Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Fridge is freezing everything!
The refrigerator side started freezing everything, I have thawed fridge side, turned back on and it went back to 20 degrees in the fridge, help!!
  • 11,896 Answers
There is a flap that directs the air from freezer to fridge. Sometimes this flap can stick Or the actuator that controls the flap can go out. Same with autodefrost timer which seems to give a lot of people trouble. Thermostat is at the top, uncirculated cold air sinks, food in the bottom of the fridge freezes.
Posted on Sep 09, 2009
GE profile side by side fridge freezing and thawing randomly
Defrost entire unit, put food in coolers with ice and unplug. Wait 24 hours with doors open. Any clogs in freon lines should be gone, plug unit back in and see how it works.
Jan 24, 2014 | GE GSS22SGM Side by Side Refrigerator
Rs 265lbbp fridge is freezing everything fridge portion no ice on coils
This unit has a heater on the damper door. Sometimes the heaters go bad our just weak, causeing the damper door to freezer close. You can try thawing our damper by removing it to see if the issue happens again.
Aug 18, 2012 | Samsung RS265LBBP Side by Side...
I don't know what happened to my refrigerator but it is starting to freeze everything. I couldn't change filter because it was stuck, frozen in place. So i had to turn the fridge off so it could thaw out...
1 setting on a fridge is as cold as it can get so it will be close to freezing
should be set on 4 or 5
next if it still is freezing then the thermostat is failed and you will need to replace it
May 09, 2017 | Frigidaire FRS23H5ASB Gallery 22.6 Cubic...
Maytag msd2454gr side by side. The evaporator coils freeze up and the fridge gets warm. This happened about a year ago and I thawed it out and everything was fine. It happened again about a week ago so...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 30, 2010 | Maytag MSD2454G Side by Side Refrigerator
GE fridge and freezer cools when it wants to - freezer on top
hard to say, there is many questions left that need answered...does the compressor run, does the fans run? what more could you tell me.... whirlpoolpartssurplus.com free tech support
Jun 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My fridge is not cold enough and the freeze is colder and has ice
hi. thanks for the question. the drain tube that goes down to the drain tray is clogged. turn fridge off .pull fridge from wall. remove back panel clean all coils. let it thaw with doors open, it will thaw quiker. when thawed, clean the drain tube. this will solve the problem. thanks the appliance doc
Sep 28, 2008 | Refrigerators
Everything freezes in the refrigerator
Your damper that controls the air to the fridge side is stuck open. It can be caused by moisture getting on it and freezing it so it wont close or by a failure in the electrical circuit that controls it. There was a service bulletin from about 3-4 years ago about defective control assemblys. I have replaced several and as far as I know Frigidaire is still replacing some of them for free if they fall under the model and serial numbers that were affected.
You can tell if it is frozen by turning the controls off and thawing the damper at the upper left rear of the fridge section with a hair dryer.. After you have it thawed out, turn the controls back on and you should hear the damper door motor running. Keep your thermometer in it and check it after a while and see if it shuts off before it freezes.
Post back with the complete model and serial numbers and I will try to locate the service bulletin at my shop computer tomorrow.
Oct 26, 2007 | Frigidaire FRS26R4C Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
330 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
