Question about Optoma H30 Multimedia Projector
Optoma H30 projector hooked up to JVC RX-D201S receiver
This hookup was working before but I unhooked it and when I went to rehook it, the projector says that there is no signal. The dvr is hooked up to the receiver with the yellow video cord. The receiver is hooked up to the projector with the RGB cords. The receiver is also set to analog. The receiver sends sound to the speakers and everything.
  • 5 more comments
  • Tomyka81 Dec 10, 2007
    also to note. we had the same problem when we were first hooking it up. We just do not remember what we did when we first hooked it up.
    The yellow cord is the yellow video cord with the white and red being the audio cords.
    the connectors are just single "fat" pin connectors with the grapple features on the sides
    I cannot get the menu to come up using either the remote or the projector buttons
    When I turn the projector on, it does scroll through the differnt input options looking for the signal. The projector did this when it was working correctly.
  • Tomyka81 Dec 11, 2007
    I need help
    The yellow cord is brand new. I think the problem is with the receiver becasue I just hooked the dvd player straight to it and it works. I am not sure what is happening. the current setup is now the dvd to the projector with the RGB cords and the sound from the dvd thru the receiver.
  • 4,102 Answers
You mgiht also need to replace the yellow lead as if this has become damaged.
You say you get sound so you know the other twol leads are fine can you select input device so you can select witch mode to use if all else fails you will need to get the leed tested and replace as necesarry.
Also have you tried plugging the video lead in when it is all switched on as sometimes it will pick up the signal and be on the right video input as they will often automatically pick up the signal so try this whilst it is switched on let me know how you get on ok
Posted on Dec 11, 2007
  • paul proctor Dec 11, 2007
    from my experiance with projectors it should pick up the signal strait away ie when proj is on and then you switch the dvd on it automatically picks signal up and should have no problems.
    if you are sure the lead is ok then you have tried the lead in something else and the dvd works ok that way then the prob has to be projector.
    It could just be that the conector you plug the lead into might need resoldering to make the conection good again.
    if you cnay acess none of the settings and switch input then thats telling you their is no input their.
    If you are capable of repairing the unit yourslef then give it a go but if you are unsure then leave to expert.
    But you should find that it is only solder problem.
    Only go this route if you are sure dvd works ,lead are fine then it is projector.
    Does the controll do anything and does the projector buttons do anything let me know ok
  • 709 Answers
Hi Tomyka81,
I will investigate the problem you are having and get back to post a comment momentarily. If you can describe the yellow cord for me a little better. Please describe the connectors on both ends for me. I will post back soon with a proper hook up.
Posted on Dec 10, 2007
  • 6 more comments
  • Greg Stokes
    Greg Stokes Dec 10, 2007
    Hi Tomyka,
    The optoma website does not cover anything helpful in getting info on the H30. However the JVC site is very good. You will need to make sure the onscreen menu for the H30 is allowing auto source search.
  • Greg Stokes
    Are you able to get to the menu on the H30 and select component video input? This should work and Analog is correct setting by the way. I am thinking you only need the Y, Pb, Pr cable to the H30 hooked up to the Monitor out Y, Pb, Pr connection on the back of the reciever.
  • Greg Stokes
    Greg Stokes Dec 11, 2007
    Try hooking another Video output type device to the H30 to see if it is the JVC not putting out a Y, Pb, Pr signal. If you have a DVD player with y, Pb, Pr output and select the switch on the back to use the compionent output it might let you know if the video out is working on the Reciever. On the other hand, hook the monitor out Y, Pb, Pr to the input of another monitor to see if the video out put from the receiver is working. You may have a setting to turn on in the receiver that turns on the Y, Pb, Pr output.
  • Greg Stokes
    Hi Tomyka,
    I found the users manual for the h30. They say something about a hide feature could be stop[ping video from displaying, but i think it may be a bad connection. Check the pins and connections on both ends of the Y, Pb, Pr cable. Go ahead and do what I said in the last post. This may tell us if the H30 or JVC is causing the problem.
  • Greg Stokes
    Alright then, You have a bad connectiion inside the Receiver. What I am talking about is the Y, Pb, Pr connection does not work. This could be a setting not turning on the Component output. I will investigate further for more information.
    http://marketing.optomausa.com/PDFs/user...
  • Greg Stokes
    Also, you need to set the JVC to the correct Video Input. If you are using a VCR or DVD player to play a videoo, be sure to set the JVC to read that input. All you will get is audio is the wrong video input on the JVC receiver is not selected properly.
  • Greg Stokes
    Here is a copy of the JVC manual.
    http://resources.jvc.com/Resources/00/00...
    On page 20 it talks about selecting the Video input.
  • Greg Stokes
    Select the input that the DVR is wired into on the back of the REceiver.
Optoma H30 -- When turning on projector the green light on power button blinks and the projector sounds like it is going through a cycle....after the cycle the lamp light comes on and nothing comes on the...
If the lamp light is orange then the lamp ballast circuit or power to it is no good.
I presume the lamp is not on at all, and it's not the hide function that is stopping the light coming out.
Mar 10, 2011 | Optoma H30 Multimedia Projector
Vertical lines on optoma projector
use "frequency" to make an adjustment. then make sure your resolution matches.
Nov 13, 2009 | Optoma H30 Multimedia Projector
I have optoma dv10 projector the dvd is playing but there is green flickering lines over the picture can anyone help
Hi
Try to change the cable from source to your projector. or make sure everything is connected properly.
Hope this help
Apr 02, 2009 | Optoma H30 Multimedia Projector
How to hookup yamaha rx-v730 receiver to projector & cable unit.
hook up hdmi cable from cable box to receiver hdmi input 1 then from hdmi out to your projector or tv,i don't know what kind of inputs you have on your projector .whatever you have run from projector to receiver input example component red,blue,green then run from both say to the av input 1 then set your receiver to av1 and you should get picture.
Jan 25, 2009 | Yamaha RX-V730 Receiver
Optoma H30 Projector: color banding
Most DLP projectors have a colour wheel. It's usually hard to get at, and you may have to actually remove everything including the optical block from the projector to access it. This wheel turns on a motor just like a fan, and if it gets dirty it can act up just like a fan.
They are expensive to replace, so you might want to try taking it apart and cleaning it out. Add a small amount of 3 in 1 oil to the motor if you can.
Aug 22, 2008 | Optoma H30 Multimedia Projector
Optoma Projector
No power at all most likely means a circuit board is cracked. A repair of this nature will have to be done in a shop.
Apr 30, 2008 | Optoma H30 Multimedia Projector
Optoma projector image yellowing
Very odd problem. Depending on the hours of the projector it could have some glass in it that over heated. Contact Optoma directly, my guess is they will work with you.. good luck
Apr 06, 2008 | Optoma H30 Multimedia Projector
Noisy projector
Hi there
It is a pitty that they quoted you so much for the replacement of a colourwheel - because it really is'nt a expensive part to have replaced.
It makes me really mad that some repairers take chances like that with their clients.
Sep 10, 2007 | Optoma H30 Multimedia Projector
H30 Crashing
The only thing I can think would be that the projector is heating up because the air filters are clogged.
Jul 09, 2007 | Optoma H30 Multimedia Projector
Optoma H30 Multimedia Projector Logo
357 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
