Question about Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player
Dont kwon what corol wire go together on pioneer mp3
  • lethalslug1 May 11, 2010
    i don't understand
  • yadayada
    yadayada May 11, 2010
    what color wire goes to what component, you don't say, is this a car?
  • 85 Answers
Black is ground red is key switch yellow is memory constant power blue is remote,violet is RR positive and violet with black is positive.green is LR positive and green black is negative,gray is RFpositive and gray black is negative.white is LFpositive and white with black is negative.
Posted on Sep 14, 2009
My pioneer won't turn on in my car. I have the wiring harness and all thst plugged together but it won't turn on
what car? make? model? what year?
check feeds at terminals and then fuses if no voltage.
if it is a modern car and has MOST connectors and not ISOs, then it may not have an ignition on/off
as modern cars use a CAN-CODE on/off.
Nov 12, 2010 | Pioneer FH-P800BT Car CD/ MP3 Player
It will not turn on when i connect all my wires together.
check your power source...try red and yellow together and the black...you can tap them to the battery to check power...there may be an issue with the fuse...inline or on the deck also check your auto fuse box... if you get power on the battery but not on the actual radio wires (in dash) the problem is easily solved got to walmart purchase a $4 spool of 14 or 12 guage wire and run a "hot wire"...you could also run a toggle switch to the accessory wire(red) to control the pwer( not the memory"yellow")
Feb 22, 2010 | Pioneer DEH-P2900MP CD Receiver...
Hey, I am installing a pioneer 1100mp with adapters I purchased from walmart. I wired everything together and now when I hook it up the interior lights do not work and the radio has no power. what am I...
sounds like you may have a shorted wire . make sure you tape up all unused wires seperatly. so they dont short to each other. also helps if you could tell us what kind of car you have
Feb 13, 2010 | Pioneer DEH-1100 CD Player
What colour wires do i need to use to wire up rear speakers on a pioneer 2000mp headunit
should be listed on the unit itself, however if youre attempting an install there are vehicl specific plug-n-play kits available that cure these headaches with out breaking the bank, and they can be found starting around 10.00 and you dont need to hack up your factory harness to install after market equiptment
Jan 17, 2010 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
I don't know how to wire this pioneer deh-p2900mp
the wires will not be the same. the best thing to do is go to the nearest place where they sell radios and they do have to sell the two plugs that have the same wiring diagram as the radio and then direct connect to the two plugs on the car.
Sep 11, 2009 | Pioneer DEH-P2900MP CD Receiver...
Installin used headunit in 97blazer dnt know wat wires go where?
you need wiring harness for your truck to the radio go to your local bestbuy or car audio shop then follow color coded instructions for the wiring
Aug 13, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Got a new deh-6000ub and wire harness for honda accord dont know how to install the harness
You need an installation harness. You can get them at most anyplace that installs car stereos. Once you have the installation harness for your car, you just match up the colros of the wires on it to the same colors of the harness for the Pioneer. Make sure that each wire is insulated from anything by using some electrical tape and make sure they all have good connections. Strip away close to about an inch on each wire and then twist them together and then tape them good. After all the wires have been connected, all you need to do is plug the Pioneer harness into the Pioneer radio and then plug the installation harness into the factory wire harnees connector in the car. If you have any wires that do not match up in color, you can normally leave then not connected to anything, but make sure they are insulalted with electrical tape. Most all the wires should say what they are for. Matching the colors is the easiest way to do this.
Let me know if you need more help. I can always give you a detailed wiring of the Pioneer. I do not have the wiring diagrams for the car though.
Jul 20, 2008 | Pioneer Car Audio & Video
Pioneer DEH-1100
Dont connect wires together randomly or you WILL damage the head unit. You need to get a multimeter. It will show you which wires have voltage and which wires are connected to speakers. I've found that old Pioneers have the same colour codes as new ones. So:- Black Chassis and negative. Red ACCessory switch (key) Yellow Constant 12v Orange Lighting Blue/white Auto antenna relay White Front left + White/black Front left - Gray Front right+ Gray/black Front right- Green Rear left + Green/black Rear left - Violet Rear right + Violet/black Rear right -
Apr 14, 2007 | Pioneer DEH-1100 CD Player
Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player Logo
48 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
