Question about Garden
MY OASE PUMP SEEMS TO BE LOW ON POWER, IT PUMPS WATER BUT NOT ENOUGH TO GET TO THE FILTRATION TANK
  • Anonymous Mar 21, 2014
    No filtration
  • 990 Answers
Check to be sure that the impeller is not clogged in the center of the fins.
Posted on Jan 15, 2010
Can I connect a mechanical tank float to the filtered water line of my HydroSense-0500? Will doing so damage the pumps?
You can connect the permeate line to a 3/8" tank float without any issues.
When the tank float valve blocks the water flow, the pressure will increase in the line until the high pressure switch shuts down the pumps. As the valve opens, the pumps will turn on automatically.
WECO HydroSense 0500 Light Commercial Reverse Osmosis Water Filter System
Mar 28, 2018 | Water Dispensing & Filtration
Tip
Simple keys to a beautiful clean pool.
There are 3 keys to a clean swimming pool; filtration, circulation and chemistry. Not having the right amount of any one of these keys will soon cause the pool to be dirty. Filtration requires a filter that allows enough flow and catches any particles in the water. Circulation means enough water is circulating. Chemistry is having the chemicals to the right levels in the pool. The most important component to accomplish these keys is the pump. If the pump doesn't work then the filter doesn't work, the water is not circulating and since chlorine feeders need circulation to deliver enough chlorine to the pool, not having a working pump quickly causes the pool to go green.
on Aug 11, 2011 | Intex Easy Set Pool 15x36
What is the difference between a filter and a pump in a fish tank?
A filter maintains a natural environment that for fish thatbalances the good and bad bacteria in the tank. Additionally, a filter can remove toxins, chemicals and other unwantedmaterials from the water. The filterworks by taking water in from the tank and returning it clean.A pump is just a pump. It pumps air into the tank and creates bubbles, and sometimes a current. It does not clean the tank or balance thebacteria and PH like a filter does.
May 13, 2012 | Fish
Hi got oase filter and everything just stopped working including the pump please could you give me some advice on what it could be thank you
It could be no power, bad wires, bad controller, bad switch, bad pump. You may have something as simple as a tripped Ground Fault Circuit Interupter (GFCI) breaker or receptacle. That is what I would check first. If you reset it and it trips as soon as you turn on the pump switch then you have a ground fault in the pump. I hope this helps.
Aug 30, 2011 | Oase BioTec 10.1 Filter
I have a solar pump kit using an OASE Aquaflow 1500 submerged unit .The pump will spin when connected to a car battery but when attached to my solar panel which is producing 21 v on open circuit it will...
Hello Phil, what is the size of your solar panel? This pump draws 17 watts so, your panel must be 17 watts or greater. Remember a solar panel only puts out full power when in direct sunlight and facing the sun directly. You can read 21 volts but your amperage may not be full and this is why your pump is not running, not enough amps. I would recommend a minimum of a 20 watt panel.
Feb 14, 2011 | Plumbing
When adding air to a pressure water pump ,i
Sounds like the bladder is gone or inproper air pressure in water storage tank.
Bladder goes bad check it out with step 1
1-
One way to check for sure with everything hooked up. The air valve on top of the tank if pressed you will get water out of the valve which should be only air. This will let you know it should replaced.
If Tank bladder is low in air and not water coming out.
2-If it checks ok put an air gauge to tank to check the air pressure, with a standard 40 gal tank you will have 28 psi of air in tank for it to function properly.
May 21, 2010 | Plumbing
Installing an air pump in a 5000 litre tank
The pump must be mounted nearest the 5000 liter tank. The air intake will be the air sorrounding the area, while the discharge low pressure air must be pipe to underwater level such that the air discharge of the air pump bubble up the water (aerate the water) inside the tank. This is common in fish pond/ shrimps pond/ and water treatment plants. Electrical wiring is
standard for the electric motor and controls.
Nov 04, 2009 | Plumbing
How do i drain my pool with a hayward variflow pump?
To Flush out the filter with the backwash setting. The backwash setting releases trapped particles from the filter back into the swimming pool. You may need to alternate between the rinse and backwash settings until the water runs clear in order to unblock your filtration system and flush out clogs. To Rinse away dislodged items from the backwash setting. The rinse setting flushes clean water through the pipes and carries away any particles or clogs freed during the backwashing. To Drain the pool select waste on the multiport valve. This sends the water directly to the drain rather than back into the swimming pool. Close the filtration equipment and stop the pump with the closed setting. You should only use the closed setting when you turn the pump off. This function allows you to remove the strainer basket, clean the filter tank and perform other swimming pool maintenance on the filtration system.
Aug 08, 2009 | Hayward 1.5 Hp Northstar High Performance...
Garden Logo
212 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
