Question about HP Office Equipment & Supplies
I have received a fax and it has to vertical lines down the front of it.
  • Steve Allison
    Steve Allison May 11, 2010
    Without a model number given, any suggestion we might make would be a 'guess' since there are several different types of mechanisms in fax machines.
    President:
  • 1,187 Answers
The problem is with the SENDER's fax machine ... not yours...
Your fax machine is working properly...
Note that all faxes from that source will have the stripes, all other faxes that you receive from other sources will not have the lines...
You might send the fax with the lines back to the sender to advise them...
Hope this helps!
Posted on Sep 09, 2009
We are getting black vertical lines on all...Can anyone help?
Have you changed the drum recently? This can indicate the drum needs to be replaced.
Jun 04, 2010 | Brother IntelliFAX 2800 Laser Fax
The printer is printing a line down one side of every page it prints
Are you printing a scan or a fax?
If so, you may want to scan the file as a ".PDF" file. This vertical line is sometimes an artifact of receiving a fax.
Don
Nov 18, 2009 | Ricoh CL4000DN Laser Printer
Dark vertical lines
You have to clean the scanner.Open the dock feeder area,and make sure the scanner glass is clean sometimes the glass look clean but just a smaal dot on the glass can cause a line.Clean also the white area above the scanner.The white area above the scanner help for shading operation of the mchine.Make sure you clean with a sullotion that can remove ink but not damage plastic.
Feb 18, 2009 | Brother FAX-8070P Plain Paper Laser
SF-560R. When receiving and sending Faxes
needs a new toner cartridge probably but the fuser rollers may be damaged as well usually if the lines are indented into the paper that means its the fuser roller if they just appear strait down the page then its the toner cartridge
Nov 18, 2008 | Samsung SF-560 Plain Paper Laser Fax
Poor fax printout quality
I would say you have a bad drum / toner cartridge.
Stuff you receive with vertical lines is probably the sender's dirty scanner.
Nov 04, 2008 | Canon LaserClass 2060P Plain Paper Fax
Line almost straight down center when receiving fax
if you try a internal print such as a report does it go away? if so its more lucky the person sending you the fax.
if you print a report and its on there i would check the ribbon and look for marks, also it could be a transfer problem causing these marks.
Hope this gives you a starts
Oct 21, 2008 | Brother MFC-1970MC Plain Paper Inkjet Fax
Black lines on received faxes
look for a corona wire, close to the drum
  1. Clean the primary corona wire inside the drum unit by gently sliding the tab from right to left several times.
  2. Return the tab and snap it into the home position.
zl42b.gif Note
    If the tab is not at the home position, printed pages may have vertical stripes.
    Jul 18, 2008 | Brother IntelliFAX 4100 Laser Fax
    Trouble shooting
    Hi my mom has a brother fax machine. When printing it puts a vertical line straight down the middle. It takes the carbon paper and I noticed underneath there is a black nob thing that sticks up and that is whats making this line why and what to do? Thanks vicky
    Nov 12, 2007 | Office Equipment & Supplies
    37 people viewed this question
    Seeker5211
    Seeker5211
