Hello For some reason my toshiba MK6032GSX is no longer reading cd or dvds I place in the drive, it has been working fine for the last 3 years now all of a sudden I place a CD or DVD in the drive and it does not read it just stays on "DVD-RAM Drive (D:)"
  • 1 more comment
  • fitz11118 Sep 10, 2009
    Hi
    When you switch on the laptop, and when you put a disc in the Laptop the drive spins up and try's to read the disc.
    Hi
    Tried this, but after restarting the Laptop and the driver re-installs DVD Drive, but still it cannot read CDs or DVDs.
  • Dick
    Dick May 11, 2010
    Does the drive spin up and try to read the disc, or does it not recognize that a disc has been inserted? Have you cleaned it recently?
  • 36 Answers
Try uninstalling the device and drivers and re-installing them. Restart your computer and you should be fine.
Posted on Sep 10, 2009
SOURCE:
I have bought a second hand toshiba external cd player xm 1902b. it wont play dvd's. is it not set up to do so?
This is a CD-ROM drive. CD drives will not read DVDs. You need a DVD-RW if you're going to be burning DVDs or if you're only going to be watching DVDs then a DVD-ROM drive would work.
Apr 03, 2011 | Toshiba XM-1902B (XM1902BSILVER) Plug-In...
Toshiba Satellite M60-156 My DVD/CD drive doesn't see any kind of CDs any more. DVDs works fine? Any ideas? Thanks!
Try going on to toshiba's official website and enter your pc model number. They should offer a variety of drivers that you can download. Try re-installing your CD/DVD driver
Feb 28, 2011 | Toshiba Computers & Internet
Dell 600 is my laptop am using now all other function like cd,vcd is playing but only dvd not playing
You want to check and see if it is only dvds you have burned or do commercial dvds also not work?.
If the dvds won;t work but the cd's work then this is typical of how laptop optical drives age or fail. The alignment on the heads goes out and because the dvd's require more accuracy to be used they start showing either error's, longer and longer read time, or not being able to read them at all. If you were burning dvd's or cd's on this then you should have also seen a lot of burn errors and perhaps the dvd's didn't want to work on other computers.
Eventually the cd's will not want to work as well This takes longer as they don't need as much accuracy from the drive to read.
You can easily replace the drive with a new one for about $65-$85. It is definitely something you can do yourself. You undo one screw that holds the drive in, slide it out, slide the new one in, put the screw back in and you are done. Here's the trick you need to buy the parts from a laptop repair place not Dell. You can get the same drive but waaaaay cheaper. If you do a search for laptop repair parts with google/bing there will be hundreds. Just find one close to you or one with a good price for the optical drive. Keep an eye out for either pictorial or video instructions on changing the drive. It really is as simple as I have described.
Unfortunately your symptoms are typical of optical drives failing from all laptop manufacturers. Actually they are the same for desktops but those last longer before they have problems. Replacement is the only thing that fixes this.
Aug 13, 2010 | Computers & Internet
Drive doesn't read CDs
in device manager try uninstalling and reinstalling the cd-rom driver. If that don't work the infered reader is probably bad
Apr 04, 2010 | Toshiba Satellite P300D-ST3711 Notebook
Does the toshiba sd 2502 , can it burn cds
It is a DVD ROM drive which stands for DVD Read Only Memory. In other words, this drive is meant to only PLAY DVDs and CDs but NOT save data to them.
To burn CDs you need a CD burner. Burners are of 3 types:
CD writer only burns and reads CDs.
Combo drive reads CDs and DVDs but only burns CDs.
Super drive burns and reads from CDs and DVDs.
As you go higher in functionality, the price also increases. Check your needs before you plan to buy one. Also compare prices of all the drives. Note: burn-able media costs are separate.
Dec 11, 2009 | Toshiba SD C2502 Internal DVD Drive
Toshiba satellite a65-s1762 dvd-ram drive problems
Take the laptop *and* your DVDs/CDs to a qualified technician.
It seems like the drive is "intermittently" failing, and needs to be replaced.
Apr 22, 2009 | Toshiba Satellite A65-S1065 Notebook
My dvd drive in my computer won't play dvds
1. Completely remove any dvd/cd player/burner softwares (i.e. Nero, Power DVD, etc.).
2. Go to device manager and remove your DVD/CD device from the device list
3. Restart you laptop
4. Windows will then try to reinstall the device drivers again for the DVD drive.
5. After another restart, then reinstall your dvd softwares again.
Nov 15, 2008 | Toshiba Satellite A135-S4527 Notebook
Laptop CD no longer work
it means you lens is very week and need some replace by buy a need cd/dvd rom to make it play
Mar 30, 2008 | Toshiba Satellite A65-S126 Notebook
CD RW/ DVD RW Drive Will not read and Burned discs or burn to blank discs
I suggest a firmware update from Toshiba. If this does not help then your laser in the drive is no longer capable of this task. Also just thought about it but make sure the media that you are burning to is the same as the drive + or - R's
Jan 22, 2008 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Open Questions:
Computers & Internet Logo
Ekse
Alun Cox
