Printer head is not printing the whole word, just the top and bottom of words (middle of the word is blank)
Whenever I try to print a document on Word, the top of each letter is cut off. Everything on the document looks normal until I print. It is the whole thing that it happens to, not just the first few lines...
This is usually a printer cartridge or printer head issue. Usually you can clean with rubbing alcohol and a swab. Canon printers usually need new print jets.
Jun 18, 2011 | Office Equipment & Supplies
Printer only prints the middle of the text, leaving the bottom and top part blank
Try changing cartridges to see if you have the same problem. Also, try a good cleaning of the print head.
Jan 02, 2011 | Alps MD 1300 Thermal Printer
My printer is making white lines in the middle of all the words
You don't say what make or model of printer, so I can't give specific instructions.
However, you probably need to perform a head cleaning process on the printer, assuming it is an inkjet printer.
You should have some printer control software on your PC. Find that, and select troubleshooting, or maintenance, or something similar.
You should find an option to clean the print head, which is an automated process that the printer carries out when you select it.
Mar 04, 2010 | Office Equipment & Supplies
Only prints on bottom half of label.
Your scanner and thermal printer has got loose connection. Print head also may need cleaning by own system. try from the software.
JMC
Aug 12, 2009 | Dymo LabelWriter 330 Thermal Printer
I have red lines that go accross the the page. It is inconsistent. Sometimes just the top Qt other time the whole page. Tried nozzel cleaning and new ink.
It is caused by waste ink at bottom plate of head. Print blank pages for cleaning itself. You can clean it by put wet tissue at bottom side of head. Turn off printer, move head to center. Put wet tissue at pad. Move head to parking position. Wait for 15 minutes. Print blank pages for checking.
Jul 18, 2009 | Epson Office Equipment & Supplies
#5 black ink cartridge skips through the middle occasionally
Replacing the print head
The print head may need replacing if, after all print head and ink tank troubleshooting has been performed:
  • The nozzle test appears broken or to have horizontal white streaks.
  • One or more of the colors is missing from the Nozzle Test.
  • The colors are incorrect on the Nozzle Test.
  • A print head error is indicated on the unit.
  • The printer powers off when the print head is installed.
I hope it helps!!!
Nov 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Printing problem with Star Sp200
Seems like a problem with the printer head...It is usual for matrix printers and it happens due to wear and tear..You will have to get the printing head to get replaced..
Oct 27, 2007 | Star Micronics SP 2000 Matrix Printer
k24674
