Question about Dell 924 All-in-One InkJet Printer
The paper is stuck on the rollers and jams up every time i try to print it
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 115 Answers
Try to open the printer and clean it, if the probleme perciste you must have a help of expert.
good luck
Posted on Sep 09, 2009
HP laserjet 1518
HP printers frequently time how long a page takes to run through the machine. If it is too slow, they signal a jam error.
Try cleaning all the rollers and pinch wheels etc within the laser.
Dec 10, 2013 | HP LaserJet Office Equipment & Supplies
Hello paper jam error appears with no paper jammed. Then printer refuses to print or doesn't print well
To resolve paper jam issue, follow the steps
1. Open the rear access door.
2. Remove any bits of paper stuck.
3. Clean the rollers using lint free cloth ( upward position )
4. Close the rear access door
5. Open the front panel door
6. Check for any paper stuck between the rollers.
After doing all these steps, to make sure if your printer is working fine, try to make a copy.
If the printer can make copy, Click on the link to resolve printing issue -> Link
Oct 12, 2010 | HP Photosmart 2575 All-In-One InkJet...
The paper twists and causes a jam on every print
sounds like something jamed in the rollers like a pin etc
Jan 05, 2010 | Epson Stylus R265 InkJet Photo Printer
Photo paper cannot print
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Oct 05, 2009 | HP Office Equipment & Supplies
The paper gets jammed when I'm duplex printing
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Aug 19, 2009 | OKI C6100n Laser Printer
Paper pulls to the right, jams, won't print, tried different paper still won't print
Hope that helps!
PREM
May 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Hp photosmart 2410xi - paper won't feed properly through, jam
Go to an office supply store and pickup printer cleaning sheets. They are sticky on both sides. You run a sheet through it a couple of times to remove paper dust from the rollers. The pickup roller is so slick it is drawing in more that one sheet of paper. Cleaning the rollers and the paper path will solve your problem.
Mar 18, 2017 | HP PSC 2410 All-In-One InkJet Printer
Paper Jam
hi y'all -
you share a frustrating problem... error message but no apparent error (jam)! it's one that's common to many models of printers and the result of many different causes.
I've seen it when I've printed on cheaper paper, or different (lower) grades with odd surface finishes. the sensors get dirty, or the printer/computer 'thinks' there's paper stuck where none exists. I've opened/closed paper trays 2-3 times and rolled feed rollers around multiple times, then closed printer paper drawers only to have the 3rd time of doing the exact same steps be the time it cleared the error message.
there are often very tiny pieces of paper stuck in weird places in the paper path in printers, too. if you did have a jam before the message started, is every little scrap of the page accounted for? there are also hard to get to places to find paper scraps in larger printers, but I'm going to assume you're all talking about home printers.
here are a few general HP support links you may find helpful for future paper jam messages for this model of printer.
this link is for general info for this model:
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&dlc=en&product=304535&lc=en&jumpid=reg_R1002_USEN
this link is for general support for this model:
http://h10025.www1.hp.com/ewfrf/wc/solveCategory?lc=en&dlc=en&cc=us&product=304535
here's a link addressing paper jams in general:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud09189&lc=en&dlc=en&cc=us&rule=26353&product=304535
and here's one on cleaning your printer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00016484&lc=en&dlc=en&cc=us&product=304535
hope this helps a little bit for future refs. remember that using good paper helps print quality and lessens printing problems. also, when you take a stuck page out of a printer, doing so gently will help ensure little scraps of paper do not tear off paper edges and get stuck in weird spots. it some times helps to gently, manually, roll the feed rollers a full turn around in the printer, too. patience pays! -JW50
Sep 02, 2008 | HP DeskJet 3650 InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
32 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
