Question about Dryers
When dryer is turned on , it hums but the drum doesnt turn. It smells like heating element is working, belt is on correctly but drum will not turn. Any suggestions? Thank uou
  • king129 Sep 09, 2009
    Drum turns nanually but not very smoothly. Motor was turning extremely slowly and then dryer cut of like a breaker or fuse went off in dryer. Washer is on same outlet and it stll spins.
  • jamieei May 11, 2010
    can you turn the drum manually? if so, does it turn easily and smoothly? could be the bearing is bad. Have you confirmed the motor is actually turning?
    Problem Solver:
  • 4 Answers
Sounds like the bearing the drum rides on is bad. that will cause the breaker to trip as the motor strains to turn the drum on the bad bearing.
Posted on Sep 09, 2009
Testimonial: "very prompt response, thank you"
Asko t701 dryer burning smell
Loud noise is not a good description. What does it sound like? The dryer has a belt that turns the drum, the belt can wear and slip, there is a also a tensioner pulley on the belt system and then there is the motor that turns the drum. The smell could be from the belt, however you should know that dryers are not maintenance free and you have to clean them at least annually because they can build up lint in the cabinet and that lint can get into the heating element and it can start a fire.
Aug 19, 2016 | Asko T701 Electric Dryer
Heating works but drum doesnt turn.
Try turning drum, or remove top from dryer to confirm if belt has gone. When turning drum there should be some resistance as the belt fits around the drum
Feb 18, 2010 | Whirlpool LER4634J Electric Dryer
Press the start button and drum doesnt start but the dryer makes a humming noise.
motor running but drum not turning, good chance drum drive belt is broken or has jumped off drive pully.
UNPLUG POWER CORD TO DRYER.
open dryer and look for broken belt, if belt is broken use modle number from dryer to purchas the correct belt for dryer install belt and reasmbele dryer. reconect power and test dryer.
Oct 23, 2009 | Dryers
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Dryer motor just hums
Sounds like the belt has been stretched and is not letting the motor turn the drum. If the motor is not turning at all then your motor is burnt out and needs ot be replaced
May 22, 2009 | Dryers
My Whirlpool dryer LER3624EQ1 is overheating
If you open the dryer quick enough during a cycle, you will see the element glow. That's normal. It sounds like a belt problem. Something is causiing the drum to drag which will cause the belt not to turn as easy. This, in turn, will make the motor work harder and overamp as it is trying to move the belt but it is just sitting and spinning and burning the belt. Look for something like a rear drum bearing or tensioner pulley causing the problem. Continuity test just show that there is a complete circuit. This is confirmed by the element getting hot. Also, if you motor is not turning at the correct speed, this will slow down the amount of air being moved across the element. This will also cause excessive heating of the element.
Good luck and hope this helps.
Mar 01, 2009 | Whirlpool LER4634J Electric Dryer
Open Questions:
Dryers Logo
111 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
