Question about Olevia LT32HVM 32 in. LCD Television
Base can't get the screws to come out of base stand so i can put it on my wall. whats my problem.
I had the same issue- keep turning and turning and turning- they will loosen.  I did have a small magnet that I put on the screwdriver shaft so when they actually did loosen, they would come out.  They are a few inches long with small threads, so don't give up...
Posted on Dec 31, 2007
Remove stand from monitor
there will be screws on the back which will allow you to remove the stand, then on the back of the monitor their should be 4 screw holes, use these to attach a a flat plate wall bracket to it.
but if you can't remove the stand, then put a clap speaker bracket on the wall & just clap the base of the monitor, as this type of bracket can be adjusted both in & out & up & down.
Jul 21, 2012 | Acer AL1711 17" LCD Monitor
Please help me for may led monitor asus vh197d how to remove the base to put in to a wall tns
For the ASUS VH197D LED Monitor, turn it upside down so you are looking into the base of the stand. Squeeze the plastic tabs to unlock the base and pull. This will remove enough of the base to make it wall mounted and you can quickly attach the base if so desired. If you want to permanently remove the base and stand, remove the two screws that are now visible after the base is removed and pry out the plastic stand. This will break it off at the hidden screws. You will be left with a short metal stub that can be folded in.
Mar 30, 2011 | ASUS VH197D LCD TV
Im trying to take my base of the tv to put it on a wall mount but the screws wont come out
Have you tried lifting the display off of the stand with all of the screws loosened? Even though they do not come out you should be able to remove the base stand once loose.
I hope this helps,
Magoo
Mar 09, 2011 | Samsung LN32B530 32 in. LCD HDTV
Sony bravia pedestal stand is unstable
http://www.docs.sony.com/release/SUWL31_EN_ES_FR.pdf This link will show what it looks like when removing base to wall mount.They always recomend a mounting strap that connects to the rear of the TV and then screws into the table it will be sitting on.Not sure what they expect you to do if you have a glass top table. http://www.docs.sony.com/release/SUWL31_EN_ES_FR.pdf
This is a link to all the downloadable manuals and what not.Well hope this will help,and good luck.
Mar 13, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
I'm trying to wall mount my Proscan 19LB30Q LCD. According to the manual, to remove the base, you simply take out 3 screws from the back near the base and pull out the stand gently. I can't remove the...
Although the instructions don't mention this, you also need to remove two screws on the bottom of the base. Pull the base bottom off. Then remove another screw that holds the base post on.
Nov 17, 2009 | Proscan Televison & Video
How does one remove the Toshiba TV stand. There does not appear to be any levers etc to release it. We want to mount our TV on the wall so the stand needs removing.
ya we put four screws in the base of the stand you have to lay t.v. on a flat surface protect the screen from getting damaged by putting a blanket over it when u flip it over or lay it flat on the bed you will see the 4 screws that hold the base to the t.v., but if it's a model that's having trouble just leave the base on as you will probably be returning it the store where you bought it lol
Aug 24, 2009 | Toshiba 40RV525U 40 in. LCD TV
I took the base off my Sony KDL40S2000 for wall mount and now I want to put the base back but when I tried it wobbles.. What do I do?
That tv looks similar to mine with the same base.
Have you pushed the stand fully in and tighten the screws fully.
I must admit,they do not seem really stable on those little stands.
Feb 25, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How can I put the base back on my tv Sony Bravia KDL40S2000
Lay the TV face down on a flat surface covered with a cloth. Back out all the screws holding the base stand. Hold the back and front against the base shank while tightening all the screws through the base. Make sure they are tight.
Feb 25, 2009 | Samsung LN-S2641D 26 in. LCD HDTV
Removing swival base
Most LCD TV's have 4 or 5 screws attaching the stand to the set near where the stand slots in at the bottom. The screws might be covered by a plastic panel.
Hope this helps.
Andy
Jun 25, 2008 | Televison & Video
Olevia 227V lcd
All you need to do is remove the two long screws on the back of the tv panel just above the stand, then the two short back panel screws AND the three short screws just above the two panel screws and the stand will come right off. DO NOT remove any of the other screws in the perimeter of the back panel. There is no need.
After much trial and error this is the correct and EASY procedure for this apparently troublesome task. Good Luck !!
Feb 12, 2008 | Olevia LT27HVX 27 in. LCD Television
Olevia LT32HVM 32 in. LCD Television Logo
48 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
