Question about Canon imageCLASS D760 All-In-One Laser Printer
Looking to replace fuser how do you get at it to get out
How do I Fix HP Printer 50.9 Fuser Error online ?
50.9 Fuser error message HP LaserJet P4014 P4015 P4515 If you are seeing the message 50.9 Fuser Error on your HP LaserJet P4014, P4015, P4015 series printer, you have either a failing fuser or the wrong model fuser installed in your printer. (The fuser is the consumable part in your printer which heats up and bonds toner to the paper. Usually the fuser gets replaced several times over the life of these printers.)
HP makes 2 different model fusers that look very similar -- the P4014/P4015/P4515 series fuser, and the M600 series fuser. Because of the similarities in appearance, sometimes the wrong fuser gets installed in the wrong model printer and triggers a 50.9 error.
The easiest way to check which model fuser you have installed is to pull the fuser out of the printer and look at the fuser's barcode. It is easy to remove the fuser on these models; if you don't know how to remove your fuser see the removal instructions farther down this page.
Once you have the fuser removed from the printer, look at the barcode as shown below to determine which model fuser you have installed. For the P4014, P4015, P4515 series printers the fuser part# should read RM1-4554 as shown in the picture below.
Either way, whether you have a failing fuser or an incorrect fuser on your LaserJet P4014, P4015, or P4515, you can purchase a quality replacement fuser in the maintenance kit for the P4014, P4015, P4515 series. Click here to view our selection of fusers/maintenance kits. Call us with any questions toll-free 866-352-7108 or local 608-831-2396.
Removal instructions: How to remove the fuser from the printer
Turn the printer off and unplug the power cord. The fuser might be hot if you have been using the printer. As a safety precaution wait 30 minutes for the fuser to cool before proceeding.
If a duplexer is installed, remove it from the back of the printer.
Next fold down the rear door.
Flex the plastic arm-hinge (circled in red below) on the left bottom of the door . This will release the tab which holds the plastic arm in place, and will free the door.
While grasping onto both sides of the fuser, push the blue levers upward and pull the fuser straight out.
After you order a replacement fuser and it arrives, you can install the fuser by inserting the fuser and aligning the left side first. Push the fuser firmly on the left side, then the right--listen for the sound of both blue levers clicking into place. If the fuser does not click into place you run the risk of wearing out both the fuser and the gears that drive the fuser prematurely. Re-install the plastic rear output bin and you are ready to print.
Dec 28, 2017 | HP Office Equipment & Supplies
Paper comes out looking dirty with a line down the page, why?
bad fuser if the line is in the same spot and kind of a hazy back round also check to see if the toner rubs of when you touch it if it comes of its for sure a fuser but it sounds like a fuser or drum start by looking at the fuser if it looks good replace the drum if it looks bad replace the fuser
Jul 10, 2014 | Kyocera FS-1135MFP
Dell 5200 fuser replacement
Get new fuser, open the machine, look up for the fuser which is already there, remove it and add the newer fuser.
Jul 11, 2013 | Office Equipment & Supplies
Workcenter pe 16 open heat error
Bad Fuser. Google a business called The Parts Drop to order.
It is not difficult to replace. Remove the back cover, 4 phillips screws pull out slide the new one in.
I would remove the fuser first though. And check the plastic in the ends of the fuser. If they are melted, then the power supply has failed and you will have to replace both the fuser and power supply. If the fuser looks normal no plastic on the end of the rolls melted, then just replace the fuser.
Mar 12, 2011 | Xerox CopyCentre C20 Black and White...
HP3330....machine is adding a wide black streak about 3 inches wide down the center of printed pages. Is this something I can fix ?
Check the fuser for the problem, look at rear of printer and open access door to fuser, look at gray plastic film if film broken replace fuser, if film has black mark replace fuser. Note replacing fuser NOT considered a user replaceable item.
Feb 22, 2010 | HP LaserJet 3330 All-In-One Printer
Repeating white spot deletion suggests drum, fuser roller, cleaning roller,etc has a defect. Drum/imaging unit replaced and fuser roller can be seen and looks good. how do i get the fuser out to inspect...
Fuser doesnt sound like your problem generally speaking fusers will add black marks not deletions look to your image creation lense mirrors erase lamps or defective charge grid
Jan 16, 2010 | Canon PC-921 Black and White Copier
How to Replace Dell Fuser?
How do you reset fuser on a dell 5110? replaced fuser but still tells me to replace
Oct 20, 2008 | Dell 5110cn Laser Printer
Hp laserjet 2840 all in one gives FUSER ERROR
For any fuser error, the first thing that should be done is replacing the fuser. If the error still shows up after wards, it could be the LVPS (Low voltage power supply) or a board.
May 26, 2008 | HP LaserJet 2840 All-In-One Printer
My Xerox B/W Copier XC 1044
When was the fuser last replaced?
Jun 09, 2008 | Office Equipment & Supplies
Canon D760 Fuser
Hi Yes when cleaning the fuser you have to be extremly carefull! The fuser can be easily damaged by poor removal or using harsh chemicals. Usually if the fuser is in that bad of shape to where you are having to wipe and clean it your better off replacing the fuser. But again in order to remove fuser you will need certain tools . I hope this helps!!!
Dec 04, 2007 | Canon imageCLASS D760 All-In-One Laser...
Canon imageCLASS D760 All-In-One Laser Printer Logo
197 people viewed this question
old marine
old marine
