Question about Onkyo TX-SR605 Home Theater Receiver 7.1 Channels
I have the same problem
I have it hooked up to new polk 8 ohm speakers, with a self powered sub. If I go over 50 on the vol dial it will run for aprox 10-15 min, then turns its self off. I let it set for less than a min and I turn it back on and it works fine for another 10 min or so. If I turn the vol down to under 35 or so..OR listen to a movie that has NO loud explosions, or yelling..it does not have this problem. I have had this thing for about a year and a half now..and it never did it before.
I it on a new open shelf system. It WAS enclosed before..now it has plenty of room all around it, and now it starts to over heat. I could have understood it before..??
I put a table fan behind it last night and set it on low, and it SEEMS to fix the problem. I dont know if I have a fan that died in the machine its self, or what the problem is? any ideas?
Thanks in advance.
  • shooter313 Sep 09, 2009
    I use 10 gauge wire for all my speakers except for my Sub, that I use 8 gauge. I am running about 25 feet for my back speakers, 8 feet each for the fronts, and maybe 8 or 10 feet for the powered sub.
    T here is no dust in the reciever, I build computers..I used to do it for a living, now it is just a hobby of mine. (My newest one is liquid cooled.) :)
    I am aware of the problems dust buildup can cause and I am very careful not to let it happen. I clean all of my equipment weekly with compressed air, as you mentioned. (I take the covers off first of course.)
    It is not a Sony, I have not heard of any problems with those, mine is an Onkyo, (same as the person posting before me.) Heat has always been a problem for that company, from what I have seen in the past from my own Onkyo machines.
    From what I have read on line this is a pretty common problem, (some getting so hot people are starting to worry if they will start a fire.)I dont think they will get that hot, but I am not going to take any chances.
    I dont know WHY I bought it? I said I would never own anything made by them ever again. This time I will stick to that promise.
    I just ordered a new Pioneer VSX-23TXH. From what I have read heat is not a problem with these machines especially the Elite series.
    Thank you for your advice. :)
    Have a good day.
    Gary*
  • shooter313 May 11, 2010
    It was NOT by using the persons information that posted to my problem.
    I solved it myself, so WHY would I want to help YOU SELL my soulition to some other person with the same problem? If you want to know how I did it, check the AV boards I posted the fix on. I dont believe in charging people for advice, especially when I am not actually LOOKING at the piece of equipment they have. Especially when that person answering my post didnt even mention the correct manufactuer I had listed!!
    Plus I dont think most people should be taking apart electroinic products, most will end up doing more harm than good, and in the end turning a $50 fix into a new machine instead. Which I did buy as well..but I fixed the Onkyo just to prove to myself that I could do it.
    Pretty sorry site to lure people in with a WE WILL HELP YOU AD, then pull the bait and switch and try to charge them for someones opinion that MAY have a clue what they are talking about instead.
    Pretty sorry site pal.
    Problem Solver:
  • 5 Answers
No mention of speaker wire size or length but the internal thermal shut down circuit is very sensitive, if even one channel goes into thermal protection it shuts the unit down, quick fix is cans of compressed air for computers and clean the inside of dust the factory set thermal cut off is 39.1 to 43 degrees celcius with an impedence check of not less than 4 ohms, your fan trick sounds like the right start the volume setting is not absolute there fore it may be your units actual voltage, amperage wattage conversion output is at its limit, heat is electronic death take great care to avoid heat, large amps have massive heat sinks your sony is not one of them
Posted on Sep 09, 2009
Wiring a crossfire vr602 at 4ohm
OK what you are saying now is that your speakers are dual voice coil; models? 4 Ohms per Coil? I have always used single 4 Ohm Voice ciol speakers since amps are mostly based on 4 Ohm outputs. but you can get 8 Ohm dual voice coil subs also. With 8 Ohms per coil you can get 4 Ohms if you parallel the wires. What is best for you and will get you the most stable power and still will be in the specs of that amp is to run the amp in BRIDGED MODE running each subs voice coils in series with each other then run those 2 subs in parallel to the amplifier giving it a 4 Ohm load. So, your will have two sets of wires from your amp 1 for each speaker. Then you will take a short piece of wire that will connect the + to the - of each voice coil then hook up the wires from your amp to each sub What it will be is 4 Ohms + 4 Ohms = 8 Ohms per speaker the 8 Ohms in parallel each speaker to the Bridged amp output using just the + from one channel and the - from the other will give you a total of 4 ohms and power out put of 600 Watts so that ends up being 150 watts per voice coil or 300 watts each speaker
Apr 04, 2013 | Crossfire VR602 Car Audio Amplifier
I just purchased a yamaha RX-V767 receiver. I have a polk surround sound speaker system 5.1 that have an impededance of 8 ohms. The receiver has an impedece adjustment knob on it. would it be safe to...
No, you don't want to do that. The Ohm output on the amplifier must match the speakers. Run 8 Ohm speakers on 8 Ohm and run all your speakers on the same impedance (Ohms). Your gonna burn your amplifier up if you run different impedances.
Mar 24, 2011 | Yamaha NS-A60X Main / Stereo Speaker
Have a blown vintage polk audio psw50 subwoofer 8". Cannot find the value of the Ohms. Could you please provide this info and make recs for best place to replace this sub that is most cost efficient....
It measures in at just under 4 ohms, so assume a 4 ohm speaker. You can replace this with any number of similar subs, using perennial DIY favorite PartsExpress, there are two under $30 that would meet your needs (Dayton SD215-88 and Goldwood GW408). Looks like they both have dual 8 ohm coils, so you would simply wire them in parallel for your application.
Feb 18, 2011 | Polk Audio PSW50 Subwoofer
I unplugged my rca cables from micropro 4000 and it made a loud boom. Now it no longer puts out any bass. I pushed on the sub and it feels good. The sub powers on just no bass.
Open the case and check the resistance value of the actual speaker - should be around 8 ohms. If it doesn't get a reading, then it's bad.
Jan 01, 2011 | Polk Audio DSW MicroPRO 4000 Subwoofer...
Just got two AR 312 HO speakers from my brother. I have a Yamaha HTR 6250. The speakers have (2) sets of cable hook up. One I assume is for built in sub woofers? Do I hook one normal and one to the sub...
do not use those speakers with that amp, those are 4 ohm speakers, which could damage your 8 ohm yamaha amp. you will have to get a 4 ohm capable amp to run the highs, and another 4 ohm amp to run the subs.
car amplifiers are currently 4 ohm, or even 2/1 ohm stable, but few, if any modern receivers can run at anything lower than 8 ohms without a danger of overheating. you may have to get a vintage amp(s), like a 1970's marantz receiver, or a 1980's to early 1990's kenwood power amp, because 4 ohm home amps are pretty scarce nowadays.
whatever amp(s)( you get, verify that they are DEFINITELY 4 ohm stable.
Nov 06, 2010 | Acoustic Research 312 HO Speaker
Is it possible to hook the infinity bu-1 subwoofer to a home theater system where the subwoofer output is straight power say it"s like 25 watts coming out of that one channel and before the original...
In general higher speaker impedance is safer than lower impedance for the amp. Don't expect anything impressive re: audio output from a passive (unpowered) sub if your HTS says it pushes only 25 watts. Without frequency bandwidth and distortion noted the spec is virtually useless as a comparison.
The BU-1 is a powered sub that accepts either RCA Line Level or HIGH LEVEL amplifier power. If you use the latter, impedance is a non-issue because the input feeds the BU-1's internal amp, not the speaker directly. You should be okay.
Perhaps if we knew some specifics about the HTS we could do more than guess.
Jul 21, 2010 | Infinity BU-1 Speaker
DSW PRO 600 not getting signal from receiver. Why?
You don't name the electronics, which can be the source of the problem. See #3.
1. If you suspect the cable why don't you just swap in another RCA cable? BTW: there's no such thing as a "subwoofer" cable. Monster makes their money on those beliefs. Cables don't wear out but they can go bad if one or more conductors fails. Oxides devolp at either end which can inhibit conductivity. Remove each end and reinsert it with a twisting motion.
2. Maybe. You need to ensure the sub is defined. Run speaker level check. If no sound at the sub, prove the LFE/sub channel has output by running the RCA cable to a recorder or your TV (low volume). If there's no signal, duh, no speaker will work with it.
3. Mmm, not if it's exhibiting the same problem as the old one and the Polk 450. Have you looked at the setting of the Standby/Auto/On Switch? And the Power Mode LED's? Red is bad.
Mar 31, 2010 | Polk Audio DSW PRO 600 Subwoofer Speaker
Ohm calculations; 4 and 8 ohm sub woofer?
+ output from amp to + input of 4 ohm to + input of 8 ohm AND - output from amp to - input of 4 ohm to - input of 8 ohm is a parallel circuit = 2.66 ohm impedance load for amp
+ output from amp to + on 4 ohm - on 4 ohm to + on 8 ohm - on 8 ohm to - of power amp is a series circuit = 12 ohm impedance load for amp. Clear as mud??
Clear as mud?
Jun 11, 2009 | Jl Audio 12W0 Car Speaker
Help
can you tell me how your sub is hooked to your amp. is it via the speaker cables or using the amplifier source sub wooker rca connections.
i suppose you have checked all your power cables. if the sub is connected to the amplifier rca output then check the bass sub out level if high enough to drive the auto power switch of sub wfr input. subwoofers normally use an auto power cutoff when no signal. if sub vol level is too low it might not triegger the autopower on.
Jul 16, 2008 | Yamaha HTR-5840 Receiver
Two amp
I don't know why you'd set the Peavey to 2 ohm to drive 8 ohm speakers??? My other thought is... I wonder if the phase is correct. try reversing one of the speaker wires Left or right side.
Geno
Feb 27, 2008 | Harman Kardon AVR 630 Receiver
Onkyo TX-SR605 Home Theater Receiver 7.1 Channels Logo
180 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
