Question about InFocus ScreenPlay 4805 Multimedia Projector
It makes a wierd noise
The noise started a week after we replaced the bulb.
    President:
  • 1,187 Answers
The bulb housing has come loose...
When the bulb heats up & cools in normal use, the housing will contract and become loose.
Unplug and re-seat the bulb and housing ...
Another possibility: If the replaced bulb shattered in the projector, there may be debris in the fan... use compressed air ($8/can RadioShack) to clean out (make sure the projector / bulb are cool before using compressed air.
Hope this helps!
Posted on Sep 09, 2009
My mr heater mh9b won't stay lit. The pilot flame starts acting wierd and making noise after ten to fifteen minutes of being lit and then goes out completely. It can be re-lit but goes out again in a...
my mr heater mh9b won't stay lit. The pilot flame starts acting wierd and making noise after ten to fifteen minutes of being lit and then goes out completely. It can be re-lit but goes out again in a bit. Any suggestions?
Nov 17, 2009 | Mr. Heater MH9B Ceramic Utility
2001 kia sephia the clutch has dropped to the
What did you do to fix the clutch fluid loss??? if it ran dry, you need to find out where it went. You will need to replace the clutch hydraulic master and slave cylinders.
Sep 21, 2009 | 2001 Kia Sephia
Projector makes wierd noise and shuts down after several minutes
3 problems: 1- the light tunnel is collaping and needs replacing. 2- the tunnel might be hitting the colorwheel, which is now making that wierd noise. and 3- it needs cleaning. these models are famous for these 3 problems. there are no filters, so the dust just gets sucked in. the glue on the tunnel wears out from heat after a while. the colorwheel motor also wears out from heat and dust. the parts are not that expensive and they are relatively easy to install. contact an infocus authorized service center (from their website) and either get these parts or send it in.
tunnel- 306-0095-01
colorwheel- 525-0146-00
Aug 28, 2009 | InFocus ScreenPlay 4805 Multimedia...
My car makes a wierd noise when starting it up
IF ITS MAKING A CLICKING NOISE WONT TURN OVER.CHECK BATTERY CABLE FOR TIGHTNESS AND NO CORROSSION. THE BATTERY VOLTAGE. SHOULD BE 12.5 VOLTS.IF NOT HAVE IT CHARGED AND TESTED.IF ITS GOOD HAVE ALTERNATOR CHECKED OUT.IF BOTH IS GOOD HAVE THE STARTER REMOVED TO HAVE IT AND THE STARTER SOLENOID TESTED.NOTE DUE TO LOCK OUT FEATURE.TURN OFF RADIO SO YOU WONT LOSE CODE WHEN YOU DISCONNECT NEGATIVE BATTERY CABLE.
Aug 12, 2009 | 2004 Dodge Neon
I changed the bulb in my tv and it was working for a few days. Now I get audio but there is a wierd electrical clicking noise which made me think the new bulb broke but I still have a green light on the...
In this case there are two possibilities of what part is the one causing the issue, it coul be a ballast because of the clicking sound that caused the tv to shut off, and that buzzin sound is for your color wheel that it might not be working anymore, discountdashmerchantdotcom free troubleshoot
Jul 24, 2009 | Mitsubishi WD-65733 65" HDTV
Whirlpool gold refridgerator light not working and is making funny noise
switch of your refrigerator then try replacing the light that doesn't work then try to switch it back on. the light might be the cause of the noise. it might be grounded. replacing the light might reduce the noise then observed the noise for a week then if it still making noise that's the time for you to get a technician that could fix your refrigerator.hope it helped... send us a message for more concerns thank you...
Jun 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Sony 60 in projection tv makes weird noise
Did you hear that wierd noise 3 times after you turn the TV on? if so the ballast is working try replacing the lamp XL-2000u
May 27, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
InFocus ScreenPlay 4805 Multimedia Projector Logo
141 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
