Question about HP Pavilion dv1000 Notebook
I cant get my microphone to work
I have a advent laptop and the microphone is built in to it. when i try to make vidio calls or evin just record voice it does not work the light is not coming on it sayn it is working prop but obv its not any idead what i can do ?
    Sergeant:
  • 217 Answers
Try this, Go to Start click now Control Panel ,sound and audio devices click 2 x this will open up properties box , click Audio, Volume ,Look for internal mic that its checked and not muted volume can be adjusted too.Good Luck.
Posted on Sep 09, 2009
What do you do if the built in microphone for the Toshiba Satellite M305D-S4840 is not working (not picking up sound)?
SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphonedriver not installed or not working OR the microphone is not configured inSkype.
To test your microphone then click on Start - All Programs - Accessories -Entertainment - Sound recorder. Then record your voice and then play it back.If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options -Audio Settings for the Microphone THEN click on Save.
May 20, 2012 | Toshiba Satellite M305D Notebook
Does HP compaq nx6310 has built in microphone, how can i record my voice using built in microphone instead of using headset.
Check next to the camera there should be a small hole. That is the microphone. There should be a program on the laptop called voice recorder.
Sep 18, 2011 | HP Compaq nx6310 Notebook
I have a Toshiba Laptop PC. It is a Satellite Pro L300 Series. I wonder if it has a built in microphone so that I can add a voice/music clip to my power point slides. I do not have a separate...
Most laptops do have Microphones built in. I do not know for definate that your laptop does, but you can easily test it to find out.
1. Go to the volume control (double click the speaker icon near the clock on the taskbar), go to recording properties and select microphone as the recording source and set the slider to about 80%.
2. Bring up microsoft sound recorder (its in the start menu somewhere) and click record... when you speak you should see a voice print appear in the sound recorder window.
If you do not see a voiceprint, then you probably dont have a built in microphone, but if you do see a voiceprint as you speak then you do have a microphone built in and you can record into your powerpoint shows to your hearts content.
Hope this helps!
Aug 18, 2010 | Toshiba Audio Players & Recorders
Toshiba laptop Microphone Not working or Non-existant?
Click Start/All Programs/Accessories/Sound Recorder. Click Start Recording and talk to your computer in a normal voice. When you finish click Stop Recording. Type in a file name and click save. Open the file and play it. If it works you have a built in mike, otherwise buy yourself an external, which I recommend anyway, because the built in mikes are generally not good enough for voice recognition or VOIP.
Sep 22, 2009 | Toshiba (P000257700) Microphone
Audio on Dell Webcam Central And voice record isn't working
I have a Dell 1545 with Dell web cam central & I've had this issue. The problem is that Dell web cam central installs it's own microphone settings onto your laptop called something like Dell web cam Live!. This isn't the built in microphone in my laptop & maybe not yours either. You have to change the settings for your computer system & Dell web cam central. Go to start> control panel> sound> recording .. on mine there is an option for Microphone "High Definition Audio Device" ... that is the built in mic. You want that for your default & apply it. Also .. as a side note .. I disabled the web cam central Live! microphone completely from this window. Then open Dell web cam central & go to the "Record Video's" option. In the middle of this is an orange button with a video camera icon. Next to this on the same button is a little arrow pointing down .. click that. Under microphone .. choose Microphone "High Definition Audio Device" just like the sound option in control panel. I've done this & it's completely fixed. I can record videos with sound & use my built in mic in voice/video chat.
Aug 15, 2009 | Dell Inspiron 1545 Notebook
I?m facing a problem with built-in microphone that its not working after i install XP.
Try going to the control panel,
  1. click on sound's and audio device's,
  2. in the sound's and audio device's propertie's box click the voice tab at the top,
  3. under voice recording check to see if the internal mic is checked in the voice recording, default device box,
  4. if it is click the volume box, a new box will appear that say's recording control,
  5. make sure the microphone has a check in the box,
  6. under microphone click the advanced tab,
  7. in the advanced tab make sure the microphone boost has a check in the box,
  8. go back to the sound's and audio device's propertie's box under the voice tab,
  9. at the bottom of the box under voice click on test hardware,
  10. on some built in microphone's you have to talk into the area where the mic is located on the laptop.
  11. if it does'nt help try using the device manager to resolve the sound issue's, check to see if the device is enabled, if it is use the troubleshooting tab to see if the device has a conflict, if it's working properly it will say this device is working properly, or try using the update driver tab.
Apr 16, 2009 | HP Compaq Presario CQ50-210US Notebook
Acer Aspire 7720 built-in microphone not working
In the sounds control panel, right click in the area which should show recording devices. Select 'show disabled devices' and bingo!
Feb 25, 2009 | Acer Aspire 7720 Notebook PC
Inbuilt speaker is not working
u need check u r sound setting click on sound icon on u r taskbar and then click on properties and playback or recording click on microphone and try to scroll lolz try dear
Oct 21, 2008 | Compaq Presario 700 470024-192 Notebook
HP Pavilion dv1000 Notebook Logo
115 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
