Question about DeLonghi DC312T 14-Cup Coffee Maker
Coffee won't brew. Tried unplugging and resetting everything, tried manual, tried timer - still won't start brew cycle.
Tossed the coffee pot and bought a new one.
Posted on Sep 10, 2009
Cuisinart dgb900bc. Set timer to brew at 5 45. Have for many years. Last two nights at 5 45 clock goes to 12 00 AM. Does not come on automatically. Turn on manually and brews coffee as great as usual....
I would assume that the chip/timer unit has failed in the unit. Not sure you want to try to disassemble the coffee maker to get at it. Have you tried reversing the a.m. to p.m. (thus the clock would read 5:45 p.m. at 5:45 a.m.) settings and seeing if the machine would brew the coffee normally? (although I seriously doubt this will work, but...)
Jun 21, 2014 | Coffee Makers & Espresso Machines
Cleaned my mr coffee pstx properly and the light will not go off . Unplugged it and everything help !!!
!!!!FIXED!!!!
I know this an old question, but I finally fixed mine. Hopefully this will help someone. I have a PSTX Mr. Coffee (10 cup) maker.
Allow me to provide some background first ...
I started a clean cycle, following the instructions in the booklet exactly. I used 4 cups of white vinegar and pressed the clean button. Easy, right? The reservoir emptied about 2/3, the clean light began blinking and an audible (steady) alarm sounded. I waited for 2 hours for that audible alarm to stop, but it never did. Finally, I unplugged the coffee maker, plugged it back in and tried again. Same results. By this time, I figured I had run enough vinegar through it to properly de-calcify the unit, so I repeated the "clean" steps numerous times with just plain water. Same results. I realized that I could still brew coffee; only thing is, the darned clean light would keep coming on when I pressed brew. Surely, I did something wrong or there would be an answer on the web. I searched many answers, but none fixed my problem. So I decided to call Mr. Coffee (US: 800.672.6333 or Canada: 800.667.8623). I navigated through the menu and found the troubleshooting section for cleaning. The automated voice said, "Place 6 cups of cleaner solution or white vinegar in the reservoir...."
Stop the presses! Did she just say 6 cups? The manual clearly states 4 cups. Also, that's what everyone else on the web is reporting.
So I tried it, and I only used water (since the pot was still relatively clean) - 6 cups of water - pressed the clean button. This is what you SHOULD expect:
1. Place 6 cups of cleaner solution or white vinegar in the reservoir
2. Press the "clean" button.
3. When approximately 2/3 of the solution has brewed through, it will [apparently] stop brewing - the "clean" light will begin blinking (but there should NOT be any sort of audible alarm) - let the maker sit; it's still working on the clean cycle.
4. The final 1/3 of the solution will brew through and the cleaning light will shut off.
This CONCLUDES the cleaning cycle.
Of course, you should just perform a few "regular brew" cycles with just plain water to clear out the vinegar (or cleaner solution) odor.
Bottom line: The manual screwed all of us! 6 cups, not 4!
Try it - Hope it works for you as well as it did for me.
John
Nov 16, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Cooffe brews on its own
Hello. Here is what could be happening. Your brew timer may be having a problem where it is re actuating on it's own, in which case it would need to be replaced, and re calibrated. The other possibility is that the start switch is making contact internally, and telling the brew timer to start again. Your unit does not show it having a level probe, so most likely it is not overflowing due to a flooding condition. After you brew, turn off the lower heat switch, this will remove power to the brew circuit, if the problem stops, then you know it is one of those 2 things, and I would try the start switch first, as it is a cheaper item to replace than the timer.
Here is a link to your brewer manual with part #'s etc..
http://www.bunnomatic.com/pdfs/commercial/manuals/10613.0000.pdf
Hope this helped, and thank you.
Mar 12, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Mr. Coffee won't brew - Mod. #ECX30118
IF YOUR HAVING ISSUES WITH THE ACTUAL BREW OR CLEANING CYCLE AND IT WILL NOT WORK, THERE IS NO TROUBLE SHOOTING THAT CAN BE DONE. MR COFFEE CARRIES A YEAR WARRANTY SO YOU SHOULD CALL THEM TO HAVE THEM REPLACE THE UNIT.
Jan 14, 2009 | Mr. Coffee FTX24 12-Cup Coffee Maker
Reset ge model 169165 electronic cleaning cycle
Unplug the coffee pot and push in the "1-4" and "TSB" buttons at the same time, hold the buttons in for a few seconds. This will reset the pot and you should be able to brew like normal after that.
Dec 07, 2008 | GE 106591 Coffee Maker
Cuisinart grind and brew won't work
same problem except unplugging it then plugging back in makes it work again.
however, for $150, i shouldn't have to reset the timer every time i make a pot
Nov 10, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cofee maker
Can I buy the coffee basket . It got thrown out with the paper filter. Do figure. I know it's old but it makes great coffee.
Mar 04, 2008 | Kitchen Ranges
Coffee maker shuts off too quickly
It seems this coffeemaker insists on shutting itself off after 4 hours,
or whatever "auto-off" time you've programmed in. The only work-around I've found is to switch it to "Brew" and cycle the power switch off and on every time you pour a cup. That will start a new
4-hour timer cycle. Since the pot's still hot, it will go quickly to the
"brewing done" state and render 5 beeps.
Jan 08, 2008 | Cuisinart DCC-1200 Coffee Maker
Control panel lights
The manual indicates this means that it is time to decalcify the machine.  After doing so, press the ON/OFF and PROG buttons at the same time for 2 seconds.   Jeff, Burbank CA
Dec 11, 2006 | DeLonghi CAFE DUO Dual Drip Coffee Maker
DeLonghi DC312T 14-Cup Coffee Maker Logo
528 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
