Kenmore 64902 Electric Dryer
Problem for Kenmore 64902 Electric Dryer
Kenmore Dryer won't heat.
By kyriell24 on Sep 09, 2009
4 yrs old. Has done this before and started heating again - not this time. Filter is clear. Haven't been able to access vent because of location.
Best Solution
posted on Sep 09, 2009
Very Helpful)
localwonder
Rank: Guru  Kenmore Washers & Dryers  Expert
Rating: 92%, 2907 votes
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Was this helpful?
Yes
No
4 people thought this was helpful
Asker's Testimonial
" Thank you. I'll check everything you suggested. " - kyriell24
Solution #2
posted on Sep 26, 2009
Not Rated)
RPrez
Rank: Apprentice  Washers & Dryers  Expert
Rating: 0%, 0 votes
I am attempting to remove the rear panel to my dryer, when I removed the screws the panel seems to be sealed, do I have to "unstick" it off the back?
Was this helpful?
Yes
No
Popular Solutions for Kenmore 64902 Electric Dryer
Questions and Unsolved Problems for Kenmore 64902 Electric Dryer
Do you recommend Kenmore 64902 Electric Dryer?
Answer
Answer
cycle switch works in cycle and turns off when complete. Problem is dryer starts when door is closed... (More)
Answer
dryer timer sounds like it is running but it doesnt tumble
Answer
Dryer starts on its own and then will not work when I need it to. it is crazy but suddenly the dryer... (More)
Answer
Kenmore electric dryer model 110-620-36100. When it works, it works fine, but has been acting... (More)
Answer
my maytag dryer Model # MDE9206AYW will randomly decide to not shut off it will run hot until I... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryers Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
