Question about Canon Office Equipment & Supplies
Printer has error 6500 showing and i have even unplugged it and plugged it back off..
    Scholar:
  • 77 Answers
Shows an error with a logic board inside the printer, if it is under warranty, contact canon for service, if not you may want to get a repair quote.
Unfortunately its not something you can fix yourself.
Posted on Sep 09, 2009
Testimonial: "Thank you!"
Canon pixma mp500 error 6500
Hello! Welcome to FixYa
First try this to solve error 6500:
Firstly Reset the printer and
Turn the printer off with the Power button then disconnect the data cable from the printer.Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. Turn the printer on. If this works you have solved the problem If this not works then try the next step:
After confirming that the printer is powered on,open the paper output tray and Open the top cover and wait until the print head moves to the center then Open the inner cover and check that ink tanks are properly seated.Press down on each ink tank until a click is heard.Close the inner cover and top cover. Also do you have any kind of data equipment like a camera connected, if so this could be causing the problem as well.
If you find my solution helpful for you the your Rating as FIVE STARS will be esteemed.
For further help, you can take my valuable,professional help by taking my Service
Thank you for using FixYa!
Dec 14, 2011 | Canon PIXMA Office Equipment & Supplies
Error code 6500 on my mp8630...unplugged everything for hours...the printhead will not move back into place
Hello thanks for using FixYa
To solve error 6500 First try this:
  • Reset the printer:
  • Turn the printer off with the Power button
  • Disconnect the data cable from the printer.
  • Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
  • Turn the printer on. If this works you have solved the problem
If not try the next step
  • After confirming that the printer is powered on,open the paper output tray
  • Open the top cover and wait until the print head moves to the center.
  • Open the inner cover and check that ink tanks are properly seated.
  • Press down on each ink tank until a click is heard.
  • Close the inner cover and top cover.
Also do you have any kind of data equipment like a camera connected, if so this could be causing the problem as well. Unplug it if so and see if this is the problem after the above steps
I hope this helps, because Canon doesn't even have support for an error code 6500.
If it all fails the final & best option is to take it back where you purchased it or contact Canon service center about the error code. They will surely solve it.
I hope this solution was helpful for you.
Please give me token of appreciation as FOUR THUMBS
(given below to this solution) "it if it helps you"
Thanks & Keep using FixYa
Apr 01, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Error 6500
Hello thanks for using fixya
To solve it First try this:
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Feb 21, 2011 | Canon PIXMA MP830 All-In-One InkJet...
6500 error code
Jan 29, 2011 | Canon PIXMA MP830 All-In-One InkJet...
My printer ix5000 error 6500. pls help me... what happent with my printer.....thk....
Jan 28, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
Display shows error code 6500. how do I fix the error
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement
Aug 15, 2010 | Canon MP830 All-In-One Printer
I can't even fax from the machine with error code 6500 showing. Thus, it isn't just a printing problem.
Error code 6500 on the MP830 is for a PCI bus error. The Canon service manual suggests the remedy is to replace the Logic Board. That wouldn't be cost effective if you could even get the spare part.
Sorry I can't be of more help.
Jan 07, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Officejet 6500 error code 0x61011beb when attempting to install new printer. How to fix?
Your OfficeJet 6500 may need resetting. With the printer power on:
1) Disconnect the USB cable from your computer
2) Remove the ink cartridges
3) Unplug the power cord. Wait for at least 1 minute. Plug the unit back in (press the power button if necessary)
4) Wait for the "Insert Cartridges" message. Reinstall the cartridges
5) Close the product doors
6) If you receive a recalibration message, allow the printer to complete this task
7) Reconnect the USB cable
8) Try your print job again
If problems still exist, your product may need servicing by an authorised HP technician.
Dec 20, 2009 | HP Officejet 6500 Wireless All-in-One...
Screen shows error code 6500
4. Properly seated
if reset method not works for you then you go for the new logic board replacement .............
Good Luck!!
Thanks
Sep 09, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Error code 6500 flashing
4. Properly seated
Good Luck!!
Thanks
May 03, 2009 | Canon Office Equipment & Supplies
95 people viewed this question
old marine
old marine
