Question about Dual Car Audio & Video
What color is the power wire for 1984 volvo 240
    Problem Solver:
  • 5 Answers
BEST THING TO DO IS GET A TEST LIGHT AN TEST ALL THE WIRES FOR POWER YOU SHOULD END UP WITH THREE BUT ONLY TWO ARE REALLY NEEDED CONSTANT POWER WITH IGNITION OFF AND ONE THAT GIVES YOU POWER FOR ACCESSORIES ONCE U OPEN THE SWITCH
Posted on Sep 14, 2009
1984 Volvo DL Wagon No Heat or Fan
I would look for the supply to the blower motor. If you have supply on the motor, the motor is probably faulty, if not look for the reason why no supply is there.
Feb 26, 2018 | 1984 Volvo 240 Series
What is the fireing order and distributor wire location. On a 1986 240. Volvo dl
1432 clockwise
bring number one piston to top dead center and look at rotor- start number one wire in that spot-
if engine doesn't start and sounds funny
then you are 180% out---- bring up # one piston again and look at rotor this time it should point oppsite of where it was- redo plug wires- engine should start
Mar 24, 2012 | 1984 Volvo 240 Series
What's wrong with my 1985 Volvo 240 if it won't start? I already changed the battery and ignition cables and when I ten the key an give it gas the engine wants to start but t doesn't..
I had this problem and had to rebuild nearly the entire wiring harness, in my case, from the alternater to the starter. My wires had water damage and some rodent chews! Hope this helps, check harness.
Feb 10, 2011 | 1984 Volvo 240 Series
Central locking not working draining battery. Looking for color of wire at fuse panel, so I can disable it; and/or location of relay for system (and any obvious identifying features of the relay).
i used to have the same problem with my '83 what happened is that my came from up-north so in the 240 volvo up to 1986 the wire is "bio degradable" or something like that what happened is when you touch it practically turns in dust... go to the junk yard and get the wire that goes in the driver side is like plastic ring with 3 wires and that will fix the problem... all of them are the same up to 93, get the newest
Feb 03, 2011 | 1984 Volvo 240 Series
I have a 1984 Volvo 240 DL 4 cylinder wagon, it has had some minor electrical issues (like the power locks turning on the back windshield wiper) and the other day the car's engine and power steering just...
You need to check your engine wiring harness. 84 is part of the crumbling, corroding wiring insulation years. If your harness has not been replaced, you may have to really scrounge around to find one of the "new" versions that has okay insulation on the wiring.
Nov 16, 2010 | 1984 Volvo 240 Series
Shop says that moms 1982 volvo chrysler distributor has
There is little to go wrong electrically.
Replacing the points and condenser covers it;
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2057872.m570.l1313.TR0.TRC0.H0.X1982+Volvo+240+distributor+.TRS0&_nkw=1982+Volvo+240+distributor+&_sacat=0
Nov 07, 2017 | 1982 Volvo 240 Series
1984 DL in tank fuel pump.
Check the fuses, I think power to the tank pump is supplied via a fuse. The pump will have power all the time!
Feb 25, 2009 | 1984 Volvo 240 Series
Volvo wagon, power window on driver's side will not come up
Could be the window switch,motor or regulator.
Jul 20, 2008 | 1984 Volvo 240 Series
Car Audio & Video Logo
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
