Question about Samsung WF328AAW Front Load Washer
How to replace the door diaphragm on a Samsung WF328AAW front load washing machine. It has a small tear that is causing leakage down the front of the machine.
  • 1,531 Answers
Remove the lid.then you need to take off the control panel move it out of the way.there will be a spring that holds the boot in place on the front where the door closes remove this spring the rmove the boot from the front panel then remove the front panel.there will be another spring that holds the boot to the drum.i have found it easy to remove the counter balance weights to remove and reinstall the new boot. i hope this helps sounds like alot but not real bad
Posted on Sep 19, 2009
Tub is rubbing door seal. Should it be doing that?
no it shouldent...........more likely the rear bearing is on its way out.......or maybe the suspension legs are shot at.....good luck
Oct 09, 2016 | Samsung WF328AAW Front Load Washer
I have a Samsung front load washing machine wf328aaw/xaa. the washer stops when it gets to the drain function. The drain pump motor is not getting the 120 to run the motor. I removed and tested the
There is a water level sensor that could inhibit the operation of the pump if it is indicating that the water level is low. There is also a small relay in the control panel (on the control circuit card), which may have dirty contacts. That is the contacts are not closing properly. Unfortunately, this relay is not readily accessible to consumers and even quite difficult to service for the professionals. I posted a description of the repair or cleaning of the contacts on the question placed by another user "My Drain Pump Doesn't Work"
Oct 19, 2014 | Samsung WF328AAW Front Load Washer
Samsung washer WF328AAW/XAA metal pieces in hose?
Could be a number of things. Either something foreign was left in a pocket (Coins are the most common object) and has come out in the wash. The coin rattles around and falls in between the tubs through the gap in the front gasket. When this happens, the coin can hit the bracket which holds the heater element in place and tears it off. This causes a lot of damage. Most Samsung have plastic outer bowls and often, the tub will be split and a leak will start from underneath. Lastly, it could be the drum main shaft and spider assembly. This is what holds the spin tub into the machine. If this fails, bits of metal will come off. Usually seen as bits of corroded aluminium that get stuck in the pump and hoses. When this happens, the tub usually goes loose and the machine makes a horrible grinding and banging noise when spinning. I would say that if this has happened , its time for a new machine.
Sep 10, 2014 | Samsung WF328AAW Front Load Washer
Where is the debris filter in a samsung washer WF328AAW/XAA
you take the plug out
take the back off
it should be between the tub and the pump ((take the hose of and clean it))
Feb 02, 2014 | Samsung WF328AAW Front Load Washer
3e error code washing
3E is an error code related to the motor speed or speed sensor. It could be a bad motor, or perhaps a foreign object impeding motor function. Depending on your expertise, you could tear down the motor assembly and check for problems, or else contact a repair technician. Given that it's happened twice, it will likely happen again.
Dec 19, 2013 | Samsung WF328AAW Front Load Washer
How can I best access the pump on my Samsung front load washer? I don't know how to remove the front panel
Some samsung washers have the water pump located in the back of the machine. If your model does not have a small door located in the bottom of front than remove back service panel to access the water pump.
Jun 21, 2017 | Samsung WF328AAW Front Load Washer
Samsung frontload washer fashing nd code
The ND code means not draining
The older versions of this machine did not have a debre filter, but in later versions a drebe filter was added . It is on the bottom right of the front panel. Open the door. Pull the cap off the drain hose and drain water into pan. Remove filter cap. Wash filter off and don't block propeller when replacing filter cap. Insert cap back in drain tube.
Jun 04, 2011 | Samsung WF328AAW Front Load Washer
Samsung WF328AAW Front Load Washer Logo
2,034 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
