Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
SWEEPER STOPPED, WITH A LOUD HUMMING SOUND. THE
SWEEPER STOPPED, WITH A LOUD HUMMING SOUND. THE BELT IS OK. THE DRIVE SHAFT IS NOT TURNING ?
  • 430 Answers
Do not turn on again. You have an obstruction in the fan . You will need to remove the motor from the lower housing, dismantle the fan cover and remove the obstruction, possibly replace the fan as well.
The lower housing plate can be removed revealing a set of clamps around the motor hosusing which will in tun release the motor from the base of the vac.
Posted on Sep 09, 2009
Canister vacuum
Without the make or model... We are speaking in GROSS GENERALITIES... but
ELECTRICAL Trouble...
The light & the BRUSH not working ... when considered TOGETHER.. would indicate a NEED to check your electrical connections...
My best advise would be to:
make sure the cords & wands are fully connected
make sure the (HEAD) motor is running ...
If the motor (brush head) is running... belt looks good and brush is not seized (or jammed)...
You will need to look to the DRIVE PULLEY on the motor OUT-PUT shaft...
Hope this helps
Jul 25, 2016 | Vacuums
Changed belt on my eureka airspeed sweeper n since makes loud noise, really loud n vibrates
Sonja, Recheck belt installation, see if it is riding in proper groove or is twisted.
Press the helpful button and follow me on fixya for more tips and info.
Feb 11, 2016 | Eureka Vacuums
I need to change my sweeper belt on my Dyson 14 Animal
When turned on and set to sweep the sweeper makes a loud noise like it has something stuck in it but the brush is turning abut not does not have a lot of sucking power. It started the other day when a blanket with tassels got caught and wund up in the brush and sucked up in the sweeper a bit. Tried to pull out while running and came out but made the loud noise. If I take off the brush then it does not make the noise when on. I think it might be the belt grooves are worn and slipping when the sweeper is in the sweeping on mode. Sorry, do not know the technical sweeper terms.
Dec 13, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuum wont spin when on carpet but will spin if tilted off the carpet
Remove the bottom plate of the sweeper. Remove the sweeper brush roller and clean the end bearings of debris. Oil the bearings lightly with 3-1 oil or similar machine oil. Clean the motor shaft with alcohol as well as the brush drive area, and the inside of the drive belt. Test on a carpet for improvement--if still stopping, replace the rubber drive belt. Hope this helps!
Nov 21, 2010 | Bissell 3920 Bagless Upright Vacuum
I need to replace the belt I bought a new belt and I can't get the belt back on
On this page
http://www.totalvac.com/videos/kirby-vacuum-cleaners-videos.htm
there is a video at the bottom on changing belts on a Kirby
Sep 23, 2010 | Kirby Generation 3 Bagged Upright Vacuum
The sweeper parts that spins just stopped spinning, what I do, I don't know where my owners manual is?
Sound like your belt broke. most vacuums the bottom plate comes off or the top cover can be removed to access the belt area.
Sep 27, 2009 | Vacuums
How do i change belt on my hoover sweeper
get a fillipshead screwdriver, put the vacuum facing you so the brush is infront of you, you will see 4 screws on each corner.unscrew those and when you do there will be a space where you will see a shaft that points out. take the old belt off and put one part of the new belt on the shaft and the other part on the brush near the belt. (there will be a little brown part on the brush for the belt to lay on) make sure its secure and screw the screws back and your ready to go !
Sep 09, 2009 | Vacuums
Roller does not turn; I was vacuuming a rug and a string got stuck in roller-took it off but now the roller will not turn. suction is fine.
The roller drive belt may be stripped, worn partway through where it goes around the motor shaft, thrown off the motor shaft, or broken. Take the bottom plate off the carpet sweeper and have a look.
If the belt was damaged when the roller brush got stuck, then you get to replace it. On most of these, the easiest way is to put the new belt around the roller pulley, reinstall the roller, stretch the belt around the end of the motor shaft, then turn the motor by hand while pushing the belt on. If the motor also has a pulley on it, you may have to remove the motor screws to get enough slack on the belt, then pull the motor into place and put the screws back in.
Aug 28, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kirby generation3 instructions,
Hi there!
If you are talking about the main sweeper attatchment, Lift the light at the front of the upright machine, Make sure the belt inside the sweeper it is over the hook when you turn the handle on the front anti-clockwise to "belt off". Turning handle raises belt.
The hooks at the bottom of sweeper go over the bar at the base of the body. It helps to lift the wheels slightly.
When hooked on, rotate handle clockwise to "belt on" and close the light cover.
Is this solves the problem , please take a moment to rate as Fixya! If you need more help, just ask again on this question.
Thank you.
Jun 19, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
189 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
