Question about Amana ACO1840A Microwave Oven
My Amana Microwave ACO1840A "start" and "stop" buttons are working intermittently. Any Sugjestions?
  • Amana Master
  • 9,098 Answers
You have a failing membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for FREE help & do-it-yourself advice.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 12, 2009
Is the clock that has stopped working fixable?
Yes, but ... If this truly is a failure, you're looking at replacing the clock/display/control board. This is usually a VERY expensive solution. In some cases more than it's worth as compared to replacing the entire microwave. The clock not 'sticking' is a rather unusual complaint. I'd highly recommend that you dig out the owner's manual - or check on-line for one if you can't find / don't have - to make sure you're not missing a step while setting the clock.
Jul 07, 2014 | Amana ACO1840A Microwave Oven
Microwave turns on but does not heat.
The magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Oct 31, 2010 | Amana ACO1840A Microwave Oven
ACO1840A Not heating Makes loud noise when turned on
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 26, 2010 | Amana ACO1840A Microwave Oven
The oven control panel won't let me push light and work. Even when putting in the times for microwaving, the start button won't work. The panel seems to not be working. Do I need to replace the panel?
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it is just failing to start when you press "Start", it may just be a door switch or mount. See this file.
If several keys are not working, it is almost certainly a bad keypad.
Feel free to contact me directly (and mention your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Jun 14, 2010 | Amana ACO1840A Microwave Oven
Microwave will not stop cooking unless I open door
you have a bad door switch call a tech these things can kill you even if they are unplugged.
Jan 07, 2010 | Amana MVH210W Microwave Oven
I hit the lock button and it quit wrking
Hold down the "START" button for 5 seconds.
Jul 13, 2009 | Amana Radarange Microwave Oven
Looking to buy a top vent grille
Depends on the brand, but you can usually find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If not, Please reply back with your brand and model number so we can help you.
Feb 11, 2009 | Amana ACO1840A Microwave Oven
Need to replace present microwave with compatible one (ACO18490A)
I guess you already done some microwave shopping and can't find anything. SEARS sells this item for $400.00 http://www.sears.com/sr/javasr/product.do?BV_SessionID=@@@@0477548919.1182727839@@@@&BV_EngineID=ccifaddlfkfgdkkcefecemldffidfmm.0&vertical=SEARS&sid=I0004501420003900085&pid=02276779000
Jun 25, 2007 | Amana ACO1840A Microwave Oven
Fan starts intermittently Amana AMV5164BAB microwave oven
Sounds like a loose connection or a failing hood thermostat. That's right behind the control panel on the base plate. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://www3.sears.com/
Mar 12, 2007 | Amana AMV5164 Microwave Oven
Amana ACO1840A Microwave Oven Logo
161 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
