Question about Refrigerators
The cooler gets a small puddle of water about every two weeks. It sometimes flashes when the compressor comes on
  • 4,066 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 09, 2009
I have an artic king freezer model arco7mw and it has puddles of waterneath,why is that?
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Mar 02, 2015 | Refrigerators
Why won't the red blinking light go off on my primo water cooler?
If the cooler or the water are not getting cold I would check for a high pressure reset if they are getting cold the compressor would working fine, you could also try flushing it, is there a pattern to the flash that may indicate a code................good luck! mine has developed a leak and does not heat less that 6 mo old pretty disapointing.
Jul 20, 2014 | Unknown Primo Deluxe Stainless Steel...
I dropped my net ten phone in a small puddle of water the screen was already cracked now it wont unlock
Water and electronics are a fatal combination. You can try to keep it inside the house where it's warm and dry and maybe after a few days or a couple weeks it might come back for you, but I think it's time to get a new phone, Peter.
Jan 19, 2014 | Cars & Trucks
My GE Profile refrigerator leaks water from the freezer. I find a puddle under it 2x/week.
Defrost drain tube clogged, drain pan cracked, water tubing near compressor gets brittle and leaks, critters chew on water tubing also.
Oct 29, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
I have to replenish the powersteering fluid in my 96 Corolla every other week, just about. Where should I check for a leak? in the pump or reservoir or where?
If it is leaking that fast, there should be a nice puddle on the ground where it is most often parked. That would be a clue. Take it to a muffler or oil change place, both have lifts, and pay them a few bucks to tell you where the leak is if you cannot find it. It is so much easier to find a leak with a lift and a light.
Pumps leak, racks leak, hoses leak, and sometimes there is a small fluid cooler which springs a leak.
Cooler, hose, pump, rack is the expense order.
Aug 29, 2011 | Toyota Corolla Cars & Trucks
I have a puddle of water under my crisp drawers every week! I have a whirlpool model number ET18GKXHW0 - manufactoring date of 5/99! Is it time for new fridge? Why the puddle of water?
I'm presuming that this is a self defrosting fridge. When it defrosts, the water runs down the back of the fridge inside and collects in a gully, usually just above the crisp draw, it runs through a hole in the centre of the gully, down a pipe to a plate which is positioned above the compressor at the back. The compressor gets warm and the water evaporates.
The hole in the gully is probably blocked with debris or mould, as a result, the water overflows onto and into the drawers. MOST fridges have a dip stick like device in the hole, which you can use to jiggle up and down and clear any blockage. If you don't have such a dipstick, a soft wire or bit of plastic tie will do to clear the pipe. Worst case, you may have to pull the fridge away from the wall and check at the back. The compressor, plate and drain hose (about the thickness of a pencil and usually clear plastic) should be clearly visible. Sometimes, the hose gets dislodged so it doesn't drip onto the plate, sometimes the blockage will be at the end of the hose that runs out onto the plate, rather than inside the fridge. You can try blowing into the hose, which should be free and clear to blow through, or pushing a soft flexible wire down the entire length of the pipe to clear any blockages in places you can't see.
Jul 10, 2011 | Whirlpool Refrigerators
Marvel wine cooler leaks water
All coolers produce water as a result of condensation which occurs when air is cooled. The water appears upon the radiator (technically called the evaporator) inside the cold area of the cooler. When the water drips off of the radiator, it is caught by a pan which may or may not be a removable piece. The pan should lean toward the rear of the cooler and the water should pour into a drain tube. The drain tube should lead down into the compressor area of the cooler and deposit the water into another pain which is outside of the cooler where it should evaporate back into the air. Sometimes "cardboard" fins are used to help the water evaporate. Sometimes a pan with a huge surface area is used to help the water evaporate. Other times the pan is literally on top of the compressor. Make sure the cooler itself is level. Make sure room air is able to move over the pan where the water is supposed to evaporate. Make sure the drain hose is not clogged. Make sure pans are not leaking.
Jun 11, 2011 | Marvel (6SBARBSG) Wine Cooler
Small puddle of water on floor in front of fridge
there is a drain pan under the fridge where water is collected then evaporized from the heat of the compressor thet sometimes the pan cracks or the pan is unleveled .check pan
May 23, 2009 | Bosch Logixx KDR40423 Refrigerator
Cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
May 18, 2009 | Avanti Hot and Cold Water Cooler
Moisture dripping from temperature control hood model KTRS21MFAL0
possible that condensation drain line is clogged. This line drains the water from the freezer when it goes into defrost to a small pan loscated above the compressor where when it gets to the pan the heat from the compressor running evaporates the mosture.
Mar 23, 2009 | Kenmore 61042 Top Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
