Question about Canon MV6iMC Mini DV Digital Camcorder
Moisture icon mv6i
Iv not used my camcorder for a while and now when I switch it on the moisture icon flashes and films will not play. Is there anything i can do about this myself or will i need to have it serviced.
  • Chris-T Dec 11, 2007
    Hi after 6 months of not using the camera, I have just turned it on to find the same problem, I have done as they say in the manual, taking the tape and battery of and leaving it in a warm dry area, but not change please tell me how to fix it without having to spend over £130 in service charges, Thanks Chris
  • hangie Feb 24, 2014
    http://youtu.be/ZLFJD2a-ZLw
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
You can disable the condensation detector by shorting the two bottom connections at the end of the ribbon cable ( four live and a dummy middle) from the motor/condensation detector to the front board. You need to remove the front body panel to gain access and it is quite fiddly soldering, and it will leave you with an operating camera, but no protection from condensation if you should use the camera in atmospheric conditions where condensation could occur. Also, you can repair a broken ribbon cable.
See:
https://www.youtube.com/watch?v=ZLFJD2a-ZLw
Posted on Feb 26, 2009
  • 64 Answers
Can you get it to rewind and fast forward if so take a lp recording that you have recorded with completly and rewind it and fast forward it all the way and after that use a soft cleaning tape and run it for 20 secs if that doesnt work then theres not much you could do other then to send it in sometimes the method i have stated works sometimes it doesnt
Posted on Dec 26, 2007
Model MV6i Camera works but have flashing red icon adjacent battery icon which looks like a 'little man in a row boat '!
This symbol means that your backup battery needs to be replaced. It is a "button battery", type CR1616. Instructions for replacing it are in the manual, which is available to view or download here.
Aug 26, 2009 | Canon MV6iMC Mini DV Digital Camcorder
Canon Camcorder MV6i MC
This is a very common condition if you live in a very humid area. Do you know what is the humidity % in the area you live?
Jan 01, 2008 | Video Cameras
WILL NOT PLAY BACK NOR ZOOM IN OR OUT
WOW! You've realy got some problems. With this combination of failures I would suggest that you may have gotten envloved in some environmental conditions which have caused differing unrelated symptoms all connected to exposure to moisture. The focus data is communicated through a flexible printed cable to the lens and may have the connector eroded by moisture. Ordinarily a cleaning tape should restore playback if it indeed was able to properly record in the first place (same set of heads in use for both record and playback). If the play and rewind buttons do not function you may have another cable problem. More info could be useful. Good luck, magic seadog
Aug 21, 2007 | Sony Handycam CCD-TR416 Camcorder
What does C:31:22 mean?
Per the manual
C means you can fix E means professional service needed.
21 is moisture condensation. icon of rain drop in a box will flash on screen unless moisture in lens Eject tape let sit 1 hour or more to acclimate
31...manual says to eject cassete and reinsert, operate OR daisconnectpower cord andremove battery, reconnect, operate.
Mar 08, 2009 | Sony Handycam CCDTRV118 Camcorder
Can not download film clip through PMB or Handycam Utility icons
Keep playing with the USB options on the camcorder while the PC is up with the PMB program running. I had to try the option on the left of the vid camera screen USB with the little disc icons. It took several attempts but it will work
Jan 11, 2009 | Sony Handycam® DCRSR45 HDD Camcorder
Sony TRV120 Won't load tape C21:00 code
From the user manual ...
Under self diagnosis display
C21:00
Moisture condensation has occurred.
Remove the cassette and leave your camcorder for at least 1 hour to acclimatize. (p117)
On p117
If your camcorder is brought directly from a cold to a warm place, moisture may condense inside your camcorder, on the surface of the tape, or on the lens. In this condition, the tape may stick to the head drum and be damaged or your camcorder may not operate correctly. If there is moisture inside your camcorder, the beep sounds and the [picture of water drip] indicator flashes. When the [end tape icon] indicator flashes at the same time, the cassette is inserted in your camcorder. If moisture condenses on the lens, the indicator will not appear.
If moisture condensation occurred
None of the functions except cassette ejection will work. Eject the cassette, turn off your camcorder, and leave it for about 1 hour with the cassette compartment open. Your camcorder can be used again if the [water drip] indicator does not appear when the power is turned on again.
Note on moisture condensation
Moisture may condense when you bring your camcorder from a cold place into a warm place (or vice-versa) or when you use your camcorder in a hot place as follows:
- You bring your camcorder from a ski slope into a place warmed up by a heating device.
- You bring your camcorder from an air-conditioned car or room into a hot place outside.
- You use your camcorder after a squall or a shower.
- You use your camcorder in a high temperature and humidity place.
How to prevent moisture condensation
when you bring your camcorder from a cold place into a warm place, put your camcorder in a plastic bag and tightly seal it. Remove the bag when the air temperature inside the plastic bag has reached the surrounding temperature (after about 1 hour).
Dec 06, 2008 | Sony Handycam DCR-TRV120BT Digital...
Power light flashes
It could be the common moisture sensor problem.
Take the base cover off by removing the 4 screws (3 on base - 1 under LCD). There will be two small copper contacts under this cover toward the top/middle. Either just blow on them or if that does not work clean them with alcohol spirit or similar, put the think back together and power up and that should do it - worked for me.
Feb 24, 2008 | Panasonic NV-DS60 Mini DV Digital...
Tape will not load
I have enabled the MV6i to load a tape by: replacing the 3V 'data' battery, re-entering the date and time, turning the camera off for about half an hour, after taking several photos using the photo function the tape would load properly. Hope this works for you too! jimtarver@ntlworld.com
Mar 07, 2007 | Canon MV6iMC Mini DV Digital Camcorder
Tape will not play or record - flashing eject icon and beeping
Hi! I think the Switch Block is defective. May be you need a service manual as well. Pl.re examine and let me know. We can help you on the parts and manuals at a reasonable cost. may be you can seom of them in this link. http://asia.pg.photos.yahoo.com/ph/videospare/album?.dir=da14&.src=ph&store=&prodid=&.done=http%3a//asia.pg.photos.yahoo.com/ph//my_photos
Nov 28, 2006 | Sony Handycam DCR-TRV250E Digital...
Condensation
When pouring a chilled beverage into a glass, water droplets may form on the surface of the glass. This happens because the air around the glass is rapidly cooled down, and moisture in the air adheres to the surface of the glass. This phenomenon is called condensation. This kind of condensation may also occur with camcorders. If you continue to use the camcorder with condensation on it, it could damage the camcorder. Condensation may form on the camcorder in the following cases: (1) When being moved from a cold place to a warm place (2) When being used in a rapidly-heated cold room (3) When being used in a humid room (4) When being moved from an air-conditioned room to a warm, humid place When condensation occurs: The camcorder stops operating automatically after its power lamp flashes. The warning message "CONDENSATION HAS BEEN DETECTED" appears and the condensation-warning icon below starts flashing. Condensation-warning icon If a cassette is loaded, the warning message "CONDENSATION HAS BEEN DETECTED" and "REMOVE THE CASSETTE" appear and the cassette-warning icon starts flashing. Cassette-warning icon If a cassette is loaded in the camcorder, remove the cassette immediately and leave the cassette compartment open. If condensation is detected, the POWER switch and cassette-removing switch will be activated. Leaving the cassette in the camcorder may damage the tape. A cassette should not be loaded into the camcorder when condensation is detected. How to avoid condensation Unload the cassette and place the camcorder in an airtight plastic bag when moving to locations where temperatures vary. Allow time for the camcorder to adjust to temperature changes slowly before removing it from the bag. Resuming use Allow at least one hour before resuming use; more time may be required for heavier condensation. When condensation has been eliminated, turn the camcorder on. After the condensation-warning icon stops flashing, wait one hour before resuming use.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Canon MV6iMC Mini DV Digital Camcorder Logo
236 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
