Question about OTC 7471A CUMMINS DIESEL ENGINE BARRING TOOL - 7471A
1998 Peterbilt truck will not start in the mornings after being shut down over night. Have to turn it over and over for a long time before it kicks in. Have replaced the fuel pump, fuel lines, replaced injectors, and checked for possible pieces that may be blocking the lines. I had to replace the crank shaft, and ever since they had to take out the engine and put it back together, it won't start right. Any ideas?
  • 3 Answers
I am going to assume that this is a celect plus N14 engine, 99 percent of the time the hard start problem is caused by either not having a check valve in the supply fuel line at the ecm cooling plate or a debris in the check valve, The check valve is on the ecm cooling plate closest to the fuel pump. good luck
Posted on Sep 10, 2009
    President:
  • 986 Answers
Do you have a engine light? I have something for you to try unhook you battery make sure you unhook the ecm wire to the battery,hook every thing back up it will start,I hope this help you
Posted on Sep 09, 2009
  • Donnie Wilson
    Donnie Wilson Sep 09, 2009
    One other thing is your ecm powering up you will have 2 fuses in your battery box if one of them is bad it will not start,also check your wire ends make sure there is not alot of green stuff around them
  • Donnie Wilson
    I think you said you change your engine posistion sensor if it bad it shoul give you a code of 121
I have honda activa 110cc of 2009 model.when I start in morning first time by cick,it starts by kicking 12-15 times ...what is the problem ....it may be overflow or not
Sounds like the carb may be flooding and fouling the spark plug overnight,can you turn the fuel off ? If so try Turing it off at night and see how it starts in the morning.
Sep 17, 2017 | Honda Motorcycles
1994 peterbilt 379 keep shutting down
It could be the fuel pump but could also be the evap system if you have one. The unused gas drains into the system and the captured gas is supposed to be there for the next startup but isn't.
Aug 10, 2014 | 1994 - 1996 Peterbilt 200-33 Engine...
Why do the lights come on and off after I shut car and lights off in my 1998 dodge van and then the car wont start in the morning?
Well the car wont start in the morning, becuz its draining the batteryfrom the lights coming off and on. But the reason ur lights r coming off and on when the car is turned off is there is a short in the wiring from the headlight switch to the steering wheel iignition. There are several wires that are ran from the ignition switch to various things in the car. Such as windsheild wipers, headlights, turn signals... which is why these things generally work only when ur ignition is engaged. The wires could be pinched which could cause the short, if ur in the habit of raising ur steering wheel up and down alot. Kind of like a pinched nerve. The steering colum is going to need removed to trace and straighten out the wiring to properly fix the short thats causing ur lights to go off and on all the time.
Jun 26, 2014 | 1998 Dodge Caravan
I have a problem with my z71 v8 pick-up in the morning when i first start it i have a hard time starting but once it starts it fine after the first start it has no problem starting when u shut it off i...
run the fault codes
indicates a problem ambient temp or baro sensor not reporting to the ECM to get the correct air/fuel ration for starting ( as in the old choke application)
Aug 12, 2017 | 1998 GMC Sierra
Why if it is a timing problem why would the problem be cured after the first start in the morning. I only have that problem first thing in the morning when I go to start my car do u think it is still the...
Before you start the car tomorrow morning,open the hood and wipe down a wires,cap, all electric parts and connectors with few dry towel.
The morning moisture is a common problem for folks in cold climate.
How many mile is on the rubber timing belt?
It need to change every 85,000 miles
A worn timing belt will off set the timing.
Dec 12, 2009 | 1998 Mercury Tracer
For the past two nights, the lights on our 1998
it sounds like the headlight switch which is part of that arm needs replacing. a multifunction switch is the proper name for that.. you will have to remove the steering column covers and you will see the attaching screws to remove. i hope that helps
Dec 10, 2009 | Isuzu Rodeo Cars & Trucks
Cold morn - not starting. Car was moved a few feet night before.
OK, so starting the engine uses a lot of battery power, and the engine needs to be left running a while to recharge the battery.
When it is cold batterys don't hold as much charge (not quite the correct technical term, but I don't want to go into battery mechanics and chemistry here). You either need to pop it on a trickle charger or let it run for at least 15 minutes.
Dec 28, 2008 | 1998 Suzuki Swift
Startup problems
check your keyboard connection (unplug and plug again). If not works try another of same type.
Dec 24, 2007 | HP Compaq Presario V2000 Notebook
OTC 7471A CUMMINS DIESEL ENGINE BARRING TOOL - 7471A Logo
1,870 people viewed this question
Top OTC Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an OTC Hammering Expert? Answer questions, earn points and help others
