Question about Citoh EZ-2C Thermal Printer
Badinjection On acceleration power intermittent, or coming and going. Also loud noise or growl coming from engine on initial acceleration. Also revs jumping from 750 to 1200 coming in idling position. My car is 2009 .. 140 bhp 2litre diesel exclusive Citroen c5..
When I press the accelerator there is a noise inside the car as though the fans have been turned on
If your battery is weak, the accelerator will boost the cars 12v power enough to speed up your fans if they are on...otherwise, maybe you have a driver - passenger area firewall hole...will really sound loud when you rev the engine.
Oct 19, 2014 | 2009 Ford Focus
Loud clicking noise on accelertion only.
Have you checked your intake cam. Mine started clicking when my cam got wiped.
Mar 31, 2013 | 2005 Lotus Elise
Loud Vibration / Sound Under Acceleration And Starting Engine.
Get the engine mounts checked. A bad mount may allow part of the engine to lie on a body or frame part, allowing engine vibrations to become very loud. Torquing of the engine (under load) can cause the same type problems.
May 03, 2017 | 2005 Dodge Neon SE
1997 expedition after i go over 40 miles engine is growling shifting but a littlle sluggish
I have had similar complaints that turned out to be the Idle Air Control (IAC) solenoid. The solenoid can get a little weak and air coming in through the intake at certain speeds can cause it to start vibrating. It sets off a moaning sound that resonates through the intake ducts and can get VERY loud. Sometimes it almost sounds like a fog horn.
If this is the type of noise you are hearing, replacing the IAC will fix it.
Other than that, the only suggestion I have is to see if you can get it to make the noise while the vehicle is sitting still. Slowly accelerate the engine speed with the vehicle stopped and the transmission PARK to see if it will make the noise. If the vehicle has to be moving to make the noise, then that eliminates several possibilities like the IAC, fan clutch, pullies, etc.....things that operate the same whether the vehicle is moving or sitting still.
Nov 22, 2011 | 1997 Ford Expedition
Growling engine noise only at idle. Cam area
Take all of the belts off for a short run at idle. If the sound goes away it is pulley related, spin each pulley and listen for bearing noise, also check for play at this time.
If the noise does not go away when the motor is driving no accessories you have a more serious problem.
Jan 13, 2010 | 1991 Oldsmobile 88
Loud acceleration noise in my 2003 Mazda 6 2.0 auto
one thing to check is rear engine mounting i have had a stone wedged in one and it causes a nasty noise when accelerating
Apr 12, 2009 | 2003 Mazda Mazda6
Whinning noise
possible power steering pump.
Feb 04, 2009 | 2004 Toyota RAV4
Loud noise while driving
It is your Wheel Bearings. I just changed mine out on my Grand Am with the same problem. Now I have no humming noise.
Jan 15, 2009 | 2004 Pontiac Grand Am
Loud Intermittent Droaning Noise
rear axle to ring gear side bearing is loose due to weak preload. might be able to locktight is its not to late. was in bmwmoa memeber mag this month december08
Nov 30, 2008 | 2004 BMW R 1150 RT (ABS)
46 people viewed this question
Top Citoh Office Equipment & Supplies Experts
k24674
Are you a Citoh Office Equipment and Supply Expert? Answer questions, earn points and help others
