draw etc etc.
  • Anonymous Mar 16, 2014
    innovation washing machine clean filter
We have the same machine which had the same problem, there is no filter only a colection pot at the bottom of the machine. Unfortunately even cleaning this did not solve ours, in the end I had to strip the machine down, split the drum down and then flush the brown crud which had accumulated behind the steel inner drum. Ta da problem solved!. Probably not what you'd want to do if you were not confident in attempting it but it saves buying a new machine.
Posted on Feb 07, 2010
Hi my washing machine is not draining or spinning is there a way of reseting it. It is a hotpoint wmt 720
No reset on Washing Machines, suggest you talk to Engineer, to find out the problem Ask on Internet
Mar 14, 2015 | Hotpoint Washing Machines
Hotpoint acquarius wf640 what does error f-03 mean?
F-03 means that there is a drain problem. Check the drain filter and the drain hose. The drain filter must be cleaned and the drain hose must be set according to the specifications on the appliance's manual.
The drain filter access is located in the front lower side of the washer. The drain hose at the back of the appliance. See also: http://www.fixya.com/support/r4949772-washing_machine_not_drain
Jun 23, 2012 | Hotpoint Washing Machines
Where do I find the filter on my Hotpoint Aquarius WM22? Or does it not have one?
Both the Hotpoint WD63 (wash dryer) and the Hotpoint WM22 (washing machine) have a drain filter in the sump hose at the bottom of the tank.
This filter is a last line protection for the pump and is not designed to be cleaned on regular intervals by the user.
Jan 31, 2011 | Hotpoint Aquarius WD63 Front Load...
Where is the filter?
theres no filter as such you have to do whats called a maintance wash tells you in the instrutions just a boil wash to clean filters some hotpoint machines have a filter access point under the kick plate at the front bottom of the machine
May 20, 2010 | Hotpoint First Edition FEW12 Front Load...
Hotpoint washing machine, model WF630, Error F-03???
Error code F03 is indicating a problem with the wash thermistor, it could be open or short circuit.
Check connections on thermistor and heater element.
Hope this helps.
Dec 15, 2009 | Hotpoint Aquarius WD640 Front Load...
Cant find filter on my hotpoint Ultima
Good luck. All modern washers that I know dont have the filter you need. If a clean out is needed you will have to clean out the pump.
Jan 26, 2009 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT KEEPS FLASING F-03
The error code F03 indicates that the wash thermistor is open or short circuit.
Check heater element and thermistor,if ok, then you need to call an engineer.
Sep 22, 2008 | Hotpoint Aquarius WD63 Front Load...
Filter
most hotpoint have a hidden filter
take back bottom panel off. you will see a large diameter hose coming from tub to pump. undo hose at tub end. filter is inside this hose. take it out and clean it
Jun 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
