Question about Honda Garden
Ar pump does not seem to be pumping water is coming thru wand but
  • 5,603 Answers
The transfer valve is probably stuck on bypass.
Posted on Sep 09, 2009
Pump does not appear to be working
Disconnect wand/hose with water to pump run machine. If high pressure water comes out of wand/hose port, bad wand or hose. If no high pressure water, bad pump.
Apr 27, 2016 | Garden
Will start and run fine water comes out but has no pressure
Maybe bad pump. Remove wand and wand hose, run machine with water in. High pressure water coming out of wand/hose connection, bad wand or hose. No high pressure water, bad pump, replace.
Apr 01, 2016 | Simpson PS2600 PowerShot Commercial-Duty...
Saeco poemia espresso machine, cant complete circuit prime as water stream does not come thru steamer wand, as instructions say. Left open for 5 min.
Not sure I understand your question since there are no question marks "?" But assuming you open hot water and nothing comes out. Saeco uses micro switches to activate pump for hot water. Steam sometimes ruin the switch. Open and replace
Jan 06, 2015 | Coffee Makers & Espresso Machines
Dayton pressure washer motor runs no water coming out of wand
Not sure what model you have but take the high pressure hose off the pump and see if water in coming through the pump.
If water will not come through the pump then check the outlet port of the pump.
If water is coming out of the pump but wont come out the end of the want then you may have a clogged nozzle in the end of your wand.
Oct 23, 2011 | Heating & Cooling
Water flows thru the pressure washer pump and out of wand, when I start the motor flow stops. I have a craftsman model # 580.752060 I've taken pump apart and there are no obstructions that I can...
Let the water run for a longer time. "Walk" the hoses, from the faucet to the pump and then to the nozzle, holding the hoses up to displace any trapped air in the lines through the pump and out the nozzle. What it sounds like is that air is reaching the pump. When it does, it cavitates, and no water can be pumped. Tighten all of your hose fittings securely. Try holding the trigger down while starting the washer. It may be easier with another person helping.
Best regards, --W/D--
Jul 08, 2011 | Craftsman 2500 PSI Briggs Stratton...
Poor pressure and water comes out of the detergent hose
replacing the wand wont solve the pressure problems, its going to be the pump problems, pump create high pressure to the wand. hope that help
Jul 21, 2009 | Karcher 2500 PSI Pressure Washer
Pump cycles when trigger is not open
it is normal,It is the governor on the engine that does this.
May 07, 2009 | Briggs & Stratton Garden
Motor starts and pump is not working. No water is flowing at all..what do i need to do?
Water is supposed to flow slightly through the pump without it running so disassemble the wand and cut on water supply, see if water comes out of the wand on-off handle. The motor does not have to be running. Got water flowing? YES - clean out the wand filter or nozzle hole. A partially clogged filter will prevent hi pressure activation.
NO? disassemble pump and clean out chamber paths.
Also - A pressure pump is not suppose to be running and not used for over ten minutes. The pump can overheat from lack of water passing through and damage the pump seals. A clogged wand is the same as not using it while you try to figger out why it doesn't have high pressure. I found my clogged filter and stopped up nozzle but haven't gotten my real high pressure back yet. Sears doesn't sell the valve seal kit but someone does.
May 04, 2009 | Garden
Power washer problem no pump action
sounds like nozzle is blocked.small bits of grit jam nozzle unscrew and make sure its clear turn water on and pull trigger to see if gun trigger works,then refit nozzle check again for spray.if clear start up and try out.if no go then pump probably needs cleaning and relubing seals.
Apr 20, 2009 | Comet Garden
Gas driven portable pressure washer no longer draws chemicals up
Picks up under low pressure conditions by adjusting wand or changing tip.
Mar 18, 2009 | Honda Garden
Garden Logo
69 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
