Acer Aspire 4810T internet connectivity problem
I have had this computer for 16 days. I am about ready to pull out my hair. Whenever I boot up the computer, it says that I'm connected to my wireless network, but my browser [Internet Explorer] doesn't go anywhere. Everytime I boot up, I have to disconnect and then reconnect to the same wireless network. Then, sometimes, I can connect with websites. I have called Acer support who wanted to reformat the hard drive! A new computer! I was able to download a LAN wireless network driver, installed it. Same thing. Does anybody have a fix for this?
Touchpad, mouse and keyboard not working
Try installing the touchpad driver from here http://www.helpjet.net/files-Acer-Aspire-4810T.html#ATouchpad
Once you are done restart your Acer and see what happens.
If this doesnt resolve the issue it may be a problem with the hardware in which case you may need a new touchpad. otherwise just use a mouse as a fix either temporarily or if it turns out to be to expensive to fix.
Aug 17, 2014 | Acer Aspire 3810T 4810T 5810T
Acer Aspire 5733 Wireless connection lost
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
hope this helps
Sep 13, 2012 | Acer Aspire 5733 Laptop
Reset acer 4810t
You can start the Recovery from outside windows by holding down the ALT key and tapping F10 repeatedly
on startup. When the recovery loads you will be prompted for a password.
This should have been set by the customer if they have been into the Acer Recovery Management software previously.
If they have forgotten the password or you wish to clear the password you need to boot off the recovery disk that should have been created.
More Information
From the Acer toolbar at the top of the desktop click on the disk icon
Setup a password if requested.
After clicking on setup you need to click Create Password to continue.
Create a password and add a password hint (strongly recommended).
You now have the option of restoring from a previous Windows Vista backup or you can start the Acer recovery process.
The recovery is started by clicking Restore at the bottom of the window.
Further types of recovery are now presented.
Choose Restore system to factory default if you wish to run the hard drive based recovery and return your Acer computer back to it's original factory default state.
Note: The factory default recovery will wipe ALL data from the computer so ensure important data has been saved to disk before proceeding.
Enter the password that was previously set.
Confirm you wish to run the recovery process.
After confirming you wish to run the recovery process the computer will restart and restore all the original files
Complete the Out of Box Experience when prompted
After a couple of restarts the computer will run through restoring the preinstalled software that came with your computer and then be ready to use
hope this helps
Jul 27, 2012 | Acer Aspire 3810T 4810T 5810T
Acer 4810t. how do I turn on the bluetooth
Check your Device Manager to make sure you computer has Bluetooth capability. If there is no Bluetooth in your control panel, you may have to install the drivers and use the software. You can download the drivers and software from here for the 4810T:
http://global-download.acer.com/GDFiles/Driver/Bluetooth/Bluetooth_Broadcom_6.2.1.800_Vistax64Vistax86W7x86W7x64_A.zip?acerid=634024298954715268&Step1=Notebook&Step2=Aspire&Step3=Aspire%204810T&OS=V10&LC=en&BC=Acer&SC=PA_7
Mar 27, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
Looking for a user manual for acer aspire 4810T
Below is a link to the Acer support webiste for your Aspire 4810T. It gives you support documents and downloads.
http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
I hope that you find this information helpful. If so, please leave feedback to that effect.
Thank You,
Brian
Jan 25, 2010 | Computers & Internet
Acer 4810t ...does not load bios...and blank display
my acer 4810t does not load xp. it shows bluescreen error. than says use chkdskoption what can i do??
Dec 13, 2009 | Acer Aspire 3000 Notebook
Wi fi on ACER Aspire 4810T connects intermittently
Log into your router and change the channel and see if that helps. Failing that try rebooting the router to factory settings and deleting your connection from the laptop. Then start from scratch again...Hope this helps...Please let me no...
Nov 17, 2009 | Acer TravelMate 4062WLMi Notebook
Acer 4810T w/Vista it will not stay connected to internet
i doubt its your unit. if it shows your connected, your connected.wireless routers often loose signal. even if you have a cordless house phone it could easily interupt with your signal also. a lot of times it could be your service provider.
Oct 15, 2009 | Computers & Internet
ACER LT 4810T does not connect to the Internet after I ran your program for recover discs. Returned a new computer 4 days ago for same problem. This is new. Same problem. HELP janlusc@cfl.rr.com
CHECK YOUR INTERNET CONNECTION WITH ANOTHER COMPUTER OR CALL YOUR INTERNET PROVIDER TO DIAGNOSE YOUR PROBLEM. UNLIKELY 2 NEW COMPUTERS WOULD HAVE THE SAME EXACT PROBLEM IN SUCH A BASIC AREA.
Aug 20, 2009 | Computers & Internet
Acer aspire one hard disk cannot read
Check the BIOS configuration for the hard disk, if the BIOS does not detect the hard drive then the hard drive is faulty or the disk controller is faulty.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. This computer should detect the hard drive as an external disk drive. If this computer cannot detect it and/or cannot open the folders etc. the the hard drive is faulty.
Then you need to install a new hard drive in the Acer and install Windows, the device drivers and your programs to get the laptop operational again.
Aug 19, 2009 | Acer Aspire One D150-1587 Netbook
Computers & Internet Logo
501 people viewed this question
David Payne
David Payne
