Question about Apple iPod classic MP3 Player
My ipod is not getting strated it was fallen down two-three time a white screen is appearing what should i do? please help me in solving this problem as soon you can. the model is ipod classic
    President:
  • 392 Answers
Have you tried restoring it?slide the hold switch on and off a couple of times and then when in off position press and hold menu and center buttons till an apple logo appears...restore it using itunes and you're done
Posted on Sep 09, 2009
--please help. i pod 4gb silver has white screen. does not turn off i hear 2 beeps. it stays on with white screen. What do I do?
Hi leahschecter
***White Screen of Death***
This is probably caused by not allowing the firmware update to finish the installation before disconnecting the iPod.
Try these steps.
Reset the iPod:
1.Turn the Hold switch on, then back to off.
2.Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
3.You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
Put iPod into Disk Mode:
Apple suggests that you ensure your iPod is charged before following
the next step. How exactly you check a charge on an iPod screen that
is completely white has yet to be revealed. But hey, give it a shot
anyway. Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
2.Press and hold the Menu and Select buttons until the Apple logo appears
3.Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode.
If at this point you still have the white screen,
restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory
settings).
Don't disconnect or eject the iPod until the store is totally done.
After you think it's done, wait another five minutes.
Please take time to rate Me
Bud
Nov 25, 2012 | Apple iPod MP3 Player
Ipod touch 3g has a white screen - any way to bring it back up?
Hi mickhon...
Try these steps.
Reset the iPod:
settings).
Sep 17, 2011 | Apple Ipod Touch 8 GB 32 GB 64 GB 3rd...
My ipod touch 8 gb screen has went complettely white and will not do anything. What do I do?
Hi webfoot1304...
Try these steps.
Reset the iPod:
settings).
Aug 23, 2011 | Apple Audio Players & Recorders
My screen is showing white i can here but not see
This is probably caused by not allowing the firmware update to finish the installation before disconnecting the iPod. Try these steps.
Reset the iPod:
Apple suggests that you ensure your iPod is charged before following the next step. How exactly you check a charge on an iPod screen that is completely white has yet to be revealed. But hey, give it a shot anyway. Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Don't disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
Free answer...Please rate me
Apr 13, 2011 | Apple iPod nano
Hi my ipod touch screen is wghite when i turn it on please help me
Try these steps.
Reset the iPod:
settings).
This is a FREE answer, Please Rate Me
Sep 26, 2010 | Apple iPod touch
White Screen Of Death
MY IPOD IS IS HAS A WHITE SCREEN
Feb 08, 2010 | Apple iPod nano
White screen and no music HELP
if your getting a line hrough the screen.. its possible you have wet it.. try to reset it and see what happens if that doesn't help.. give me a yell
Nov 10, 2009 | Apple iPod nano
I have the white screen on my ipod nano 2nd gen i tried the reboot, restore, debug everything i cant see any logos text or anything i cracked my old screen ao i bought this put it in and bam white screen...
Hi.
This is probably caused by not allowing the firmware update to finish the installation before disconnecting the iPod. Try these steps:
Reset the iPod:
  1. Turn the Hold switch on, then back to off.
  2. Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
  3. You may need to repeat the reset several times.
  2. Press and hold the Menu and Select buttons until the Apple logo appears
  3. Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
Nov 05, 2009 | Apple iPod nano 2nd Generation MP3 Player
Stuck on black and white Apple logo screen
Solution 1) Press Hold/Sleep & hold buttons at same time for 20 seconds, This may fix you problem.
If problem is still alive follow solution 2
Solution 2) Press Hold/Sleep & hold buttons at same time for 10 sec. & then leave only Hold/Sleep button keep home button pressed & connect you ipod to PC, That means you have to bring your ipod in DFU mode (Recovery mode) Check out this video for getting ipod touch in DFU mode http://www.youtube.com/watch?v=bITIiGswjFI
. itune must be run on PC.
It will ask you for restore. Accept Restore you ipod touch request by itune. Wait for few minutes while ipod being restored.
This process will solve your problem 100%. I have solved same problem for ipod touch. Follow this video http://www.youtube.com/watch?v=AQk4-krrNVk
Thanks.
If my solution help you please vote up me.
May 22, 2009 | Apple iPod touch
My ipod screen stays white, cant read it
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore http://www.apple.com/support/ipod.five_rs/
If you need more asistance, let me know. Good luck.
Feb 26, 2008 | Apple iPod nano
Apple iPod classic MP3 Player Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
