Question about Lexmark X2500 All-In-One Printer
My Lexmark 2550 printer does not communicate with my laptop (dell)
Won't communicate with windows 7 laptop. I have a dell inspiron laptop. Printer works with HP netbook, but not with laptop??
Use the Vista driver in Windows 7. Check if your Windows 7 is running on 32-bit or 64-bit operating system by going to Start menu > right click on Computer > Properties. Then, download the Lexmark Z600 driver at http://bit.ly/cd4MzI(for 32-bit) or at http://bit.ly/c4xCtN(for 64-bit). Execute the file and follow the instructions in the software. Thanks.
Sep 30, 2010 | Lexmark Z600 InkJet Printer
Km-2550 fax machine stays busy for long periods while it has document in memory and is communicating. The product is not a Lexmark, its a Kyocera KM-2550, but thats not a choice so...
1.....connect a regular fax to the line and see if you get the same response if you do then its a phone line issue... ... now lets troubleshoot...plug a phone in and pick up the reciever... listen for static on the line... if there is static... that can cause issues... call phone company... also if its voip... that can cause issues... if so tune your voip or get filters and this might reduce it... and possibly eliminate the issue.... if not... then i would call a kyocera tech and have him update the firmware for everything on the machine... printboards... scanners, fax... main system and if it keeps happening I would replace the fax board... still happening replace main board...
Oct 19, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark X6150 will not communicate with new Dell Vista computer
Uninstall the driver and restart. Turn off antivirus, install driver again and always click allow or yes if firewall ask for permission. Follow instructions, restart when done.
Aug 31, 2009 | Lexmark X6150 All-In-One InkJet Printer
I installed a new lexmark Z645 in my HP Compaqnc6120 llaptop. While printing its giving message 'Communication Not Available- the printer cannot communicate with the printer'. i have disconnected and...
I have seen that in most of the cases (with lexmark and dell printers) it is fixed by reinstalling the printer software. Be sure that you completely remove the older drivers using the cd or using add/remove programs
Jul 01, 2009 | Lexmark Z640 InkJet Printer
Printer does not Communicate (connect) following Microsoft SP3
I figured out the solution. Download the printer driver here http://downloads.lexmark.com/static/229-1-0-486.html#
Jan 28, 2009 | Lexmark Z600 InkJet Printer
Lexmark Z705 Printer
re-install the printer with take care of communication port,
PS. keep turn on your printer while installing
Nov 08, 2008 | Lexmark Z705 Inkjet Printer
My lexmark 2550 is now refusing to scan to computor
Go to START > RUN > Type: services.msc > OK > Scroll down the list and find LEXBCE Server > Right-clik on it and choose RESTART
Next scroll down the list even further and find PRINT SPOOLER > Right-click and choose RESTART.
This resets the communication from your Lexmark to your computer. Good luck!!
Oct 01, 2008 | Lexmark Office Equipment & Supplies
Computer will not communicate with printer
Go out to Lexmark web site and look for a vista update in their software download section. So this should solve your problem.Most of the cds which come with equipment do not contain vista software and drivers.
Aug 06, 2008 | Dell 962 Photo All-In-One InkJet Printer
Ckeck in control panel & se if the driver software installed. It should be listed in Add/remove programs. If it is, power up the piinter & load windows Vista update service. See if Vista has any patches for you're printer. If no, goto Lexmark & go to the driver section for you're P4350 printer software for Vista. While in Vista update, install any updates listed.
Click on the link provided.
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:479:0:0&searchLang=en&os_group=Windows%20Vista&target=
Creat a folder on you're desktop & down load the latest driver software in-to the folder you created. Uninstall any Lexmark software that might have been in add/remove programs. Install the driver software you downloaded. If all this still fails, call Lexmark since this is a new printer. The number should be in you're manul. Or you can go here for free support.
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_652569481_0_en,00.html
Luck!
Mike
May 29, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark X2500 All-In-One Printer Logo
75 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
