Hi,I have a BANG&OLUFSEN (Beocord 5000) tape deck and need new belts for it 3 belts in all. Can you help Regards Paul
5 Suggested Answers
kevin000
  • 1847 Answers
SOURCE: Replace a Tape Deck Belt
. Remove top lid (4 screws on the side)
2. remove the back plastic mount on the mechanics (2 pink long screws on the top). The bottom are two plastic hook lock. The mount pulls back and the belt and pulleys are exposed. NOTE: It is the mount you are removing, not the tape deck itself.
Posted on Jul 05, 2008
robotek
  • 1512 Answers
SOURCE: Gx-77 Akai reel to reel tape deck -belt
G'day Chidu
You can buy a replacement belt kit with the correct belts for your model from here
Thanks for using FixYa, a FixYa rating is a great reward for locating this part for you. Good luck with the repairs, and happy listening.
regards
robotek
Posted on Sep 11, 2008
Grubhead
  • 5113 Answers
SOURCE: i need to replace cassette drive belts on my bang
CPC may hold parts for B & O products. They are online, so you should be able to access the site. However I don't know if they only deal with trade. If they won't deal with you (because your just an individual) and they do stock the part, why not ask a local TV repair shop to get it for you from CPC. You will probably have to pay upfront, but it might solve the problem.
Posted on Oct 07, 2009
Grubhead
  • 5113 Answers
SOURCE: replacement drive belts for Sony HTC-H2900 tape deck
CPC, Chas Hyde, Willow Vale, Wizard.
Or you can measure the diameter of the belt and enter it into google. IE 60mm drive belt.
Posted on Jan 05, 2010
Beocord 7000
belt kits are available on the internet and the mech is fairly easy to get out to work on
Jan 18, 2014 | Bang and Olufsen Audio Players & Recorders
Beocenter 7007 lights but no power
It is likely the audio output ic has failed, check the speaker wires for shorts, if okay! you will need a professional to take care of this.
Mar 21, 2012 | Bang and Olufsen Beocenter 9300 Shelf...
I have a beomaster 5000 which will cut out at any time sometimes it goes for ages,other times it will go almost immidiately,also i have the beogram 5000 and the cueing function doesn't seem to raise the...
O.k. The Beomaster 5000 needs new Quiescent current presets , you can temporarily solve the problem by turning the two presets (in the main amplifiers) fully anti - clockwise .
Your beocord needs new belts for sure .. availiable from CPC of Preston .. Hope this helps ..
Oct 29, 2010 | Bang and Olufsen Beosound 2000 Shelf...
Beocenter 7002 tape deck starts and clicks off within 2 sec.
If the take-up spool (r/h) doesnt turn the autostop will activate.Both these spools get clogged with old grease with age, remove and clean/regrease them,check all belts while apart and replace any limp ones.Removing the tape deck requires some knowledge.
May 09, 2010 | Bang and Olufsen Beosound 2000 Shelf...
Need the elastic band that helps run the tape deck. using a bog standard band from work but not sure how long this will last. any ideas regards spares???
Have you kept the old belt? If so measure the diameter and then look around the net for "Belt ??mm". If not measure the diameter of the one you have in.
Belts are standed and are not specfic to any machine.
Feb 17, 2010 | Bang and Olufsen Beosound 2000 Shelf...
Can't operate the turntable and tapes. Radio OK This is a Beosound 2000
its likely you have 2 seperate faults.parts for the tape deck are discontinued.check belt on turntable, if its ok not much else can be done,no spares!
Jan 04, 2010 | Bang and Olufsen Beosound 2000 Shelf...
I need to replace cassette drive belts on my bang and olufsen beocentre5000 unit but unable to locate an outlet.i am currently resident in spain
Sep 24, 2009 | Audio Players & Recorders
Hi is the cassette player in the 5000 stacking system belt driven regards cliff
beocord 5000?. if so yes.there is a capstan belt clutch belt and a counter/autostop belt.there is also a deck in/out belt.
Sep 18, 2009 | Bang and Olufsen Audio Players & Recorders
BANG AND OLUFSON BEOCORD V8000VIDEO RECORDER TAPE WILL NOT EJECT
turn the motor pulley at the far right corner this is the load/unload motor.unfortuneately the gears in this assy are often the cause for a jammed tape.take to any vcr specialist as the deck is a phillips (turbo) model and well known to engineers.
Apr 15, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
Bang & Olufsen Audio Tape Player Seized Up
probably needs belts but parts are discontinued.
Dec 27, 2008 | Bang and Olufsen Beosound 2000 Shelf...
167 people viewed this question
 Grubhead
Grubhead
