Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
My trimmer won't rev up
My trimmer worked fine for a few months. Now when I give it gas it acts as if it's getting too much or too little gas. I tightened the 4 screws on the carburator a little bit. (the pushbutton section) They seemed a bit too loose. Worked good again for a couple weeks. Now it's doing it again.
  • mw1955 Sep 12, 2009
    Fixed it with no help from FixYa.
    Opened the carburetor up and found a very tiny bit of junk blocking the fuel jet/orfice.
  • mw1955 Oct 10, 2009
    This is a new trimmer. Maybe 6 weeks old at the time. The problem was a small grain of sand found in the jet. I blew it out and viola, it works just fine. I actually found this right after I posted the problem. But thanks for responding.
  • 7 Answers
SOURCE: Troy Bilt trimmer model # TB575SS no high throttle
Dont replace the carb! The gaskets are what wear out on walbro carbs and the like. Specificaly the fuel inlet membrane which is under the removable plate opposet of the throttle plate.It is a black gasket with a small metal button in the middle. This regulates the fuel supply. If if is still flexable then it is good. Usually they become crisp after sitting for a couple years. Start with a gasket set( 5 to 10 bucks) Then try adjusting your fuel and air mix needles if need be.
Posted on Jun 08, 2009
  • 16 Answers
SOURCE: troy bilt 4 cycle string trimmer wont stay running
If this is an old unit, then the diaphragm is probably hardened.
Tests before hand would be:
1. Is the gas fresh and water free?
2. Is the spark-plug clean and snugly fastened?
3. Are you using the correct gas to oil mix ratio in your fuel?
4. yes...yes...yes...= bad diaphragm. Probably less than $5 for the part and a 1/2 hour to replace the part.
Posted on Jul 07, 2009
Dolfoff
  • 148 Answers
SOURCE: i am able to crank the trimmer but it does not
1) Change out the old fuel (not just adding fresh but pouring out the old and replacing it entirely) and check the engine oil.
2) Check muffler and/or spark arrestor screen for restrictions.
3) Clean and reinstall spark plug (check gap).
4) Replace inlet screen INSIDE the carb. (It is located directly under the inlet needle.)
Try each of these as needed.
Hope this helps!
Posted on Oct 01, 2009
bustech17
  • 38 Answers
SOURCE: TB70ss Trimmer runs but does not turn the string
Remove the angle drive gearbox near the string head and spin it to see if everything is moving properly. You may have stripped the gears out of it.
Posted on Sep 23, 2012
hunter19_46m
  • 7482 Answers
SOURCE: Troy Built gas trimmer won't start
Hi Kevin Whitaker
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Then follow the procedure below:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
I will also include a drawing of how the fuel lines connect
Please take time to rate me
Bud
Posted on Oct 15, 2012
I have a Bolens BL110 Trimmer - it starts just fine, but won't rev up completely. Suggesstions?
Could be blocked spark arrestor or carboned up in the exhaust port.
May 06, 2012 | Garden
Have a new craftsman edger, 27cc 2 cycle. Have used one time. Worked fine. Now trying to use again and won't keep going when cranked.
If it worked the first time you used it, what changed since then? It sounds like you have old, dirty or water in the fuel. Is this possible? I need a few more details on how it acts to help you.
Jim
Aug 07, 2011 | Craftsman 25cc Gas Line Trimmer
'04 Kymco Venox won't start. Bought it a few months ago from someone w. about 20,000 miles on it. Always runs good/never had a problem w. it 'til yesterday. Ran outta gas on the road...put more...
Hi Mrcherry99, for this situation I would call my local dealer or reputable shop's service department and inquire about any possible quick fix. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if possible, and give you a written estimate of repairs and answer any specific questions you may have about your issue. Good luck and have a nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 18, 2011 | 2005 Kymco Venox 250
What setting should it be when i begin the start process. also it seems to have a slight hesitation when i engage the trottle
Two stroke gas equipment needs a good long warm up. The heat is part of the deal. Set the choke on full chioke. Prime the bulb till you see the bulb is full. Turn the kill switch if you have one to "on" and fire it up. let it run at idle as long as it will or for a minute on this choke setting. If it dies restart and let warm up. When it is running ok but a little bit boggy then move the choke to open or half and give it some gas. If it responds then go to full open and crank it up a few revs. If it bogs or dies your unit will need service. The diaphragms in the carb are replaces as a kit and run about $6- 10. They are also easy to do if you can read and hold a screw driver. These go bad from fuel hardening every 14 months or so along with the primer bulb and hoses. Get all of this online from parts stores. Whole repair makes it like new forabout $15.00 or let someone do it for you for about $ 50.00.
Sep 08, 2010 | Homelite Factory Reconditioned 26cc...
Holds idle fine but stalls when accelerating
your carburetor should have a fuel filter in the carburetor body where the
fuel line enters it replace it and, any other in-line fuel filter the engine might have
Jul 25, 2010 | 1986 Jeep Cherokee
I have a new Stihl FS90R Trimmer...Idles fine but dies when given gas to rev up. Tried to adjust the carb out. Did not help. I have two of these.Changed the carbs and the same thing happened. The same carb...
My nephew had a problem with his Stihl FS55R trimmer, sez it would run on high for a few then quit. Sez it restarts easy and runs on idle with no problem. I pulled carb & found fuel screen full of fine contaminant. This is the screen you see when you drop the bottom pan of the carb. (single screw does it). Reassembled and the trimmer runs on high speed w/o problems. If your primer bulb doesn't pop right back up when you punch it down, it means that the fuel can't get past that screen....
Nov 07, 2009 | Garden
I have a Shindiawa T-27 weedeater.Everytime i give it gas,it stalls.Idles fine but stalls as soon as you hit the gas.i put clean gas a new plug in it no good.
Depending on how old this unit is, you should be able to adjust the hi/lo speed needles on the carb. If it is so new that they have a strange head rather than a screwdrive slot, you will have to experiment to find something that will turn them. Sounds like you are not getting fuel when you open the throttle. Other than that, probably a carb cleaning would be in order.
When turning the fuel needle, you just want to turn it about 1/4 turn then try to give it the gas. You are going to be turning it out, or counter clock wise. Once you get it so that the engine will rev, try giving it fuel 2 or 3 times very fast. If it bogs down or acts like it is going to die, adjust the needle a bit more.
Oct 21, 2009 | Husqvarna 28cc Gas Line Trimmer
Lawn trimmer runs but won't rev
You need to clean the carburetor. Remove & disassemble. Use a Den Tek Brush,
(http://www.shopping.com/xPO-Lustrasilk-Lustrasilk-Cholesterol-Shea-Butter-Mango-20Oz-Bonus), to clean small portals in carb. Spray carb. with carb. cleaner. make sure the small screen in carb. is free of debris. Reassemble and start. If this doesn't work, buy a carb.kit and replace the needle valve, gasket(s), small screen, & diaphragm.
Jim
Jun 06, 2009 | Craftsman 25cc Gas Line Trimmer
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
432 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
