Question about RCA F38310 38" TV
Rca..model f38310 no power no fan ,nothing how much do you think it will cost to fix...is it worth it..
  • dstechman Dec 11, 2007
    Solution #1
    posted on Dec 11, 2007
    By dstechman
    Rank: Apprentice
    Rating: 0%, 0 votes
    My set just recently went through the same problem. I found a bad connection on the power board and a burned diode as well. I repaired the conneciton but have had no luck getting the specs on the burned diode. RCA has been no help.
    As for cost of repair, on serviceman quoted $50 just to come take a look.
  • Anonymous Dec 22, 2007
    Same problem. did not open to investigate. Iwas not home at the time but was told it hummed loudly for a while and then turned off.
My set just recently went throgh the same problem. I found a bad connection on the power board and a burned diode as well. I repaired the conneciton but have had no luck getting the specs on the burned diode. RCA has been no help.
Posted on Dec 11, 2007
I cut the RCA model F31672ET off and now I get nothing. It simply does not cut on. Before I cut it off the picture was getting very dark and I could not control the sound. Family members say it's not...
It sounds like your power supply board has gone out. This is a fairly common issue, and the repair will cost you around 175-300 dollars at a repair shop.
Mar 19, 2011 | Televison & Video
No picture/no sound. fan working
I have done some research and found a notorious cap and diode problem with this set. The two 4700uf caps (C14113 and C14115) on the DM1 power board (the board to the left of the sat. box when you look at the set from the back) are under rated and will eventually fail. When these caps fail they tend to take out diode CR14105. This may be your problem. If it is, you can replace the caps with 4700uf 25V 105c and the same as original diode.
May 10, 2009 | RCA F38310 38" TV
SETUP RCA F38310 TO DISH NETWORK
using your Dish Network box connect the audio and video outputs to the tv via the RCA inputs1, 2, 3, or component inputs on the tv and then select the coresponding video input to view your cable. Or you can connect your Sattelite to the antenna A or B input jack on the back of the set and set the tv input to antenna
Apr 14, 2009 | RCA F38310 38" TV
Rca television (f38310)
using your cable box connect the audio and video outputs to the tv via the RCA inputs1, 2, 3, or component inputs on the tv and then select the coresponding video input to view your cable. If you do not have a cable box you can connect your cable to the antenna A or B input jack on the back of the set and set the tv input to antenna
Mar 23, 2009 | RCA F38310 38" TV
Direct satalite failure
If the tv works and its just the sattelite portion of the tv that doesn't work you can alway just use a new sattelite box and connect it to the tv via the rear inputs on the tv and then just select the coresponding input to view the sattelite chanels.
Dec 28, 2008 | RCA F38310 38" TV
My RCA F38310 doesn't seem to want to turn on all the way.
Sometimes mine will sort of go into a "loop" powering off/on similar to what you describe. Physically unplugging the set for a few minutes, plugging back in solves my issue.
May 22, 2008 | RCA F38310 38" TV
More info on my RCA F38310 38" TV
Thanks for the reply.
Go to this site and browse through their stock of parts for this TV model. You can give them a call as well if you do not see what you are looking for.
Good Luck.
Apr 13, 2008 | RCA F38310 38" TV
CRT
the cost will far exceed replacement value if the crt is faulty.
Apr 08, 2008 | RCA F38310 38" TV
Noise
That fan is in the tuner section which houses the Direc TV part as well. It runs no matter what you do and should NOT be disconnected by any means.
Apr 17, 2007 | RCA F38310 38" TV
RCA F38310 38" TV Logo
161 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
