Question about Garden
Replace fuel lines WeedEater FL 1500 Blower
When I replace fuel lines in my WeedEater FL 1500 Blower. I removed old (broken) lines small parts remained in tank besides filter. Where do these attach to newly replaced fuel lines? one looks to be connector to connect two ends of same line. other looks like a filter.
  • 7 Answers
On the FL1500:
  • The Smaller line goes on the Lower inlet tube on the carborater the other end goes to the gas filter inside the gas tank.
  • The Larger line goes on the upper outlet tube on the carborater the other end goes to a fitting that holds this tube from coming out on the gas tank .This tube is only for Air, it helps fill the primer bulb when pushed.
I hope this helps.
Mechs correct me if I have made a mistake.
Thaxs Jon
Posted on Jul 11, 2010
  • 1 more comment
  • baldwinjimmi Apr 11, 2011
    VERY helpful, thanks a lot, I thought that was the way to do it, BUT not sure, thanks again, Jim.
  • sach_pathak Jul 14, 2011
    thanks for the tip... i was debatign if i should do it or take it to someone more knowledgeable...
  • shharg Sep 14, 2011
    Thanks, very clear and helpful!
  • 3 Answers
The smaller line goes with the filter and into the bottom of the carb. Larger line is to prime or top of the carb.
Posted on Mar 01, 2010
    President:
  • 1,776 Answers
The typical fuel line routingreplace fuel lines WeedEater FL 1500 Blower - 2.gif is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of fuel line goes from the top fitting on primer bulb to top fitting on carburator. Hope this helped and best wishes.
Posted on Sep 09, 2009
I have a FL1500 Weedeater Blower Does the Larger fuel line go on the small fuel filter in gas tank or is it the smaller fuel Line?
Posted on Nov 16, 2009
Replacing broken or perished fuel lines on a Weed Eater is a normal occurrence. I recently found a step by step proceedure and viedo guide on how to do this properly, <a rel='nofollow' href="http://www.weedeaterfeatherlite.com/guides">Here!</a>
Posted on Sep 21, 2013
My blower has a problem that I don't know how to fix. The engine is hard to start. After priming the blower and pulling the cord 8-10 times it starts but only runs for about 30 seconds then dies. It has a W12 carbuerator. A guy at the store sold me the K10WAT kit which did not have adequate parts to repair the carbuerator. Does anyone know what kit is necessary to rebuild the carbuerator? Besides rebuilding the carbuerator, does anyone have other suggestions to fix the ~!@# thing!
Posted on Jun 09, 2010
Blower part stopped working. What could the problem be?
see the steps and fix it. GOD BLESS YOU
  • 1
    Find the cause of the problem. This may be obvious: if the starter cord is broken, then obviously that's your problem. But if you simply have a blower that won't start and nothing apparent to cause the problem, it's time for a bit of investigative work.
  • 2
    Examine the starter mechanism. Is the spring in place? Is the rope wound tightly? If anything is coming apart in there, then your starter won't work properly, and you won't be able to start the machine.
  • 3
    Check the spark plug. If it is old or appears blackened or corroded, it may be keeping the blower from starting.
  • 4
    Check the fuel tank and fuel line. If the cap on the fuel tank is missing, cracked or failing to seal properly, or if you have a leak in the fuel tank, the lack of pressure in the fuel system will cause problems. Check the fuel line as well for any cracks, leaks or stoppage.
Fix the Problem
  • 5
    Repair the starter assembly by removing it from the body of the blower. You can take it to a repair shop to have it rebuilt for a small charge (usually less since you've already removed it), or you can repair it yourself by purchasing a new spring and starter rope, installing the spring and rewinding the rope. Then screw the assembly back into place onto the blower.
  • 6
    Replace the spark plug by unscrewing the old one, brushing away any debris and screwing in a new spark plug.
  • 7
    Replace the tank or line. This is the only way to repair leaks in the tank or line. Be sure you order the correct part (not just any tank will fit any blower) and the right size of fuel line (usually one of the smallest available). If you're not sure, call a repair shop and have the model and serial number of your machine handy. With this information, they can help you find the right parts.
Nov 13, 2013 | Husqvarna Handheld Leaf Blower 125b
WeedEater FL 1500
if the choke needs to stay on to run it then there is a plugged jet in the carb
Aug 11, 2012 | Weedeater Garden
I have a Weedeater fl 1500 le leaf blower that won't run wide open. It will start, but it has to remain at one half to three quarter choke to remain running. Changing the throttle opening seems to make no...
Simple solution your weed-eater has a Walbro carb buy a rebuild kit and rebuild the carb and it will run like new, don't touch any screw settings on the carb. You can purchase from your local repair center just give them the number on your carb and they will give you the correct kit. Go to smalleng.com they have a video on just this issue. Good Luck.. Don't forget thumbs and feedback.
Apr 02, 2011 | Weedeater 2 Speed Gas Blower FL1500LE ()
I bought this blower last week,i tilt it alittle and heard a rattle sound and now it wont start
Check the fuel filter in the tank and make sure the fuel line is connected to it. The carburetor may have inhaled some debris and/or small chunks of broken fuel line and need to be opened up and cleaned also. At this point, you would probably need to install a new fuel filter also.
Jan 15, 2011 | Weedeater 25cc Gas Blower ()
I have a weedeater xt 200 trimmer. The parts in
The tube in the tank is the fuel pickup line and goes directly to the carburetor. You will need to get NEW fuel lines. Fish or shake the old parts out of the fuel tank after draining. Inside the tank will be a small length of smaller diameter fuel line that connects to the small fuel filter and there will be a small nylon line connector that is plugged into the end of the larger diameter fuel line which is the fuel return line from the primer bulb back to the fuel tank. That line ends just inside the fuel tank and is held there by the small nylon line connector. The other line (smaller diameter) needs some length inside the tank so it can flop around as you move the machine enabling it to always pick up fuel. 6" or so is about right from the hole in the bottom (or top) of the tank to the fuel filter. Buy long enough lengths of fuel line that they can be inserted into the tank and pulled thru the fill cap area and then have the parts put back on them and then cut to the correct length from the fuel tank to the carburetor and/or primer bulb. Buy about 1 foot of each size line needed. Small engine repair shops have it and sell it..not expensive.
Jul 18, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Idles but dies when accelerated
Sounds like fuel flow restriction. Since you've replaced the fuel lines already try this....Remove and clean the carbureter needle valves and seats...Blow/**** out the inlet hose fittings ( should be 2 small brass fittings on the side of the carburetor) If you haven't replaced the lines completely (from inside the tank to carburetor) do that now.
Feb 12, 2010 | Garden
I am needing a repair kit for gas tank on the weedeater featherlite 1500 where do I get repair parts at?
I have a Weedeater Featherlite SST and need to replace the fuel lines but do not know where they go is there a diagram that will show me this?
Nov 11, 2009 | Poulan Featherlite Gas Blower, with Low...
Weedeater leaf blower FL1500
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spray withcarb.cleaner.Make sure the small screen is free of debris. (Should beable to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Oct 19, 2009 | Garden
Leafblower
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Oct 18, 2008 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Garden Logo
9,212 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
