Question about Boating
Mariner 25hp 2stroke outboard. runs fine when
Mariner 25hp 2stroke outboard. runs fine when idling then after a flat out run for about 5-10 minutes then heats up and cuts out. i think its the impeller but it seems to exspell water fine when running slow. anybody have any ideas?
    Champion:
  • 238 Answers
Change Water Pump Impeller ,
Remove Thermostat And Check To See If Opening In Boiling WAter Clean Ou Any Sand Weed etc, REfit try Again
Posted on Mar 20, 2013
  • 677 Answers
With what you said.get the water pump done.A little bit of rubber is cheaper than metal.If the motor has a few years on it,the pump does need to be replaced.If the motor overheated after a few minutes,the pump needs replacing now.Yours sounds like it's on it's way out.A bit of sand etc. can do a fair bit.Hope this helps
Posted on Sep 10, 2009
2stroke engine cuts out when idling outboard engine
This is typical for clogged carbs, engine will only run when choked...
Have your carb(s) cleaned!
Sep 09, 2016 | Boating
How to find model number on mariner outboard 4hp 2stroke engine
Mariner 4hp are identical to Yamaha engines.
You should find a sticker on the port bracket with serial and model number.
If that sticker has disappeard, an aluminum piece is stamped in the side of the cilinder. The numbervstamped in that round pieceis the serial number. I can convert that serial number in a year/model number...
Feb 27, 2015 | Mercury Marine 4hp & 6hp Stroke Outboards...
Does 1984 25hp johnson at tor need 2cy oil mixed wiyht gas
All 2stroke engines need 2stroke oil in the fuel !!! 50 to 1 mixture ! fuel to oil !...
Sep 23, 2014 | Seloc Johnson Outboards 2002-2007 Repair...
Outboard engine will only seem to run on choke and will not idle on mariner 28hp
Sounds like idle jet is blocked,small brass screw on side of carb not one wit spring,screw that one turn in softly then out one and a half turns
Oct 07, 2013 | Seloc Mercury Outboard Engine Repair...
2001 mercury outboard 25hp 4sroke electric start. will not ldle. l have replaced fuel pump and had carb serviced at dealer. l have replaced the fuel filter twice. l can start with fast ldle easily and drop...
did you mop out the tank , fuel lines and fuel pump etc as water is bad news in a 2stroke ? when in water run engine and set the tickover ON THE CARB throttle stop ! see if it goes in and out nicely just above stalling , you might have to clean the carb again if water in tank !??
Sep 01, 2013 | Boating
1987 60 hp mariner idle & high idle great, stumbles/ stalls in gear on take off, head gasket or poor idle adjustment?
Clogged idle circuits in your carbs. Clean jets and passages.
You can try suck dirt out, therefore: Screw the idle mixture screw out ( almost totally ), give full throttle ( 1 second ) and then hold your hand against the carb air intake.
This will give maximum suction and can suck the dirt trough tje circuits.
Also, first drain the carb(s) to be shure there is no water in it...
Aug 22, 2017 | Light Boating
40hp mariner sluggish
compressions more than 100psi ? carb clean and fuel not older than 5mths ? timing correct ? running on all cylinders ?
Mar 06, 2012 | Light Outboard Motor Boat Bass Fishing...
2stroke 8 HP mercury outboard,newish engine no spark
Clean or change the Spark Cables>
to cleab the pull them out and with antirust spray and clean
May 06, 2010 | 2009 Mercury Mariner Hybrid
I have a Suzuki DT65, all is fine until motor warms up then i loose mid range, it's either idle or flat out, can someone help with this problem.
have a Older DT65 and the MOTOR is clean but wont tur over and sounds like a bearing in grinding or somthin
Aug 12, 2009 | Boating
Boating Logo
510 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
